Ripping Speed slows down when C2 enabled
  • pradig
    • Aug 2009
    • 12
    I have a brandnew Plextor PX-860A. Testing shows that it support C2 and FUA and no cache.
    With C2 and FUA disable a disk takes approximately 6 min with all tracks ripped accurately.
    With C2 and FUA enable the same disk takes around 13 min with all tracks accurate, too.
    Is that supposed to happen?
    • 46221
    Re: Ripping Speed slows down when C2 enabled
    No, how does the drive connect to the system?
    • pradig
      • Aug 2009
      • 12
      IDE directly to the mainboard. No other IDE device on that bus.
        • 46221
        Try eac using c2 switched on, what is the speed like?
        • pradig
          • Aug 2009
          • 12
          All done with the same disc:
          dBPa, C2 on, FUA on: 13:20
          dbPa, C2 off, FUA off: 5:30
          EAC, C2 on: 7:08
          EAC, C2 off: 10:30
          All tracks are ripped "accurate".
          • Tigerman
            • Mar 2005
            • 157
            It would be nice if you also tried
            dBPa, C2 on, FUA off
            From the data till now, I get the impression that c2 works, but FUA not.
            "Happiness is nothing more than good health and a bad memory."
            Albert Schweitzer (1875 - 1965)
            • pradig
              • Aug 2009
              • 12
              C2 on and FUA off takes about the same as with both on.
                • 46221
                Try the R13.3 beta (in the beta section of this forum), it has a new switch for lower message sizes when using c2, but normally only USB or firewire is effected by this).
                • pradig
                  • Aug 2009
                  • 12
                  It doesn't make a difference, > 13 min ripping time.
                    • 46221
                    How many passes does it take when ripping?
                    • bhoar
                      • Sep 2006
                      • 1173
                      I wonder if it's ping-ponging between READ CD and READ CD MSF (IIRC, my scsi logging showed you would autofail over to the other read command on errors).
                      Perhaps the C2 flag only works with one command and not the other on some Plextor drives?
                      -brendan
                        • 46221
                        If it fails onto a 2nd method the next call uses that method.
                        • bhoar
                          • Sep 2006
                          • 1173
                          Hmm, perhaps another deeper layer of debug could be introduced that would trace the read calls and responses sans data. And perhaps another level with the data too (logged to a very very very large text file).
                          -brendan
