Using [Arrange Audio] to Organize and ID Tag Batches of Audio Files
  • AudibleImagery
    • Aug 2020
    • 50
    Hello DBPoweramp Support Forum,
    I'm trying to devise an [Arrange Audio] arrangement scheme through Batch Converter that would allow me to create a folder structure that would only add disc folders to said structure if I'm converting a multi-disc album (I assume this would be done with a programmable action such as [IFMULTI] but I don't know exactly how I'm supposed to write it). Here's what I have so far: [album artist] - [album]/Disc [disc]/[track] [title]
    I've tried innumerable combinations of banging my head against the wall but am about to pass out. Can someone please advise me on how to proceed?
    The other conversion I'm trying to accomplish is using the "ID Tag Processing" DSP Effect to add "(Disc *)" to the album tag. I also haven't gotten anywhere with this but have tried different combinations with rule based manipulation, mapping, and additions but to no avail. Any help would be appreciated.
    Also, are there any guides that could provide some direction as to how to do this stuff so I can try to mitigate pestering this forum in the future?
    Regards,
    John
Name:	Screen Shot 2022-03-10 at 17.27.35.jpg
    • 45836
    Re: Using [Arrange Audio] to Organize and ID Tag Batches of Audio Files
    Try:
    [album artist] - [album]/[IFMULTI]Disc [disc]/[][track] [title]
    • AudibleImagery
      • Aug 2020
      • 50
      Try:
      Hey Spoon, this did the trick for arranging multi-disc albums into folders "Disc 1", "Disc 2", etc and also not creating disc folders for single disc albums, which will make my life a lot easier. Thank you for your help. I was off by the "[]" you put to the left of "[track]" - what does "[]" do?
      Is there a way to also add the disc numbers (i.e., "Stadium Arcadium (Disc One)") to the album ID tags for multi-disc albums within this same [Arrange Audio] process?
      • AudibleImagery
        • Aug 2020
        • 50
        Hey simbun, thank you for the resource, I will definitely look into the dBpoweramp Naming page that you recommended.
        The reason why I want to add (Disc x) to the album tag is because I tag multi-disc albums with the disc number in order to avoid confusion. i.e., I use the tags "Endtroducing (Disc One)" and "Endtroducing (Disc Two)" instead of just "Endtroducing" so that if I'm shuffling albums and disc one plays it doesn't start playing disc two after the first disc finishes.
          • 45836
          [] closes the [IFMULTI] statement
          • AudibleImagery
            • Aug 2020
            • 50
            Hi again
            Originally posted by simbun
            Interesting, the only reason I ask is because I go out of my way to do exactly the opposite
            When I'm playing music I want to be able to choose to play just the core album, without any bonus content, so I have the same album name across all the tracks and then use DISCSUBTITLE or GROUPING (depending how the original disc is structured) in order to separate the two parts e.g.
            Adele - (2008) - 19 (Expanded Edition)
            Disc 1: 19
            Disc 2: Acoustic Set Live From The Hotel Cafe, Los Angeles
            Then from the control point I can either play the whole album, or choose to play the relevant DISCSUBTITLE/GROUPING.
            Admittedly I don't shuffle albums, and I doubt the shuffle functionality will work at the DISCSUBTITLE/GROUPING level.
            This is an approach that actually makes a lot of sense and one I might seriously consider because I like the fact that you can include subtitles which I usually end up throwing out for the sake of consistency.
            Regarding adding (Disc One), you could try:
            dBpoweramp CD Ripper > Menu > CD Ripper Options, and under 'Tags & Filenames' choose 'Meta Data & ID Tag' Options, and change 'Multi-CD Add Disc to Album' to '[album] (Disc [discnum])'. This changes the album tag globally, so will be reflected in your folder structure too (if it includes album).
            If you preferred One versus 1, you could add to the 'ID Tag Processing' DSP, under 'Manipulation > Word / Character Replacement':
            (Disc 1) -> (Disc One)
            {Disc 2) -> (Disc Two)
            This again is a global change.
            I tried your suggestion regarding adding "(Disc 1)" to the album tags but it didn't work with either my Lossless Converter profile or Arrange Audio. I couldn't find any conflicting settings in any of the other preference settings. I recently tried to simplify my "Default Tag Edit Fields"; could this have something do with why it's not adding (Disc x) to the album tag?:
Name:	Screen Shot 2022-03-21 at 12.15.46.png
            I'm also using FLAC. I don't know if that changes anything regarding my tagging capabilities.
              • 6167
              mp3tag.exe would also allow such file name/location/tag manipulation in a batch manner.
