DBPoweramp 14 - CDGrab.exe - Problem
  • MagicMusic
    • Oct 2010
    I used dbpoweramp 13.5 Reference 'til now without any problems. I have updated to dbpoweramp 14 Reference "Family Pack) - and now I have a big problem. :cry:
    dbpoweramp 14 (CDgrab.exe) hangs up at the last track on every CD. For example a CD with 15 tracks: Track 1 to 14 will be ripped and at track 15 the rip starts and at 95% it stops. The software can only be closed with the task manager. I tried several CD's - same problem.
    I already de-installed the software and cleaned the registry. After new installing dbpoweramp 14 - same problem.
    So I went back to dbpoweramp 13.5 Reference - and everything works fine without any problem.
    Any ideas what this could be?
    My PC works with Windows XP SP 3 - all existing patches are installed.
    Thanks for your help in advance.
    Michael - PB - Germany
    • 46198
    Re: DBPoweramp 14 - CDGrab.exe - Problem
    Did you check the 'Over-Read' option? perhaps it should not be checked for your drive.
    • MagicMusic
      • Oct 2010
      Well, this option is checked since I use dbpoweramp (actual 13.5) and I never had problems with this.
      For your information:
      I'm using an external drive "Yamaha CRW-F1 SCSI"
      With dbpoweramp 14 I have the problems with both drives - the external and the internal drive
      • MagicMusic
        • Oct 2010
        Originally posted by hoanglongk
        Please upload a screen shot of the metadrop menu to somewhere like imageshack.
        Sorry. I don't know which menu you mean exactly.
          • 46198
          The previous version of dBpoweramp would not overread correctly on some drives, it is highly likely that the Yamaha cannot overread.
          • 2285b
            • Oct 2010
            I´ve got exactly the same problem after upgrading! Also XP/SP3 and never had problems with earlier versions. My drive is : HL-DT-ST DVDRAM GSA-T20L.
            Where can I check it? Or is there already another solution?
            Best regards
            Axel
              • 46198
              It should be unchecked, it is CD Ripper >> Options
              • 2285b
                • Oct 2010
                Sorry, but I can´t find the Over-Read-Option there...:blush:
                Regards
                Axel
                  • 46198
                  The line is titled 'Read into Lead-in or Lead out'
                  • 2285b
                    • Oct 2010
                    Thanks, now it works again
                    Greetz
                    Axel
