Problem with AccurateRip
  • wcvb
    • Oct 2009
    • 27
    I have installed the free trial of dBpoweramp Music Converter R13.3. I have a MATSUSHITA - DVD - RAM UJ862A.
    I have followed the directions in the dBpoweramp CD Ripper: Setup Guide, but when I put in CDs to configure AccurateRip the track information and the CD Album Art appear but nothing else happens.
    I have tried over 20 CDs many of which were on the AccurateRip Key Discs liist (http://www.accuraterip.com/keydiscs.htm). Please advise where I'm going wrong.
    • 46198
    Re: Problem with AccurateRip
    Keep trying discs.
    • wcvb
      • Oct 2009
      • 27
      Thanks for the reply.
      I'm still trying.
      Do you have any jazz or classical titles to suggest?
      • wcvb
        • Oct 2009
        • 27
        I haven't had any success yet.
        Is there any way to fully erase all traces of dbpoweramp and reinstall it? I tried the uninstall programs but the new installation still had the parameters I had set instead of the original defaults, indicating that there was a trace that was not removed by the uninstaller.
        The dbpoweramp CD Ripper Setup Guide says:
        "Normally only 1 CD is needed, but if your CD drive does not appear in AccurateRip's main database of CD drives then 3 matching results from 3 different discs will be required. "
        How do access the 3 CD option?
        Is there anything else you can recommend?
        • EliC
          • 1175
          borrow some mainstream cds from friends or family...
            • 46198
            Try this as well:
            http://forum.dbpoweramp.com/showthread.php?t=13285
            Clear off totally then reinstall.
            • wcvb
              • Oct 2009
              • 27
              Problem solved!
              There was a value of +102 in Option: CD ROM: Sample Offset (I don't know why or when it was set). I reset to zero and the value changed to let Accuraterip find the offset. Accuraterip configured automatically immediately thereafter, setting the offset back to +102.
              Thanks for bearing with me.
                • 46198
                That means it had already configured.
