Won't rip on one machine
  • fphredd
    • Feb 2009
    • 61
    Help...
    Have run over 1,000 discs through used MF Digital Ripstation (yes, the one I've fought with before, but that was mechanical...) and all the ripped results have been fine.
    Loaded a batch today, and they won't rip; I get the message:
    Error ripping to FLAC, 'Track 1' to 'I:\Music Untagged\4-21-2009\ -\01 Track 1.flac' Error unable to open File 'I:\Music Untagged\4-21-2009\ -\01 Track 1.flac' for writing. [clEncoder::BeginConversion]
    Every track, same error. This happened on the first 6 discs in the batch, at which point I ended the batch. Tried one of the CD's in plain old CD Ripper, same result. Loaded the CD in another machine, rips in CD Ripper with no problem :confused:
    Both computers have automatic windows update enabled, and both got updated; the MF Digital more than the other...possible cause????
    Thanks for any help. Let me know if you need more information.
    "When the going gets weird, the weird turn pro." HS Thompson
  • bhoar
    • Sep 2006
    • 1173
    Re: Won't rip on one machine
    Is " -" (that is <space><minus>) a valid directory name? Was the Naming string in your default profile (assuming you're using the same one in CD Ripper and Batch Ripper) set to something that makes sense?
    -brendan
    • fphredd
      • Feb 2009
      • 61
      It's not the naming. The setup you saw has worked on CD Ripper before, worked on the second machine as well.
      For test purposes, ran again without that part of the naming, same error:
      Error ripping to FLAC, 'Track 1' to 'I:\Music Untagged\4-22-2009\01 Track 1.flac'
      Error unable to open File 'I:\Music Untagged\4-22-2009\01 Track 1.flac' for writing. [clEncoder::BeginConversion]
      Next??
      thnx
      • bhoar
        • Sep 2006
        • 1173
        What's on the I: drive? Are you sure your optical drives didn't get renamed and I: is now an optical drive?
        -brendan
        • fphredd
          • Feb 2009
          • 61
          Nice! Wasn't that but you put me on the right path...Drive connection issue.
          THANK YOU BRENDAN! :komisch12
