Defective Disc: unreadable @ 8x speed, no errors @ Maximum?
  • dvdr
    • Sep 2008
    • 235
    I usually rip with a Plextor 1210a and 230a at 8x speed (AR-Rip + min. 2 secure reads) to ensure a proper read.
    I encountered a ripping problem with a really badly damaged disc - 13.000 and more frames to rerip, giving up after 30 unrecoverable frames. Shutting off "mark as error" the resulting files of 3 tracks stuttered with heavy dropouts.
    I put the CD into a LiteOn Lightscribe DVD-burner with the same settings and set the read speed to maximum - NO frames to rerip! Setting the read-speed to 24, 12, 8 resulted in errors again - the slower the speed, the more frames to rerip.
    :confused::confused:
    Unfortunately, the CD is not in the AR database, so I have no clue, whether the max-speed-LiteOn rip is accurate.
    But listening to the ripped tracks, at least no stutter or dropouts are audible, they seem to be fine, not even distortion in those 40-seconds-plus long sections, that used to stutter
    So: is there any explanation for this? Shouldn't slower ripping speeds enable a laser to stay better "in focus" and pick up "track" after defective zones more easily? Is there a common recommendation of ripping speeds (talking about things like higher jitter at high ripping speeds)?
    Thanks!
    [SIZE="1"][B][I]WHS ACER H340 w/ Asset V3, Linn Sneaky, Plugplayer/Songbook/Kinsky, Music mostly *.flac[/I][/B][/SIZE]
    • 46198
    Re: Defective Disc: unreadable @ 8x speed, no errors @ Maximum?
    No often with modern CD drives a slower speed makes it more difficult for the disc to be read.
    • bhoar
      • Sep 2006
      • 1173
      In addition, the Lite-On might have a very good "cover up errors" algorithm. That is, you know you're not getting an accurate rip, but you're getting one that sounds less bad.
      -brendan
