Problem with reading CDTEXT with dBpoweramp 13.4
  • BlueEntity
    • Apr 2010
    I am having problems reading CD-Text from my self-mastered audio CDs containing live recordings.
    ID Tags for these CDs cannot be found within the common internet databases - but the CDs contain CD-Text.
    Nevertheless I am unable to read the CD-Text data using dBpoweramp 13.4.
    If I select 'Meta->Retrieve From->CD-Text' simply nothing happens.
    The drive is a 'MATSHITA DVD-RAM UJ-842 RB01'.
    EAC and SonicStage have no problem reading the CDText.
    Any suggestions? Do I have to enable CD-Text support within dBpoweramp first?
    • 46198
    Re: Problem with reading CDTEXT with dBpoweramp 13.4
    Do any commercial cd-text discs work for you?
    • BlueEntity
      • Apr 2010
      Nope. Same problem (tested with 2 different CDs).
      It looks to me as if dBpoweramp doesn't even try to access the cd drive (if I try to retrieve CD-ISRC it clearly does though).
      • eaglescout1998
        • Apr 2009
        • 203
        I have experienced the same problem . . . even on discs that I knew had CD-Text because earlier versions of the ripper could retrieve it.
