cda to cda rip cda not listed
  • wanttono
    • Jan 2010
    • 12
    Hi
    i am trying to rip from cda to cda .. updated reference / new license but i dont have the option for cda .. simple fix i know but search function gave 6 pages of nothing i found
    updated all db programs
    any ideas thanks
    new install in w7
    Re: cda to cda rip cda not listed
    Install CD Writer.
    • wanttono
      • Jan 2010
      • 12
      HI
      thanks for quick resp .. I have writer installed .. dBpoweramp-CDWriter-Registered-r3 program when i try to launch it independently it gives me a "cd writer req music converter needs reference 13 or newer .. I thought i just paid for and installed that product ..
      • wanttono
        • Jan 2010
        • 12
        Re: cda to cda rip cda not listed DONE
        Got it .. thanks .. could have .. should have been easier ..
        the reference is an xtra dl in addition to the writer prog ..
        • wanttono
          • Jan 2010
          • 12
          Re: cda to cda rip cda not listed still ng
          I got it to show cda ... part one done
          BUT
          When i select cda to cda it saves/rips it as wave .. not what i wanted .. what next ?
          oh and instant email notification isnt working
          • eaglescout1998
            • Apr 2009
            • 203
            I am not sure if I am repeating information you already know, but CDA files are not actual audio files. They contain no PCM wave data. They're simply files that Windows uses to indicate CD tracks. CDA files copied from the disc to the hard drive are useless.
            • Wayne
              • Aug 2002
              • 1254
              BUT
              As already mentioned cda files do not contain any audio content they are just pointers on an audio CD that point to where the actual audio data is on the CD.
              You need to use the CD Ripper to "Convert To" Audio CD for cda to cda conversion. Initially the ripper wil populate the CD Writer and once completed you can burn the new audio cd.
              The notification system hasn't been working for some time.
              • wanttono
                • Jan 2010
                • 12
                Re: cda to cda rip
                Thanks Wayne
                let me backup .. with the older registered version I could save/rip cda to cda onto Hard drive .. and that is my goal (with tags hopefully) .. so this cd ripper does not show a convert to option other than what you can see in this screenshot .. IF i remember right, my older ver had a radio button on left (ripper) showed a drop down to further change default settings .. of course my head might be up my butt
                Frank
                note i am also posting to another trouble ticket .. any connection ?
                  Re: cda to cda rip
                  If you want to rip to HDD, then you should not select the encoder as 'Audio CD', rather the audio format you wish to rip to (mp3? flac). Selecting Audio CD would grey out the path, because it is ripping (reading CD) >> Audio CD (writing)
                  • wanttono
                    • Jan 2010
                    • 12
                    Re: cda to cda rip
                    So does the older versions of db let me save as cda ?
                    [QUOTE=wanttono;96732]Thanks Wayne
                      Re: cda to cda rip
                      As already mentioned, CDA is not a file format, it is impossible to rip and save as CDA on the HDD, Wave is the closest format to CDA.
