Mass Removing Leading and Trailing Whitespaces From a Tag Field
    • 6188
    #31
    Re: Mass Removing Leading and Trailing Whitespaces From a Tag Field
    Originally posted by AudibleImagery
    I recall a discussion you had with another person on here regarding leading whitespace on iTunNorm tags which is what lead me to my post but I didn't have any luck in finding the old discussion. It was probably years ago but the main point of the original poster was that the leading whitespace was not getting detected by iTunes' Sound Check. Are you certain that a leading whitespace won't disrupt the Sound Check process?
    I have leading whitespace on all my iTunNorm tags, and iTunes is recognizing the soundcheck values from these tags. So it seems the leading whitespace is not an issue. And mp3tag is also producing the iTunNorm tags with leading whitespace, and I know they updated their software to correct another issue with iTunNorm tags a while back. The fact that both dbpa and mp3tag produce iTunNorm tags with leading whitespace, and that itunes still picks up the SOUNDCHECK value in my mp3 files, tells me that there is no problem with the leading white space.
    • AudibleImagery
      • Aug 2020
      • 50
      #32
      Originally posted by PeterP
      Please click "report" button in the window, copy all the problem details info and post here.
      Process: dBpoweramp Music Converter [12356]
      Path: /Applications/dBpoweramp Music Converter.app/Contents/MacOS/dBpoweramp Music Converter
      Identifier: dBpoweramp Music Converter
      Version: Release 17.2 (1)
      Code Type: X86-64 (Native)
      Parent Process: dBpoweramp Music Converter [9412]
      Responsible: dBpoweramp Music Converter [9412]
      User ID: 501
      Date/Time: 2020-09-29 13:04:22.312 -0700
      OS Version: Mac OS X 10.15.7 (19H2)
      Report Version: 12
      Bridge OS Version: 4.6 (17P6610)
      Anonymous UUID: A697AF1E-DC38-F740-7AC0-2837C9C0929E
      Sleep/Wake UUID: 3DBB4A35-1AF8-45B4-9DD2-899965EE3291
      Time Awake Since Boot: 82000 seconds
      Time Since Wake: 16000 seconds
      System Integrity Protection: enabled
      Crashed Thread: 0 Dispatch queue: com.apple.main-thread
      Exception Type: EXC_BAD_ACCESS (SIGSEGV)
      Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000028
      Exception Note: EXC_CORPSE_NOTIFY
      Termination Signal: Segmentation fault: 11
      Termination Reason: Namespace SIGNAL, Code 0xb
      Terminating Process: exc handler [12356]
      VM Regions Near 0x28:
      __TEXT 00000001038ec000-0000000104112000 [ 8344K] r-x/r-x SM=COW /Applications/dBpoweramp Music Converter.app/Contents/MacOS/dBpoweramp Music Converter
      Application Specific Information:
      dyld2 mode
      Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
      0 com.Illustrate.dBpoweramp-Music-Converter 0x0000000103b1f110 ebur128_add_frames_float(ebur128_state*, float const*, unsigned long) + 34
      1 com.Illustrate.dBpoweramp-Music-Converter 0x0000000103b02b90 clEBUR128::ebur128_add_frames_float(ebur128_state* , float const*, unsigned long) + 18
      2 com.Illustrate.dBpoweramp-Music-Converter 0x0000000103913173 clDSP_ReplayGain::PassAudioBlock(STdBAudioBlock&) + 521
      3 com.Illustrate.dBpoweramp-Music-Converter 0x000000010395029a dBCoreConverter::DSPPassAudioBlock(STdBAudioBlock& ) + 106
      4 com.Illustrate.dBpoweramp-Music-Converter 0x000000010394af7e dBCoreConverter::dBCoreConverter(XListElementValue *, void*, void*, void*) + 5848
      5 com.Illustrate.dBpoweramp-Music-Converter 0x0000000103951369 CoreConverterMain(int, char const* const*) + 170
      6 libdyld.dylib 0x00007fff73b64cc9 start + 1
      Thread 1:
      0 libsystem_pthread.dylib 0x00007fff73d64b68 start_wqthread + 0
      Thread 2:
      Thread 3:
      0 libsystem_kernel.dylib 0x00007fff73ca8756 __semwait_signal + 10
      1 libsystem_c.dylib 0x00007fff73c2beea nanosleep + 196
      2 libsystem_c.dylib 0x00007fff73c2bde4 usleep + 53
      3 com.Illustrate.dBpoweramp-Music-Converter 0x000000010394938f dBCoreConverter::PumpCodecPipesCallback(XEvent&) + 43
      4 com.Illustrate.dBpoweramp-Music-Converter 0x00000001039e7960 XThread::Entry(void*) + 24
      5 com.Illustrate.dBpoweramp-Music-Converter 0x0000000103b0ed00 XThread::AppleThreadEntrySpecial(void*) + 26
      6 libsystem_pthread.dylib 0x00007fff73d69109 _pthread_start + 148
      7 libsystem_pthread.dylib 0x00007fff73d64b8b thread_start + 15
      Thread 0 crashed with X86 Thread State (64-bit):
      rax: 0x0000000000000000 rbx: 0x0000000000000000 rcx: 0x0000000000000006 rdx: 0x0000000000000006
      rdi: 0x00007ff1cb907e90 rsi: 0x00007ff1cb907e80 rbp: 0x00007ffeec2f94c0 rsp: 0x00007ffeec2f9490
      r8: 0x00007ffeec30059c r9: 0x0000000000000000 r10: 0x0000000000000002 r11: 0x0000000000000246
      r12: 0x0000000000000006 r13: 0x000000000000004e r14: 0x00007ff1cb907e90 r15: 0x00007ff1cb907e80
      rip: 0x0000000103b1f110 rfl: 0x0000000000010246 cr2: 0x0000000000000028
      Logical CPU: 15
      Error Code: 0x00000004 (no mapping for user data read)
      Trap Number: 14
      Binary Images:
      0x1038ec000 - 0x104111fff +com.Illustrate.dBpoweramp-Music-Converter (Release 17.2 - 1) <650E87E5-6B97-3C45-8A97-1AD8429EBCFF> /Applications/dBpoweramp Music Converter.app/Contents/MacOS/dBpoweramp Music Converter
      0x10a6f6000 - 0x10a787f47 dyld (750.6) <1D318D60-C9B0-3511-BE9C-82AFD2EF930D> /usr/lib/dyld
      0x7fff35310000 - 0x7fff3550bff8 com.apple.avfoundation (2.0 - 1855.3) <0837D912-3783-35D6-A94A-E474E18600CF> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
      0x7fff3550c000 - 0x7fff355d8ffe com.apple.audio.AVFAudio (1.0 - 415.75) <CAC3CA5F-FCF6-37EB-8F1A-090340E2C38E> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
      0x7fff356f8000 - 0x7fff356f8fff com.apple.Accelerate (1.11 - Accelerate 1.11) <4F9977AE-DBDB-3A16-A536-AC1F9938DCDD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
      0x7fff35710000 - 0x7fff35d66fff com.apple.vImage (8.1 - 524.2.1) <EA6F5FF2-7A1B-35D5-A5A3-D2B3386ECB75> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
      0x7fff35d67000 - 0x7fff35fceff7 libBLAS.dylib (1303.60.1) <C6C2D42F-7456-3DBF-8BE2-9AA06EFC78FD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
      0x7fff35fcf000 - 0x7fff364a2fef libBNNS.dylib (144.100.2) <99C61C48-B14C-3DA6-8C31-6BF72DA0A3A9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
      0x7fff364a3000 - 0x7fff3683efff libLAPACK.dylib (1303.60.1) <5E3E3867-50C3-3E6A-9A2E-007CE77A4641> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
      0x7fff3683f000 - 0x7fff36854fec libLinearAlgebra.dylib (1303.60.1) <3D433800-0099-33E0-8C81-15F83247B2C9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
      0x7fff36855000 - 0x7fff3685aff3 libQuadrature.dylib (7) <371F36A7-B12F-363E-8955-F24F7C2048F6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
      0x7fff3685b000 - 0x7fff368cbfff libSparse.dylib (103) <B8A10D0C-4577-343D-B310-A3E81265D107> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
      0x7fff368cc000 - 0x7fff368defef libSparseBLAS.dylib (1303.60.1) <B147FEF6-A0DB-3830-BF06-45BEC58DB576> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
      0x7fff368df000 - 0x7fff36ab6fd7 libvDSP.dylib (735.140.1) <D63DC0A5-B8B4-3562-A574-E73BC3B57407> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
      0x7fff36ab7000 - 0x7fff36b79fef libvMisc.dylib (735.140.1) <3601FDE3-B142-398D-987D-8151A51F0A96> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
      0x7fff36b7a000 - 0x7fff36b7afff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <F6C5613D-2284-342B-9160-9731F78B4DE5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
      0x7fff36b7b000 - 0x7fff36bdaff0 com.apple.Accounts (113 - 113) <E2438070-30AB-3B89-AE63-1E485B92D108> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
      0x7fff36d24000 - 0x7fff37ae4ff2 com.apple.AppKit (6.9 - 1894.60.100) <A64D10A6-FE17-39CE-9392-6615BE54E10E> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
      0x7fff37b34000 - 0x7fff37b34fff com.apple.ApplicationServices (48 - 50) <C23D2740-FAF6-3BD6-9E48-56F54D752864> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
      0x7fff37b35000 - 0x7fff37ba0fff com.apple.ApplicationServices.ATS (377 - 493.0.4.1) <87EA5DE1-506A-39FD-88BE-D8A3416C9012> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
      0x7fff37c39000 - 0x7fff37c77ff0 libFontRegistry.dylib (274.0.5.1) <F3461C05-0370-359B-9F03-5C1C1F7763EC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
      0x7fff37cd2000 - 0x7fff37d01fff com.apple.ATSUI (1.0 - 1) <5F513967-DDD7-3F22-AD14-8A38ABD9F2D0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATSUI.framework/Versions/A/ATSUI
      0x7fff37d02000 - 0x7fff37d06ffb com.apple.ColorSyncLegacy (4.13.0 - 1) <72EE68DB-F069-37F5-AA2A-40D5FCF139F4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
      0x7fff37da0000 - 0x7fff37df7ffa com.apple.HIServices (1.22 - 676) <14DF4D42-E24D-3EBD-9A9D-93124D8D6AA1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
      0x7fff37df8000 - 0x7fff37e06fff com.apple.LangAnalysis (1.7.0 - 1.7.0) <01B8B6B3-E2C3-3607-B34A-8283A7E0E924> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
      0x7fff37e07000 - 0x7fff37e4cffa com.apple.print.framework.PrintCore (15.4 - 516.2) <437BCF12-48D2-3770-8BC9-567718FB1BCA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
      0x7fff37e4d000 - 0x7fff37e57ff7 com.apple.QD (4.0 - 413) <27A36D07-B5E9-32E6-87B6-3127F260F48D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
      0x7fff37e58000 - 0x7fff37e65ffc com.apple.speech.synthesis.framework (9.0.24 - 9.0.24) <75344F8F-32CA-3558-B4E6-F56D498250E4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
      0x7fff37e66000 - 0x7fff37f47ffa com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <8CFA0620-5E43-3C4D-A75B-981C0961C2DE> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
      0x7fff37f49000 - 0x7fff37f49fff com.apple.audio.units.AudioUnit (1.14 - 1.14) <C8F9CC56-F7CF-3E77-B6FC-BD8E1D19FA92> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
      0x7fff382e0000 - 0x7fff3866fffa com.apple.CFNetwork (1128.0.1 - 1128.0.1) <07F9CA9C-B954-3EA0-A710-3122BFF9F057> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
      0x7fff386eb000 - 0x7fff386ebfff com.apple.Carbon (160 - 162) <97E334B3-7FAE-3239-9E89-5A546BC26ADE> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
      0x7fff386ec000 - 0x7fff386efff3 com.apple.CommonPanels (1.2.6 - 101) <9F6E13D9-374B-386F-8E15-FDD6CE967859> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
      0x7fff386f0000 - 0x7fff389e4ff3 com.apple.HIToolbox (2.1.1 - 994.6) <EAF2DAC3-66B1-30BF-AF10-72DDA90D1044> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
      0x7fff389e5000 - 0x7fff389e8ff3 com.apple.help (1.3.8 - 71) <36483951-6F3E-3F7E-8A5B-191C2357EF17> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
      0x7fff389e9000 - 0x7fff389eeff7 com.apple.ImageCapture (9.0 - 1600.65) <1A1F320E-3E85-3F3D-8AE0-B238C4E92D40> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
      0x7fff389ef000 - 0x7fff389effff com.apple.ink.framework (10.15 - 227) <284507AE-EF47-3ABC-86A4-669243DB1D33> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
      0x7fff389f0000 - 0x7fff38a0affa com.apple.openscripting (1.7 - 185.1) <B6E28747-5FC7-3461-8A71-864A969ED022> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
      0x7fff38a2b000 - 0x7fff38a2bfff com.apple.print.framework.Print (15 - 271) <0D9FB08F-EA87-3BE7-821B-C61BA5601050> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
      0x7fff38a2c000 - 0x7fff38a2eff7 com.apple.securityhi (9.0 - 55008) <390C6FAA-99BF-3924-9180-9EAE41D9C6BE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
      0x7fff38a2f000 - 0x7fff38a35fff com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <9614A01E-8303-3422-A3BA-6CE27540E09A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
      0x7fff38a36000 - 0x7fff38bceffa com.apple.cloudkit.CloudKit (867 - 867) <1B851180-FC00-357F-B6C1-BB0EA7D6D5CA> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
      0x7fff38bcf000 - 0x7fff38bcffff com.apple.Cocoa (6.11 - 23) <2192EE61-8CA8-3639-B7D3-0D68F200C9EF> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
      0x7fff38bdd000 - 0x7fff38cd3fff com.apple.ColorSync (4.13.0 - 3394.9) <A126406C-DA38-3FFE-8B25-BB9859EFD159> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
      0x7fff38fbe000 - 0x7fff394c7ffb com.apple.audio.CoreAudio (5.0 - 5.0) <9DA02E7A-56A0-3FFF-94C2-1795BA761F07> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
      0x7fff3951a000 - 0x7fff39552fff com.apple.CoreBluetooth (1.0 - 1) <23DBB313-A082-3C08-8E1F-2D31EE4247EF> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
      0x7fff39553000 - 0x7fff3993dfe8 com.apple.CoreData (120 - 977.3) <49AE61CA-C91E-31FE-9BD0-1AACFFB5181E> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
      0x7fff3993e000 - 0x7fff39a70ff6 com.apple.CoreDisplay (1.0 - 186.6.15) <213D7011-8180-3CF4-9BE7-FB8F75DCDB95> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
      0x7fff39a71000 - 0x7fff39ef0feb com.apple.CoreFoundation (6.9 - 1677.104) <C0D70026-EDBE-3CBD-B317-367CF4F1C92F> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
      0x7fff39ef2000 - 0x7fff3a567ff8 com.apple.CoreGraphics (2.0 - 1355.22) <4A3CDE7B-4578-3058-966A-3D1DC095A935> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
      0x7fff3a575000 - 0x7fff3a8d0ff0 com.apple.CoreImage (15.0.0 - 940.9) <69361069-01AB-342E-862B-73A74271A765> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
      0x7fff3a8d1000 - 0x7fff3a93aff0 com.apple.corelocation (2394.0.22 - 2394.0.22) <75966124-2FB7-33C3-BE49-3DD5F327F911> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
      0x7fff3a98e000 - 0x7fff3ac90ff2 com.apple.CoreML (1.0 - 1) <FD17F9EB-1930-314C-B6B4-2A2E643AC771> /System/Library/Frameworks/CoreML.framework/Versions/A/CoreML
      0x7fff3ac91000 - 0x7fff3ad6cffc com.apple.CoreMedia (1.0 - 2625.9) <A3FF3AFC-8C1C-36E5-9179-66D8F075EE35> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
      0x7fff3ad6d000 - 0x7fff3adcfffe com.apple.CoreMediaIO (1000.0 - 5125.6) <F8C046C7-4DA4-3987-A7CB-BAD12F0D2D22> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
      0x7fff3ae59000 - 0x7fff3ae59fff com.apple.CoreServices (1069.24 - 1069.24) <AA140158-E909-34C2-B2F5-20EBC93E0056> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
      0x7fff3ae5a000 - 0x7fff3aedffff com.apple.AE (838.1 - 838.1) <2E5FD5AE-8A7F-353F-9BD1-0241F3586181> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
      0x7fff3aee0000 - 0x7fff3b1c1ff7 com.apple.CoreServices.CarbonCore (1217 - 1217) <BE379206-99FA-30CD-8391-2708473A633F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
      0x7fff3b1c2000 - 0x7fff3b20fffd com.apple.DictionaryServices (1.2 - 323.6) <26B70C82-25BC-353A-858F-945B14C803A2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
      0x7fff3b210000 - 0x7fff3b218ff7 com.apple.CoreServices.FSEvents (1268.100.1 - 1268.100.1) <FC84DB48-A3CE-30F7-A918-B3587731ACC7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
      0x7fff3b219000 - 0x7fff3b453ff6 com.apple.LaunchServices (1069.24 - 1069.24) <9A5359D9-9148-3B18-B868-56A9DA5FB60C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
      0x7fff3b454000 - 0x7fff3b4ecff1 com.apple.Metadata (10.7.0 - 2076.7) <0973F7E5-D58C-3574-A3CE-4F12CAC2D4C7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
      0x7fff3b4ed000 - 0x7fff3b51afff com.apple.CoreServices.OSServices (1069.24 - 1069.24) <0E4F48AD-402C-3E9D-9CA9-6DD9479B28F9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
      0x7fff3b51b000 - 0x7fff3b582fff com.apple.SearchKit (1.4.1 - 1.4.1) <2C5E1D85-E8B1-3DC5-91B9-E3EDB48E9369> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
      0x7fff3b583000 - 0x7fff3b5a7ff5 com.apple.coreservices.SharedFileList (131.4 - 131.4) <02DE0D56-E371-3EF5-9BC1-FA435451B412> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
      0x7fff3b804000 - 0x7fff3b8cbffc com.apple.CoreTelephony (113 - 7560.1) <31D93EB1-0A20-3383-9680-090E441F25D8> /System/Library/Frameworks/CoreTelephony.framework/Versions/A/CoreTelephony
      0x7fff3b8cc000 - 0x7fff3ba83ffc com.apple.CoreText (643.1.5.1 - 643.1.5.1) <A88F052A-C840-3E6C-9BF8-FFFED34C0667> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
      0x7fff3ba84000 - 0x7fff3bac8ffb com.apple.CoreVideo (1.8 - 344.3) <5314E70D-325F-3E98-99FC-00FDF520747E> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
      0x7fff3bac9000 - 0x7fff3bb56ffc com.apple.framework.CoreWLAN (13.0 - 1601.2) <6223BFD5-D451-3DE9-90F6-F609AC0B0027> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
      0x7fff3bd1e000 - 0x7fff3bdc8ff0 com.apple.DiscRecording (9.0.3 - 9030.4.5) <BCF3AFB0-6E1A-3F28-A575-1FD2D74E7C19> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
      0x7fff3bdc9000 - 0x7fff3bdecfff com.apple.DiscRecordingUI (9.0.3 - 9030.4.5) <4B3B8217-86E5-3E4C-B1E4-DF66097F762C> /System/Library/Frameworks/DiscRecordingUI.framework/Versions/A/DiscRecordingUI
      0x7fff3bded000 - 0x7fff3bdf3fff com.apple.DiskArbitration (2.7 - 2.7) <0BBBB6A6-604D-368B-9943-50B8CE75D51D> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
      0x7fff3bfe8000 - 0x7fff3c116ff6 com.apple.FileProvider (304.1 - 304.1) <E8BB1D4B-05D6-386C-865C-F8C750CEC308> /System/Library/Frameworks/FileProvider.framework/Versions/A/FileProvider
      0x7fff3c12e000 - 0x7fff3c4f3fff com.apple.Foundation (6.9 - 1677.104) <7C69F845-F651-3193-8262-5938010EC67D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
      0x7fff3c560000 - 0x7fff3c5b0ff7 com.apple.GSS (4.0 - 2.0) <2F3A67E6-D42A-3CF0-9041-A42C22D46F95> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
      0x7fff3c6ed000 - 0x7fff3c801ff3 com.apple.Bluetooth (7.0.6 - 7.0.6f7) <CF9CEFBA-97AC-3474-93AF-863C2C74C645> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
      0x7fff3c867000 - 0x7fff3c90bff3 com.apple.framework.IOKit (2.0.2 - 1726.140.1) <14223387-6F81-3976-8605-4BC2F253A93E> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
      0x7fff3c90d000 - 0x7fff3c91effb com.apple.IOSurface (269.11 - 269.11) <BCD744D4-E17E-3C2E-B69C-F69C789892E9> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
      0x7fff3c93c000 - 0x7fff3c99cff5 com.apple.ImageCaptureCore (1.0 - 1600.65) <281CE141-B350-30E2-B345-FC7E7DF1AA3A> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
      0x7fff3c99d000 - 0x7fff3caf9ffe com.apple.ImageIO.framework (3.3.0 - 1976.11.1) <5DBAD721-B70E-396C-922C-A2742E6815D6> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
      0x7fff3cafa000 - 0x7fff3cafdfff libGIF.dylib (1976.11.1) <1A04BEC5-95CF-3EA4-8FA6-FE19679331F3> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
      0x7fff3cafe000 - 0x7fff3cbb7fe7 libJP2.dylib (1976.11.1) <686B045D-5627-3DEE-B018-72068B7136D4> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
      0x7fff3cbb8000 - 0x7fff3cbdbfe3 libJPEG.dylib (1976.11.1) <13EAEDD3-D4CF-3B2C-B7A4-FB000A71D982> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
      0x7fff3ce5a000 - 0x7fff3ce74fef libPng.dylib (1976.11.1) <031068A2-29E2-3BE0-93CC-76D154976A51> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
      0x7fff3ce75000 - 0x7fff3ce76fff libRadiance.dylib (1976.11.1) <6B5A0402-F511-39ED-933A-C361005107B1> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
      0x7fff3ce77000 - 0x7fff3cebdfff libTIFF.dylib (1976.11.1) <1F089EF9-3DCE-3B49-9B2B-28B9AC3252D0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
      0x7fff3ced6000 - 0x7fff3d365ff8 com.apple.Intents (1.0 - 1) <B2884C7F-0D08-3E3C-91A3-7FB755BB5CB1> /System/Library/Frameworks/Intents.framework/Versions/A/Intents
      0x7fff3d368000 - 0x7fff3e408ff1 com.apple.JavaScriptCore (15609 - 15609.4.1) <18766B97-AB12-331C-984C-F1C7C9363E8B> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
      0x7fff3e41f000 - 0x7fff3e431ff3 com.apple.Kerberos (3.0 - 1) <03BB492B-016E-37BF-B020-39C2CF7487FE> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
      0x7fff3e432000 - 0x7fff3e432fff libHeimdalProxy.dylib (77) <0A2905EE-9533-3345-AF9B-AAC71513BDFD> /System/Library/Frameworks/Kerberos.framework/Versions/A/Libraries/libHeimdalProxy.dylib
      0x7fff3e7c4000 - 0x7fff3e7ceffb com.apple.MediaAccessibility (1.0 - 125.1) <98065EA1-3484-3A5A-B05C-D2FABED8CEA4> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
      0x7fff3e89a000 - 0x7fff3efe7ff2 com.apple.MediaToolbox (1.0 - 2625.9) <3A848992-9182-382A-BF7D-5CB9707BE27B> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
      0x7fff3efe9000 - 0x7fff3f0b3fff com.apple.Metal (212.8 - 212.8) <98C944D6-62C8-355E-90F8-C1CA2429EF24> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
      0x7fff3f0b5000 - 0x7fff3f0cfff5 com.apple.MetalKit (141.2 - 141.2) <FAACD940-5CF2-300A-83F3-86ABA7FDC531> /System/Library/Frameworks/MetalKit.framework/Versions/A/MetalKit
      0x7fff3f0d0000 - 0x7fff3f10dff7 com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <7EBAC15D-7837-395D-B405-1E29F7DA68FA> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore
      0x7fff3f10e000 - 0x7fff3f198fe2 com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <B424FE0C-6E90-3BFA-A6E7-DD86C735AE90> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage
      0x7fff3f199000 - 0x7fff3f1beff4 com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <02006D92-E2AB-3892-A96B-37F6520C19BA> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
      0x7fff3f1bf000 - 0x7fff3f1d4ffb com.apple.MetalPerformanceShaders.MPSNDArray (1.0 - 1) <CAA5A368-DB71-34F6-AEF9-27A8BC298F53> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNDArray.framework/Versions/A/MPSNDArray
      0x7fff3f1d5000 - 0x7fff3f333ffc com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <05612E06-50CB-318F-9F8E-EF4D49FAB3B0> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
      0x7fff3f334000 - 0x7fff3f383ff4 com.apple.MetalPerformanceShaders.MPSRayIntersecto r (1.0 - 1) <B0B591F8-6875-351E-867F-8EB3CD38CD52> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector
      0x7fff3f384000 - 0x7fff3f385ff5 com.apple.MetalPerformanceShaders.MetalPerformance Shaders (1.0 - 1) <F2921F9A-3041-3495-878D-64134267B847> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
      0x7fff40414000 - 0x7fff40420ffe com.apple.NetFS (6.0 - 4.0) <4415F027-D36D-3B9C-96BA-AD22B44A4722> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
      0x7fff40421000 - 0x7fff40578ff3 com.apple.Network (1.0 - 1) <4A0F3B93-4D23-3E74-9A3D-AD19E9C0E59E> /System/Library/Frameworks/Network.framework/Versions/A/Network
      0x7fff40579000 - 0x7fff407d9ffa com.apple.NetworkExtension (1.0 - 1) <3ED35C5A-B170-373E-8277-D4198E408810> /System/Library/Frameworks/NetworkExtension.framework/Versions/A/NetworkExtension
      0x7fff42faa000 - 0x7fff43002fff com.apple.opencl (3.5 - 3.5) <293FE223-9186-320B-81A4-EC8104C38357> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
      0x7fff43003000 - 0x7fff4301ffff com.apple.CFOpenDirectory (10.15 - 220.40.1) <7E6C88EB-3DD9-32B0-81FC-179552834FA9> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
      0x7fff43020000 - 0x7fff4302bffd com.apple.OpenDirectory (10.15 - 220.40.1) <4A92D8D8-A9E5-3A9C-942F-28576F6BCDF5> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
      0x7fff43991000 - 0x7fff43993fff libCVMSPluginSupport.dylib (17.10.22) <2B6C3C16-3F5F-36A8-8070-2A862B90328B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
      0x7fff43994000 - 0x7fff43999fff libCoreFSCache.dylib (176.15) <E9A20E72-B17F-33D6-8894-41934A10B822> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
      0x7fff4399a000 - 0x7fff4399efff libCoreVMClient.dylib (176.15) <018A48BA-1326-3847-8FB5-A7C99322EB87> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
      0x7fff4399f000 - 0x7fff439a7ff7 libGFXShared.dylib (17.10.22) <AB47B927-65E3-3924-88BE-0A5BE7906785> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
      0x7fff439a8000 - 0x7fff439b2fff libGL.dylib (17.10.22) <FB5E6A75-398E-38EF-8CB2-59F5BFE3034C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
      0x7fff439b3000 - 0x7fff439e7ff7 libGLImage.dylib (17.10.22) <9A3FE633-61B8-3CC7-8183-62960109401A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
      0x7fff43b7d000 - 0x7fff43bb9fff libGLU.dylib (17.10.22) <D8B4D804-7323-30BC-871C-B7236FFC2FE3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
      0x7fff445f5000 - 0x7fff44604ff7 com.apple.opengl (17.10.22 - 17.10.22) <D3C57A32-6BD0-3228-B1C4-0F42A6128A6C> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
      0x7fff447b6000 - 0x7fff448a9ff5 com.apple.PDFKit (1.0 - 845.4.1) <A58B3E4C-6B27-32A7-AC6E-35BCB5A45944> /System/Library/Frameworks/PDFKit.framework/Versions/A/PDFKit
      0x7fff448aa000 - 0x7fff449c1ff9 com.apple.PencilKit (1.0 - 1) <95301D00-CE35-3F53-BAE1-6E6217706702> /System/Library/Frameworks/PencilKit.framework/Versions/A/PencilKit
      0x7fff44c62000 - 0x7fff44c68ff6 com.apple.PushKit (1.0 - 1) <AD547A25-1A0B-3FA6-8676-82C37F267A4A> /System/Library/Frameworks/PushKit.framework/Versions/A/PushKit
      0x7fff44d89000 - 0x7fff44fcfff7 com.apple.imageKit (3.0 - 1081) <5F086EE2-5745-3E28-B292-1DE5E0652E36> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
      0x7fff44fd0000 - 0x7fff4548ffff com.apple.QuartzComposer (5.1 - 378) <9C10ADF7-94B0-3779-AD44-5AF6394A32AF> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
      0x7fff45490000 - 0x7fff454b5ffc com.apple.quartzfilters (1.10.0 - Tag) <876E8B28-9500-34C6-B297-EA404D89C903> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
      0x7fff454b6000 - 0x7fff455c0ff7 com.apple.QuickLookUIFramework (5.0 - 906.3) <7128FB8C-83B0-3250-BF86-E8A1772CF1F5> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
      0x7fff455c1000 - 0x7fff455c1fff com.apple.quartzframework (1.5 - 23) <48F3D0F9-323E-34E5-8F63-CF541F2B7B0E> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
      0x7fff455c2000 - 0x7fff45845ffb com.apple.QuartzCore (1.11 - 841.4) <FE927B0E-BD49-32CC-8A55-90F553C86C15> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
      0x7fff45846000 - 0x7fff4589fff5 com.apple.QuickLookFramework (5.0 - 906.3) <959CE934-B541-3172-846F-4D1709353526> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
      0x7fff458a0000 - 0x7fff458d5ffc com.apple.QuickLookThumbnailing (1.0 - 1) <9CCB50D8-AA39-3744-93FB-7B5B65467AB3> /System/Library/Frameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThumbnailing
      0x7fff45da6000 - 0x7fff45dc0ff8 com.apple.SafariServices.framework (15610 - 15610.1.28.1.9) <AB93F2E5-1C7E-33AE-902E-51A06FADA48E> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
      0x7fff463c8000 - 0x7fff46711ff1 com.apple.security (7.0 - 59306.140.5) <B6F8368F-2395-379B-B768-71C53BB1B903> /System/Library/Frameworks/Security.framework/Versions/A/Security
      0x7fff46712000 - 0x7fff4679affb com.apple.securityfoundation (6.0 - 55236.60.1) <7C69DF47-4017-3DF2-B55B-712B481654CB> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
      0x7fff467c9000 - 0x7fff467cdff8 com.apple.xpc.ServiceManagement (1.0 - 1) <2C62956C-F2D4-3EB0-86C7-EAA06331621A> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
      0x7fff47479000 - 0x7fff474f3ff7 com.apple.SystemConfiguration (1.19 - 1.19) <84F9B3BB-F7AF-3B7C-8CD0-D3C22D19619F> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
      0x7fff47773000 - 0x7fff47af6ff4 com.apple.VideoToolbox (1.0 - 2625.9) <6CF18E28-A7A8-3952-8171-7E4FF4FB37FA> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
      0x7fff4b463000 - 0x7fff4b528fe7 com.apple.APFS (1412.141.1 - 1412.141.1) <C86A3423-E61C-335A-9D17-0B3CE5BB6467> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
      0x7fff4c63d000 - 0x7fff4c63eff1 com.apple.AggregateDictionary (1.0 - 1) <95A291F5-B69F-3C37-9483-C3B2EBF52AC1> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary
      0x7fff4ca8c000 - 0x7fff4cbd7ff5 com.apple.AnnotationKit (1.0 - 325.9) <9BB0EDB6-3808-30FC-B0ED-764DE5AAB893> /System/Library/PrivateFrameworks/AnnotationKit.framework/Versions/A/AnnotationKit
      0x7fff4cbd8000 - 0x7fff4cbf5ff4 com.apple.AppContainer (4.0 - 448.100.6) <87CEE13C-8585-3EFB-92CD-0852DFF0921B> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
      0x7fff4cc4a000 - 0x7fff4cc58ff7 com.apple.AppSandbox (4.0 - 448.100.6) <0F49AA04-3400-349A-9096-6D4D7ED61027> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
      0x7fff4d0d4000 - 0x7fff4d0f8ffb com.apple.framework.Apple80211 (13.0 - 1610.1) <D94E03E8-4C38-3B2F-8DF4-473ACC5A7D71> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
      0x7fff4d3b6000 - 0x7fff4d3c5fd7 com.apple.AppleFSCompression (119.100.1 - 1.0) <466ABD77-2E52-36D1-8E39-77AE2CC61611> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
      0x7fff4d4c4000 - 0x7fff4d4cfff7 com.apple.AppleIDAuthSupport (1.0 - 1) <74F6CD9C-27A7-39C7-A7EB-47E60D2517EB> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
      0x7fff4d511000 - 0x7fff4d559ff7 com.apple.AppleJPEG (1.0 - 1) <6DE30A07-C627-319B-A0DE-EB7A832BEB88> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
      0x7fff4d91c000 - 0x7fff4d942ffb com.apple.aps.framework (4.0 - 4.0) <3ED300B6-43E3-31DC-B3C6-6A0FF41A2595> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
      0x7fff4d943000 - 0x7fff4d947ff7 com.apple.AppleSRP (5.0 - 1) <70C25EA9-F7A7-366C-97C6-EEE7845FFCC3> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
      0x7fff4d948000 - 0x7fff4d96afff com.apple.applesauce (1.0 - 16.25) <68E0364C-AEA7-3654-A030-136BF3CD92F3> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
      0x7fff4da29000 - 0x7fff4da2cfff com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <67255151-F989-39F0-BC87-0C0BDAE70730> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
      0x7fff4da2d000 - 0x7fff4da7dff7 com.apple.AppleVAFramework (6.1.2 - 6.1.2) <8E18983B-AF92-3853-8251-A6577A55AC15> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
      0x7fff4dac6000 - 0x7fff4dad5ff9 com.apple.AssertionServices (1.0 - 223.140.2) <48AD21CA-B81D-380E-A04F-90C48FDA5203> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices
      0x7fff4e018000 - 0x7fff4e413ff8 com.apple.audio.AudioResourceArbitration (1.0 - 1) <2BD68521-C19C-3D67-B5EB-DE3E9A4DAF0A> /System/Library/PrivateFrameworks/AudioResourceArbitration.framework/Versions/A/AudioResourceArbitration
      0x7fff4e669000 - 0x7fff4e8a9fe0 com.apple.audio.AudioToolboxCore (1.0 - 1104.93) <5B539F50-93E8-3F73-9E4C-678C85D0488F> /System/Library/PrivateFrameworks/AudioToolboxCore.framework/Versions/A/AudioToolboxCore
      0x7fff4e8ad000 - 0x7fff4e9c9fff com.apple.AuthKit (1.0 - 1) <DC1A27C5-0172-3C72-9B24-06996D0B6207> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
      0x7fff4eb86000 - 0x7fff4eb8fff7 com.apple.coreservices.BackgroundTaskManagement (1.0 - 104) <A6877DAD-8F47-363C-983A-DC8DDE83B7B5> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
      0x7fff4eb90000 - 0x7fff4ec31ff5 com.apple.backup.framework (1.11.6 - 1298.6.2) <C4BC12A3-4D01-377F-A1DB-7E1490831CF2> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
      0x7fff4ec32000 - 0x7fff4ecbeff6 com.apple.BaseBoard (466.3 - 466.3) <10D0F3BB-E8F3-365E-8528-6AC996A9B0E7> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
      0x7fff4edc0000 - 0x7fff4edfcff7 com.apple.bom (14.0 - 219.2) <79CBE5E7-054F-377B-9566-A86A9F120CF1> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
      0x7fff4ef1a000 - 0x7fff4ef51ff5 com.apple.C2 (1.3 - 495) <4A7E2A63-E19A-3936-92F5-03F2FD602172> /System/Library/PrivateFrameworks/C2.framework/Versions/A/C2
      0x7fff4f97c000 - 0x7fff4f9cbfff com.apple.ChunkingLibrary (307 - 307) <5B09C30D-FD2B-3E98-8B64-C5EF470FC13C> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
      0x7fff50877000 - 0x7fff50887ffb com.apple.CommonAuth (4.0 - 2.0) <CF67FF34-4238-3ECA-B4A4-EA04F18A0D36> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
      0x7fff5089b000 - 0x7fff508b2fff com.apple.commonutilities (8.0 - 900) <F4C97244-E5D8-3F7D-8D94-4B6841C5A4EC> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
      0x7fff50fb9000 - 0x7fff5138efc8 com.apple.CoreAUC (283.0.0 - 283.0.0) <4341271C-D270-3F9F-8464-31A20D15158D> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
      0x7fff5138f000 - 0x7fff513bcff7 com.apple.CoreAVCHD (6.1.0 - 6100.4.1) <C3CFDC68-C7D9-3C44-9E7C-801D45575C10> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
      0x7fff513df000 - 0x7fff51400ff4 com.apple.analyticsd (1.0 - 1) <95A87174-A616-3F80-B17A-1FA7E3DB7C09> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics
      0x7fff51509000 - 0x7fff5157fff7 com.apple.corebrightness (1.0 - 1) <692194CE-AF03-30D2-B1B8-7C0D2103A2B4> /System/Library/PrivateFrameworks/CoreBrightness.framework/Versions/A/CoreBrightness
      0x7fff5170b000 - 0x7fff51716ff7 com.apple.frameworks.CoreDaemon (1.3 - 1.3) <BB7D67B1-2102-3D71-9BB6-AEB8C6A6EBB2> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
      0x7fff51717000 - 0x7fff51922ff1 com.apple.CoreDuet (1.0 - 1) <F899F217-FC31-3140-A0EB-92EAD22EEF71> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
      0x7fff51923000 - 0x7fff51970ff3 com.apple.coreduetcontext (1.0 - 1) <72341E86-6921-35FE-89CA-7B04725ECC0F> /System/Library/PrivateFrameworks/CoreDuetContext.framework/Versions/A/CoreDuetContext
      0x7fff51971000 - 0x7fff51981ffe com.apple.CoreDuetDaemonProtocol (1.0 - 1) <5E31B761-4B30-39A8-9084-97ECFD268B6F> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDaemonProtocol
      0x7fff51984000 - 0x7fff51986fff com.apple.CoreDuetDebugLogging (1.0 - 1) <6D0113DB-61D8-3A21-95CB-9E30D8F929F9> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebugLogging
      0x7fff51997000 - 0x7fff519a7ff3 com.apple.CoreEmoji (1.0 - 107.1) <7C2B3259-083B-31B8-BCDB-1BA360529936> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
      0x7fff51b5d000 - 0x7fff51caafff com.apple.CoreHandwriting (161 - 1.2) <21DAD964-51A7-3F38-9C91-EF46C0CFF12D> /System/Library/PrivateFrameworks/CoreHandwriting.framework/Versions/A/CoreHandwriting
      0x7fff51fe7000 - 0x7fff52051ff0 com.apple.CoreNLP (1.0 - 213) <E70E2505-8078-324E-BAE1-01A2DA980E2C> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
      0x7fff52314000 - 0x7fff5239cffe com.apple.CorePDF (4.0 - 518.4.1) <8F94505C-96C2-3694-BEC7-F3B5581A7AB9> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
      0x7fff5247f000 - 0x7fff52487ff8 com.apple.CorePhoneNumbers (1.0 - 1) <E4DAD514-0B3B-3E0B-8AEA-39B320FAAF03> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
      0x7fff52e74000 - 0x7fff52e97fff com.apple.CoreSVG (1.0 - 129.3) <F38189F9-C8F9-3D62-9D5F-3F520FB81724> /System/Library/PrivateFrameworks/CoreSVG.framework/Versions/A/CoreSVG
      0x7fff52ecc000 - 0x7fff52efaffd com.apple.CSStore (1069.24 - 1069.24) <C2D67667-FA0B-3DB6-AA34-6999EE4346A0> /System/Library/PrivateFrameworks/CoreServicesStore.framework/Versions/A/CoreServicesStore
      0x7fff5341f000 - 0x7fff534b5ff7 com.apple.CoreSymbolication (11.4 - 64535.33.2) <0B3BF87A-7F95-3D79-B4F8-421D6FAC4A6C> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
      0x7fff5354d000 - 0x7fff53679ff6 com.apple.coreui (2.1 - 609.4) <788818B7-7EBC-316D-9464-D12E365E3791> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
      0x7fff5367a000 - 0x7fff53833ffa com.apple.CoreUtils (6.2.4 - 624.7) <A74A1C65-6695-3F57-B703-0DEDE13E66C1> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
      0x7fff5396d000 - 0x7fff53980ff1 com.apple.CrashReporterSupport (10.13 - 15016) <ADF138F0-0274-3BA2-A1D2-48B91577FE53> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
      0x7fff53a39000 - 0x7fff53a4bff8 com.apple.framework.DFRFoundation (1.0 - 252.50.1) <8162057E-E856-3451-9160-04AEDDECFFA4> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
      0x7fff53a4c000 - 0x7fff53a51fff com.apple.DSExternalDisplay (3.1 - 380) <31ECB5FD-7660-33DB-BC5B-2B2A2AA7C686> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
      0x7fff53adb000 - 0x7fff53b55ff0 com.apple.datadetectorscore (8.0 - 659) <B1534796-1000-3520-A641-A97A4AC5D39B> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
      0x7fff53ba1000 - 0x7fff53bdeff8 com.apple.DebugSymbols (194 - 194) <040AE30B-CF2C-3798-A289-0929B8CAB10D> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
      0x7fff53bdf000 - 0x7fff53d67ff6 com.apple.desktopservices (1.14.5 - 1281.5.3) <BFA7D5B5-20EE-38E3-B8A7-96CE1F9BB48A> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
      0x7fff540df000 - 0x7fff541b2ff1 com.apple.DiskManagement (13.0 - 1648.140.2) <640DBACE-B6EC-3C72-9F73-F484E891534E> /System/Library/PrivateFrameworks/DiskManagement.framework/Versions/A/DiskManagement
      0x7fff541b3000 - 0x7fff541b7ff1 com.apple.DisplayServicesFW (3.1 - 380) <4D71ADB3-B29D-3D20-B6DE-9E94061F86AC> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
      0x7fff54211000 - 0x7fff54235ff7 com.apple.DuetActivityScheduler (1.0 - 1) <188C6793-A94C-3B49-A9F4-AF8A348C7E62> /System/Library/PrivateFrameworks/DuetActivityScheduler.framework/Versions/A/DuetActivityScheduler
      0x7fff5425f000 - 0x7fff54294ff7 com.apple.SystemConfiguration.EAP8021X (14.0.0 - 14.0) <D3F76E01-2F9F-33E1-B5C9-CAC6E01724C2> /System/Library/PrivateFrameworks/EAP8021X.framework/Versions/A/EAP8021X
      0x7fff54295000 - 0x7fff54299ff9 com.apple.EFILogin (2.0 - 2) <3BFE697B-469F-38F4-B380-4A4F4A37C836> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
      0x7fff54de3000 - 0x7fff5544dff9 com.apple.vision.EspressoFramework (1.0 - 188.4) <70B1521B-1B24-3DA4-A41B-E727CF140F1F> /System/Library/PrivateFrameworks/Espresso.framework/Versions/A/Espresso
      0x7fff55728000 - 0x7fff55b43ff1 com.apple.vision.FaceCore (4.3.0 - 4.3.0) <5D32F65D-2CD7-3204-975C-F4C9256E505F> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
      0x7fff561e2000 - 0x7fff56319ff4 libFontParser.dylib (277.2.6.1) <9E9E2EAA-3273-360E-A01B-EB986ECB7BCF> /System/Library/PrivateFrameworks/FontServices.framework/libFontParser.dylib
      0x7fff563b3000 - 0x7fff563c3ff6 libhvf.dylib (1.0 - $[CURRENT_PROJECT_VERSION]) <1605B441-08E0-332D-B7D8-0E13F37B54E7> /System/Library/PrivateFrameworks/FontServices.framework/libhvf.dylib
      0x7fff5af5f000 - 0x7fff5af65fff com.apple.GPUWrangler (5.2.6 - 5.2.6) <487F2E7A-A5FF-3C36-A8E9-B85D98618116> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
      0x7fff5b284000 - 0x7fff5b2aaff1 com.apple.GenerationalStorage (2.0 - 314) <54483E50-20BB-3AF8-900F-992320C109B0> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
      0x7fff5b2c3000 - 0x7fff5c2acff1 com.apple.GeoServices (1.0 - 1624.26.4.26.9) <F735575F-7DEF-3202-9151-589BEB162596> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
      0x7fff5c3d8000 - 0x7fff5c3e6ffb com.apple.GraphVisualizer (1.0 - 100.1) <507D5812-9CB4-3C94-938C-59ED2B370818> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
      0x7fff5c44f000 - 0x7fff5c45cff9 com.apple.HID (1.0 - 1) <932CFF6F-71D1-3BBC-A784-559E0380D377> /System/Library/PrivateFrameworks/HID.framework/Versions/A/HID
      0x7fff5c585000 - 0x7fff5c643ff4 com.apple.Heimdal (4.0 - 2.0) <B86FE9DB-71BB-3B6E-A4AE-2B0B44570A7F> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
      0x7fff5e7c9000 - 0x7fff5e7d1ff5 com.apple.IOAccelerator (438.7.3 - 438.7.3) <06E3E70B-C0D0-39A2-96B7-12ED6A0EBEE7> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
      0x7fff5e7de000 - 0x7fff5e7f5fff com.apple.IOPresentment (47.10 - 37) <32F1B3BC-4644-3982-AAB2-8EB5D5FF0161> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
      0x7fff5eb7d000 - 0x7fff5ebc8ff1 com.apple.IconServices (438.3 - 438.3) <0DADB4C3-46FF-3FDB-8A86-51E2067FC7F4> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
      0x7fff5ed65000 - 0x7fff5ed73fff com.apple.IntentsFoundation (1.0 - 1) <1BC7D355-E136-391A-8215-6982742645DD> /System/Library/PrivateFrameworks/IntentsFoundation.framework/Versions/A/IntentsFoundation
      0x7fff5ed86000 - 0x7fff5ed8dff9 com.apple.InternationalSupport (1.0 - 45.4) <8D8D4A7D-FD35-36B8-A456-7C93030EDAB3> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
      0x7fff5f01a000 - 0x7fff5f039ffd com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <6F655A32-F963-3A7E-B475-E460F4AC7D99> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
      0x7fff5f16e000 - 0x7fff5f23cffd com.apple.LanguageModeling (1.0 - 215.1) <C456087D-5B3A-390E-A665-862FA284C59C> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
      0x7fff5f23d000 - 0x7fff5f285fff com.apple.Lexicon-framework (1.0 - 72) <41F208B9-8255-3EC7-9673-FE0925D071D3> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
      0x7fff5f28c000 - 0x7fff5f291ff3 com.apple.LinguisticData (1.0 - 353.18) <3B92F249-4602-325F-984B-D2DE61EEE4E1> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
      0x7fff5f2b8000 - 0x7fff5f2dcffe com.apple.locationsupport (2394.0.22 - 2394.0.22) <CA6C86FD-051A-31BB-B3AF-3D02D6FD94B6> /System/Library/PrivateFrameworks/LocationSupport.framework/Versions/A/LocationSupport
      0x7fff5fb2a000 - 0x7fff5fb2dfff com.apple.Mangrove (1.0 - 25) <482F300F-9B70-351F-A4DF-B440EEF7368D> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
      0x7fff5fceb000 - 0x7fff5fd11ffc com.apple.MarkupUI (1.0 - 325.9) <A596E8D7-6DBD-3F01-89AD-B296C9D3B61E> /System/Library/PrivateFrameworks/MarkupUI.framework/Versions/A/MarkupUI
      0x7fff5fd96000 - 0x7fff5fe20ff8 com.apple.MediaExperience (1.0 - 1) <0203AF27-AB5E-32FA-B529-AB7F29EEB887> /System/Library/PrivateFrameworks/MediaExperience.framework/Versions/A/MediaExperience
      0x7fff5fe21000 - 0x7fff5fe54fff com.apple.MediaKit (16 - 923) <09FEE738-41E4-3A9C-AF1E-1DD00C56339D> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
      0x7fff605fa000 - 0x7fff60646fff com.apple.spotlight.metadata.utilities (1.0 - 2076.7) <0237323B-EC78-3FBF-9FC7-5A1FE2B5CE25> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
      0x7fff60647000 - 0x7fff60718ffa com.apple.gpusw.MetalTools (1.0 - 1) <99876E08-37D7-3828-8796-56D90C9AFBDB> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
      0x7fff6094c000 - 0x7fff6096afff com.apple.MobileKeyBag (2.0 - 1.0) <D5FA7041-297F-3ADC-8C7A-6EAAAB82EB68> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
      0x7fff60a36000 - 0x7fff60bccffd com.apple.Montreal (1.0 - 121.1) <E7881020-FCA6-3DFC-B0EB-9E539F80E821> /System/Library/PrivateFrameworks/Montreal.framework/Versions/A/Montreal
      0x7fff60bcd000 - 0x7fff60bfdff7 com.apple.MultitouchSupport.framework (3440.1 - 3440.1) <6794E1C8-9627-33DF-84F4-FDD02C97F383> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
      0x7fff610fd000 - 0x7fff61107fff com.apple.NetAuth (6.2 - 6.2) <B0C03C41-87A3-352B-B130-96E1A6F94B47> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
      0x7fff61b1d000 - 0x7fff61b68ffb com.apple.OTSVG (1.0 - 643.1.5.1) <001E5E8C-1DC0-3A6E-BDE4-1B7887E47F76> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
      0x7fff62d85000 - 0x7fff62d90ff2 com.apple.PerformanceAnalysis (1.243.2 - 243.2) <B47C00E5-ECC2-313D-93D4-DBDF562C48EF> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
      0x7fff62d91000 - 0x7fff62db9ffb com.apple.persistentconnection (1.0 - 1.0) <5B2D87A8-2641-3F6D-ACEA-96B00F85AAB5> /System/Library/PrivateFrameworks/PersistentConnection.framework/Versions/A/PersistentConnection
      0x7fff64834000 - 0x7fff64864ff7 com.apple.pluginkit.framework (1.0 - 1) <EFBD7FE7-02CC-3E30-999D-B036F252F805> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit
      0x7fff6488f000 - 0x7fff648a2ffc com.apple.PowerLog (1.0 - 1) <FAD6E2DC-8C9D-38A0-9CB1-75F48473A3E2> /System/Library/PrivateFrameworks/PowerLog.framework/Versions/A/PowerLog
      0x7fff6571e000 - 0x7fff65778ff6 com.apple.ProtectedCloudStorage (1.0 - 1) <6F271388-3817-336D-9B96-08C7AAC4BA39> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
      0x7fff65779000 - 0x7fff65792ffb com.apple.ProtocolBuffer (1 - 274.24.9.16.3) <5A020941-C43C-303E-8DE8-230FC6A84DBC> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
      0x7fff658a4000 - 0x7fff658a7ff4 com.apple.QuickLookNonBaseSystem (1.0 - 1) <8563CD18-DCFE-3868-912F-053FC8C34B9C> /System/Library/PrivateFrameworks/QuickLookNonBaseSystem.framework/Versions/A/QuickLookNonBaseSystem
      0x7fff658a8000 - 0x7fff658cbff0 com.apple.quicklook.QuickLookSupport (1.0 - 1) <AFB0DFCC-6580-30E5-8984-831985F37A2C> /System/Library/PrivateFrameworks/QuickLookSupport.framework/Versions/A/QuickLookSupport
      0x7fff65912000 - 0x7fff6598bff3 com.apple.Rapport (1.9.5 - 195.2) <AF01D899-3BF9-3586-860A-D95A837101DF> /System/Library/PrivateFrameworks/Rapport.framework/Versions/A/Rapport
      0x7fff65bf2000 - 0x7fff65c1bff1 com.apple.RemoteViewServices (2.0 - 148) <D3AAC2BE-3423-3F18-9654-E35F1DD8DDB3> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
      0x7fff65d80000 - 0x7fff65dbbff0 com.apple.RunningBoardServices (1.0 - 223.140.2) <96BB04BD-D6E0-3D70-8F36-89B46DA1DA30> /System/Library/PrivateFrameworks/RunningBoardServices.framework/Versions/A/RunningBoardServices
      0x7fff6769c000 - 0x7fff6769fff5 com.apple.SecCodeWrapper (4.0 - 448.100.6) <C4BF691D-A09E-37E8-A6CC-1145B79B8722> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
      0x7fff67812000 - 0x7fff67939fff com.apple.Sharing (1526.37 - 1526.37) <CBDA0ADD-F1E7-3B06-9118-C5E183F0D3D6> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
      0x7fff679b1000 - 0x7fff679d1ff5 com.apple.sidecar-core (1.0 - 209.40.4) <469E5222-A5C7-3B09-B617-EDB6E9E46B93> /System/Library/PrivateFrameworks/SidecarCore.framework/Versions/A/SidecarCore
      0x7fff679d2000 - 0x7fff679e4ff0 com.apple.sidecar-ui (1.0 - 209.40.4) <5CA517E3-4B92-30B1-96EF-77A7A2FBBEE4> /System/Library/PrivateFrameworks/SidecarUI.framework/Versions/A/SidecarUI
      0x7fff68d4e000 - 0x7fff69044ff7 com.apple.SkyLight (1.600.0 - 451.4) <A24929C3-95E6-35A7-9654-46FF3F4D1E80> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
      0x7fff69891000 - 0x7fff6989fffb com.apple.SpeechRecognitionCore (6.0.91.2 - 6.0.91.2) <4D6CAC2A-151B-3BBE-BDB7-E2BE72128691> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
      0x7fff6a0d3000 - 0x7fff6a0dcff7 com.apple.SymptomDiagnosticReporter (1.0 - 1238.120.1) <14929A5D-C369-3B46-844B-CD29A3D1A015> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter
      0x7fff6a393000 - 0x7fff6a3a3ff3 com.apple.TCC (1.0 - 1) <017AB27D-6821-303A-8FD2-6DAC795CC7AA> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
      0x7fff6a8c8000 - 0x7fff6a98eff0 com.apple.TextureIO (3.10.9 - 3.10.9) <EEDAB753-329A-396A-8119-5BEDF7DB5A56> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
      0x7fff6ab5e000 - 0x7fff6adb6ff0 com.apple.UIFoundation (1.0 - 662) <EC55B9E5-7E62-380A-9AB1-FC7BEF663653> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
      0x7fff6ae4d000 - 0x7fff6ae53ffe com.apple.URLFormatting (119 - 119.18) <7F99D166-86DC-3F77-A34A-2DA7183D7160> /System/Library/PrivateFrameworks/URLFormatting.framework/Versions/A/URLFormatting
      0x7fff6ba2c000 - 0x7fff6ba4cffc com.apple.UserManagement (1.0 - 1) <9F00880E-6EA6-3684-B208-455E14EC07C8> /System/Library/PrivateFrameworks/UserManagement.framework/Versions/A/UserManagement
      0x7fff6c7f8000 - 0x7fff6c8e2ff8 com.apple.ViewBridge (464.1 - 464.1) <25CE39DF-2052-3873-9113-DB52B385C4BB> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
      0x7fff6ca88000 - 0x7fff6ca89fff com.apple.WatchdogClient.framework (1.0 - 67.120.2) <FFA17DA1-F6DD-34D3-A708-1F73C8BA7EA7> /System/Library/PrivateFrameworks/WatchdogClient.framework/Versions/A/WatchdogClient
      0x7fff6d6b9000 - 0x7fff6d6bcffa com.apple.dt.XCTTargetBootstrap (1.0 - 16091) <D459D628-58C5-39A6-B7E8-B691CBEECEC1> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap
      0x7fff6d736000 - 0x7fff6d744ff5 com.apple.audio.caulk (1.0 - 32.3) <06D695EA-E2BC-31E4-9816-9C12542BA744> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
      0x7fff6da86000 - 0x7fff6da88ff3 com.apple.loginsupport (1.0 - 1) <12F77885-27DC-3837-9CE9-A25EBA75F833> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
      0x7fff6dace000 - 0x7fff6dadaffd com.apple.perfdata (1.0 - 51.100.6) <21760CFD-62FF-3466-B3AD-191D02411DA0> /System/Library/PrivateFrameworks/perfdata.framework/Versions/A/perfdata
      0x7fff7055f000 - 0x7fff7056bff9 libAudioStatistics.dylib (1104.93) <42CAC6A2-BCC3-391B-B1C1-D0AC69E99CF4> /usr/lib/libAudioStatistics.dylib
      0x7fff7056c000 - 0x7fff7059fffa libAudioToolboxUtility.dylib (1104.93) <A7249C4C-6C0A-3C14-BA27-DC966F6CC6A0> /usr/lib/libAudioToolboxUtility.dylib
      0x7fff705a6000 - 0x7fff705dafff libCRFSuite.dylib (48) <5E5DE3CB-30DD-34DC-AEF8-FE8536A85E96> /usr/lib/libCRFSuite.dylib
      0x7fff705dd000 - 0x7fff705e7fff libChineseTokenizer.dylib (34) <7F0DA183-1796-315A-B44A-2C234C7C50BE> /usr/lib/libChineseTokenizer.dylib
      0x7fff705e8000 - 0x7fff70670fff libCoreStorage.dylib (551) <A457B0FE-D77F-30AA-99A4-70F6A98DFE59> /usr/lib/libCoreStorage.dylib
      0x7fff70673000 - 0x7fff70675ff7 libDiagnosticMessagesClient.dylib (112) <C94F3B7B-1854-38EB-9778-834501C53B3F> /usr/lib/libDiagnosticMessagesClient.dylib
      0x7fff706bb000 - 0x7fff70872ffb libFosl_dynamic.dylib (100.4) <737573B2-190A-3BA1-8220-807AD0A2CE5E> /usr/lib/libFosl_dynamic.dylib
      0x7fff70899000 - 0x7fff7089fff3 libIOReport.dylib (54) <75D177C4-BAD7-3285-B8E1-3019F49B3178> /usr/lib/libIOReport.dylib
      0x7fff70981000 - 0x7fff70988fff libMatch.1.dylib (36) <5C6F3971-9D9E-3630-BDB6-60BFC5A665E0> /usr/lib/libMatch.1.dylib
      0x7fff709b7000 - 0x7fff709d7ff7 libMobileGestalt.dylib (826.140.5) <2BE94E6A-FA61-312F-84A1-F764D71B7E39> /usr/lib/libMobileGestalt.dylib
      0x7fff70a57000 - 0x7fff70b34ff7 libSMC.dylib (20) <5C9C17F2-1E6F-3A19-A440-86F74D82284F> /usr/lib/libSMC.dylib
      0x7fff70b49000 - 0x7fff70b4afff libSystem.B.dylib (1281.100.1) <0A6C8BA1-30FD-3D10-83FD-FF29E221AFFE> /usr/lib/libSystem.B.dylib
      0x7fff70b4b000 - 0x7fff70bd6ff7 libTelephonyUtilDynamic.dylib (5017.1) <174030B2-E35F-3F17-A9EF-DF8631F30CCF> /usr/lib/libTelephonyUtilDynamic.dylib
      0x7fff70bd7000 - 0x7fff70bd8fff libThaiTokenizer.dylib (3) <4F4ADE99-0D09-3223-B7C0-C407AB6DE8DC> /usr/lib/libThaiTokenizer.dylib
      0x7fff70bf0000 - 0x7fff70c06fff libapple_nghttp2.dylib (1.39.2) <07FEC48A-87CF-32A3-8194-FA70B361713A> /usr/lib/libapple_nghttp2.dylib
      0x7fff70c3b000 - 0x7fff70cadff7 libarchive.2.dylib (72.140.1) <AC311FBA-F2DD-3595-AA76-769F912942B8> /usr/lib/libarchive.2.dylib
      0x7fff70cae000 - 0x7fff70d47fe5 libate.dylib (3.0.1) <76EA60FB-748C-313F-8951-B076540BEA97> /usr/lib/libate.dylib
      0x7fff70d4b000 - 0x7fff70d4bff3 libauto.dylib (187) <B6124448-7690-34AE-8939-ED84AAC630CE> /usr/lib/libauto.dylib
      0x7fff70e11000 - 0x7fff70e21ffb libbsm.0.dylib (60.100.1) <00BFFB9A-2FFE-3C24-896A-251BC61917FD> /usr/lib/libbsm.0.dylib
      0x7fff70e22000 - 0x7fff70e2efff libbz2.1.0.dylib (44) <14CC4988-B6D4-3879-AFC2-9A0DDC6388DE> /usr/lib/libbz2.1.0.dylib
      0x7fff70e2f000 - 0x7fff70e81fff libc++.1.dylib (902.1) <59A8239F-C28A-3B59-B8FA-11340DC85EDC> /usr/lib/libc++.1.dylib
      0x7fff70e82000 - 0x7fff70e97ffb libc++abi.dylib (902) <E692F14F-C65E-303B-9921-BB7E97D77855> /usr/lib/libc++abi.dylib
      0x7fff70e98000 - 0x7fff70e98fff libcharset.1.dylib (59) <72447768-9244-39AB-8E79-2FA14EC0AD33> /usr/lib/libcharset.1.dylib
      0x7fff70e99000 - 0x7fff70eaafff libcmph.dylib (8) <E72A20DB-2E86-378D-A237-EB9A1370F989> /usr/lib/libcmph.dylib
      0x7fff70eab000 - 0x7fff70ec2fd7 libcompression.dylib (87) <64C91066-586D-38C0-A2F3-3E60A940F859> /usr/lib/libcompression.dylib
      0x7fff7119c000 - 0x7fff711b2ff7 libcoretls.dylib (167) <770A5B96-936E-34E3-B006-B1CEC299B5A5> /usr/lib/libcoretls.dylib
      0x7fff711b3000 - 0x7fff711b4fff libcoretls_cfhelpers.dylib (167) <940BF370-FD0C-30A8-AA05-FF48DA44FA4C> /usr/lib/libcoretls_cfhelpers.dylib
      0x7fff7175e000 - 0x7fff71769fff libcsfde.dylib (551) <CEE22AEF-4E77-36B1-B007-00303819965F> /usr/lib/libcsfde.dylib
      0x7fff71771000 - 0x7fff717d0ff7 libcups.2.dylib (483.6) <C88D78FE-D238-376C-B16A-39270E39A79D> /usr/lib/libcups.2.dylib
      0x7fff718da000 - 0x7fff718dafff libenergytrace.dylib (21) <162DFCC0-8F48-3DD0-914F-FA8653E27B26> /usr/lib/libenergytrace.dylib
      0x7fff718db000 - 0x7fff718f3fff libexpat.1.dylib (19.60.2) <FED7C38B-92D8-342D-AED7-871B12D1F7E7> /usr/lib/libexpat.1.dylib
      0x7fff71901000 - 0x7fff71903fff libfakelink.dylib (149.1) <36146CB2-E6A5-37BB-9EE8-1B4034D8F3AD> /usr/lib/libfakelink.dylib
      0x7fff71912000 - 0x7fff71917fff libgermantok.dylib (24) <D2AE5AC0-EDCE-3216-B8C9-CF59292A545F> /usr/lib/libgermantok.dylib
      0x7fff71918000 - 0x7fff71921ff7 libheimdal-asn1.dylib (564.140.1) <0AC6FB62-2B0F-3E93-A931-E4DC4B1D757A> /usr/lib/libheimdal-asn1.dylib
      0x7fff71922000 - 0x7fff71a12fff libiconv.2.dylib (59) <18311A67-E4EF-3CC7-95B3-C0EDEE3A282F> /usr/lib/libiconv.2.dylib
      0x7fff71a13000 - 0x7fff71c6afff libicucore.A.dylib (64260.0.1) <8AC2CB07-E7E0-340D-A849-186FA1F27251> /usr/lib/libicucore.A.dylib
      0x7fff71c84000 - 0x7fff71c85fff liblangid.dylib (133) <30CFC08C-EF36-3CF5-8AEA-C1CB070306B7> /usr/lib/liblangid.dylib
      0x7fff71c86000 - 0x7fff71c9eff3 liblzma.5.dylib (16) <C131EF18-2CDD-3271-8A30-A8760D4FE166> /usr/lib/liblzma.5.dylib
      0x7fff71cb6000 - 0x7fff71d5dff7 libmecab.dylib (883.11) <0D5BFD01-D4A7-3C8D-AA69-C329C1A69792> /usr/lib/libmecab.dylib
      0x7fff71d5e000 - 0x7fff71fc0ff1 libmecabra.dylib (883.11) <E31DE74D-1B88-377F-ACD3-D789D29C3AE7> /usr/lib/libmecabra.dylib
      0x7fff7232d000 - 0x7fff7235cfff libncurses.5.4.dylib (57) <995DFEEA-40F3-377F-B73D-D02AC59D591F> /usr/lib/libncurses.5.4.dylib
      0x7fff7248c000 - 0x7fff72908ff5 libnetwork.dylib (1880.120.4) <BA294A54-F309-398D-B308-F97032AFF555> /usr/lib/libnetwork.dylib
      0x7fff72909000 - 0x7fff72920fff libnetworkextension.dylib (1095.140.2) <D0E8454C-33A9-3F96-B3A0-EDB12C32283A> /usr/lib/libnetworkextension.dylib
      0x7fff729a9000 - 0x7fff729dcfde libobjc.A.dylib (787.1) <6DF81160-5E7F-3E31-AA1E-C875E3B98AF6> /usr/lib/libobjc.A.dylib
      0x7fff729ef000 - 0x7fff729f3fff libpam.2.dylib (25.100.1) <0502F395-8EE6-3D2A-9239-06FD5622E19E> /usr/lib/libpam.2.dylib
      0x7fff729f6000 - 0x7fff72a2cff7 libpcap.A.dylib (89.120.1) <A76EC076-A8EA-354C-B95F-7AB1EAFBCC65> /usr/lib/libpcap.A.dylib
      0x7fff72a6c000 - 0x7fff72a7aff9 libperfcheck.dylib (37.100.2) <9D9C4879-8A80-34C4-B0D2-BE341FD6D321> /usr/lib/libperfcheck.dylib
      0x7fff72ab0000 - 0x7fff72ac8fff libresolv.9.dylib (67.40.1) <C57EDFEF-D36A-310B-8D14-8C68A625B1E8> /usr/lib/libresolv.9.dylib
      0x7fff72aca000 - 0x7fff72b0eff7 libsandbox.1.dylib (1217.141.2) <E8BA5E84-66AF-3995-8F8E-DDC93B0A88E1> /usr/lib/libsandbox.1.dylib
      0x7fff72b22000 - 0x7fff72b23ff7 libspindump.dylib (281.3) <AE8C1AE9-5CBC-332F-BBE8-370A2A19FED6> /usr/lib/libspindump.dylib
      0x7fff72b24000 - 0x7fff72d0eff7 libsqlite3.dylib (308.5) <35A2BD9F-4E33-30DE-A994-4AB585AC3AFE> /usr/lib/libsqlite3.dylib
      0x7fff72f5f000 - 0x7fff72f62ffb libutil.dylib (57) <F01467F6-23A7-37EE-A170-33CE1577B41D> /usr/lib/libutil.dylib
      0x7fff72f63000 - 0x7fff72f70ff7 libxar.1.dylib (425.2) <EE964412-9E25-30B3-BCC0-CCEFBCC8094B> /usr/lib/libxar.1.dylib
      0x7fff72f76000 - 0x7fff73058fff libxml2.2.dylib (33.5) <A579D158-2E09-316C-872E-DD9D93401B2F> /usr/lib/libxml2.2.dylib
      0x7fff7305c000 - 0x7fff73084fff libxslt.1.dylib (16.9) <34A45627-DA5B-37D2-9609-65B425E0010A> /usr/lib/libxslt.1.dylib
      0x7fff73085000 - 0x7fff73097ff3 libz.1.dylib (76) <793D9643-CD83-3AAC-8B96-88D548FAB620> /usr/lib/libz.1.dylib
      0x7fff73946000 - 0x7fff7394bff3 libcache.dylib (83) <AF488D13-9E89-35E0-B078-BE37CC5B8586> /usr/lib/system/libcache.dylib
      0x7fff7394c000 - 0x7fff73957fff libcommonCrypto.dylib (60165.120.1) <C7912BE5-993E-3581-B2A0-6AABDC8C5562> /usr/lib/system/libcommonCrypto.dylib
      0x7fff73958000 - 0x7fff7395ffff libcompiler_rt.dylib (101.2) <49B8F644-5705-3F16-BBE0-6FFF9B17C36E> /usr/lib/system/libcompiler_rt.dylib
      0x7fff73960000 - 0x7fff73969ff7 libcopyfile.dylib (166.40.1) <3C481225-21E7-370A-A30E-0CCFDD64A92C> /usr/lib/system/libcopyfile.dylib
      0x7fff7396a000 - 0x7fff739fcfdb libcorecrypto.dylib (866.140.1) <60567BF8-80FA-359A-B2F3-A3BAEFB288FD> /usr/lib/system/libcorecrypto.dylib
      0x7fff73b09000 - 0x7fff73b49ff0 libdispatch.dylib (1173.100.2) <CD9C059C-91D9-30E8-8926-5B9CD0D5D4F5> /usr/lib/system/libdispatch.dylib
      0x7fff73b4a000 - 0x7fff73b80fff libdyld.dylib (750.6) <789A18C2-8AC7-3C88-813D-CD674376585D> /usr/lib/system/libdyld.dylib
      0x7fff73b81000 - 0x7fff73b81ffb libkeymgr.dylib (30) <DB3337BE-01CA-3425-BD0C-87774FC0CDC0> /usr/lib/system/libkeymgr.dylib
      0x7fff73b82000 - 0x7fff73b8eff3 libkxld.dylib (6153.141.2) <EE8ECB4B-2EDB-3440-BBC1-6BDDDF5F1BCE> /usr/lib/system/libkxld.dylib
      0x7fff73b8f000 - 0x7fff73b8fff7 liblaunch.dylib (1738.140.1) <AFBCBDD3-0B55-3ECD-8E04-A73A3A57356B> /usr/lib/system/liblaunch.dylib
      0x7fff73b90000 - 0x7fff73b95ff7 libmacho.dylib (959.0.1) <AA613A9C-961A-3B67-B696-4622FA59FC4E> /usr/lib/system/libmacho.dylib
      0x7fff73b96000 - 0x7fff73b98ff3 libquarantine.dylib (110.40.3) <F234E51D-FD0B-3EE4-B679-AE3EE9C536C3> /usr/lib/system/libquarantine.dylib
      0x7fff73b99000 - 0x7fff73b9aff7 libremovefile.dylib (48) <7C7EFC79-BD24-33EF-B073-06AED234593E> /usr/lib/system/libremovefile.dylib
      0x7fff73b9b000 - 0x7fff73bb2ff3 libsystem_asl.dylib (377.60.2) <1563EE02-0657-3B78-99BE-A947C24122EF> /usr/lib/system/libsystem_asl.dylib
      0x7fff73bb3000 - 0x7fff73bb3ff7 libsystem_blocks.dylib (74) <0D53847E-AF5F-3ACF-B51F-A15DEA4DEC58> /usr/lib/system/libsystem_blocks.dylib
      0x7fff73bb4000 - 0x7fff73c3bfff libsystem_c.dylib (1353.100.2) <BBDED5E6-A646-3EED-B33A-91E4331EA063> /usr/lib/system/libsystem_c.dylib
      0x7fff73c3c000 - 0x7fff73c3fffb libsystem_configuration.dylib (1061.141.1) <0EE84C33-64FD-372B-974A-AF7A136F2068> /usr/lib/system/libsystem_configuration.dylib
      0x7fff73c40000 - 0x7fff73c43fff libsystem_coreservices.dylib (114) <A199156E-058D-3ABB-BCE9-4B9F20DCED0F> /usr/lib/system/libsystem_coreservices.dylib
      0x7fff73c44000 - 0x7fff73c4cfff libsystem_darwin.dylib (1353.100.2) <5B12B5DB-3F30-37C1-8ECC-49A66B1F2864> /usr/lib/system/libsystem_darwin.dylib
      0x7fff73c4d000 - 0x7fff73c54fff libsystem_dnssd.dylib (1096.100.3) <EBB4C2C2-E031-3094-B40A-E67BF261D295> /usr/lib/system/libsystem_dnssd.dylib
      0x7fff73c55000 - 0x7fff73c56ffb libsystem_featureflags.dylib (17) <29FD922A-EC2C-3F25-BCCC-B58D716E60EC> /usr/lib/system/libsystem_featureflags.dylib
      0x7fff73c57000 - 0x7fff73ca4ff7 libsystem_info.dylib (538) <8A321605-5480-330B-AF9E-64E65DE61747> /usr/lib/system/libsystem_info.dylib
      0x7fff73ca5000 - 0x7fff73cd1ff7 libsystem_kernel.dylib (6153.141.2) <A576A1CF-7726-3146-B04B-A26E1CDB9757> /usr/lib/system/libsystem_kernel.dylib
      0x7fff73cd2000 - 0x7fff73d19fff libsystem_m.dylib (3178) <00F331F1-0D09-39B3-8736-1FE90E64E903> /usr/lib/system/libsystem_m.dylib
      0x7fff73d1a000 - 0x7fff73d41fff libsystem_malloc.dylib (283.100.6) <8549294E-4C53-36EB-99F3-584A7393D8D5> /usr/lib/system/libsystem_malloc.dylib
      0x7fff73d42000 - 0x7fff73d4fffb libsystem_networkextension.dylib (1095.140.2) <F06C65C5-2CBE-313C-96E1-A09240F9FE57> /usr/lib/system/libsystem_networkextension.dylib
      0x7fff73d50000 - 0x7fff73d59ff7 libsystem_notify.dylib (241.100.2) <FA22F928-D91B-3AA5-96BB-3186AC0FB264> /usr/lib/system/libsystem_notify.dylib
      0x7fff73d5a000 - 0x7fff73d62fef libsystem_platform.dylib (220.100.1) <009A7C1F-313A-318E-B9F2-30F4C06FEA5C> /usr/lib/system/libsystem_platform.dylib
      0x7fff73d63000 - 0x7fff73d6dfff libsystem_pthread.dylib (416.100.3) <62CB1A98-0B8F-31E7-A02B-A1139927F61D> /usr/lib/system/libsystem_pthread.dylib
      0x7fff73d6e000 - 0x7fff73d72ff3 libsystem_sandbox.dylib (1217.141.2) <051C4018-4345-3034-AC98-6DE42FB8273B> /usr/lib/system/libsystem_sandbox.dylib
      0x7fff73d73000 - 0x7fff73d75fff libsystem_secinit.dylib (62.100.2) <F80872AA-E1FD-3D7E-8729-467656EC6561> /usr/lib/system/libsystem_secinit.dylib
      0x7fff73d76000 - 0x7fff73d7dffb libsystem_symptoms.dylib (1238.120.1) <5820A2AF-CE72-3AB3-ABCC-273A3419FB55> /usr/lib/system/libsystem_symptoms.dylib
      0x7fff73d7e000 - 0x7fff73d94ff2 libsystem_trace.dylib (1147.120) <04B47629-847B-3D74-8ABE-C05EF9DEEFE4> /usr/lib/system/libsystem_trace.dylib
      0x7fff73d96000 - 0x7fff73d9bff7 libunwind.dylib (35.4) <42B7B509-BAFE-365B-893A-72414C92F5BF> /usr/lib/system/libunwind.dylib
      0x7fff73d9c000 - 0x7fff73dd1ffe libxpc.dylib (1738.140.1) <3E243A41-030F-38E3-9FD2-7B38C66C35B1> /usr/lib/system/libxpc.dylib
      External Modification Summary:
      Calls made by other processes targeting this process:
      task_for_pid: 0
      thread_create: 0
      thread_set_state: 0
      Calls made by this process:
      task_for_pid: 0
      thread_create: 0
      thread_set_state: 0
      Calls made by all processes on this machine:
      task_for_pid: 67678
      thread_create: 0
      thread_set_state: 0
      VM Region Summary:
      ReadOnly portion of Libraries: Total=661.3M resident=0K(0%) swapped_out_or_unallocated=661.3M(100%)
      Writable regions: Total=906.2M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=906.2M(100%)
      VIRTUAL REGION
      REGION TYPE SIZE COUNT (non-coalesced)
      Activity Tracing 256K 1
      Dispatch continuations 32.0M 1
      Kernel Alloc Once 8K 1
      MALLOC 144.1M 38
      MALLOC guard page 24K 5
      MALLOC_MEDIUM (reserved) 720.0M 6 reserved VM address space (unallocated)
      STACK GUARD 56.0M 4
      Stack 9752K 4
      __DATA 37.2M 343
      __DATA_CONST 20K 1
      __FONT_DATA 4K 1
      __LINKEDIT 392.8M 4
      __OBJC_RO 32.3M 1
      __OBJC_RW 1908K 2
      __TEXT 268.6M 339
      __UNICODE 564K 1
      mapped file 27.3M 2
      shared memory 48K 6
      TOTAL 1.7G 760
      TOTAL, minus reserved VM space 1.0G 760
      Model: MacBookPro16,1, BootROM 1037.147.4.0.0 (iBridge: 17.16.16610.0.0,0), 8 processors, 8-Core Intel Core i9, 2.4 GHz, 32 GB, SMC
      Graphics: kHW_IntelUHDGraphics630Item, Intel UHD Graphics 630, spdisplays_builtin
      Graphics: kHW_AMDRadeonPro5500MItem, AMD Radeon Pro 5500M, spdisplays_pcie_device, 4 GB
      Memory Module: BANK 0/ChannelA-DIMM0, 16 GB, DDR4, 2667 MHz, SK Hynix, -
      Memory Module: BANK 2/ChannelB-DIMM0, 16 GB, DDR4, 2667 MHz, SK Hynix, -
      AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x7BF), wl0: Apr 7 2020 13:09:12 version 9.30.357.41.32.5.49 FWID 01-617711e7
      Bluetooth: Version 7.0.6f7, 3 services, 27 devices, 1 incoming serial ports
      Network Service: Wi-Fi, AirPort, en0
      USB Device: USB 3.1 Bus
      USB Device: Apple T2 Bus
      USB Device: Composite Device
      USB Device: Touch Bar Backlight
      USB Device: Touch Bar Display
      USB Device: Apple Internal Keyboard / Trackpad
      USB Device: Headset
      USB Device: Ambient Light Sensor
      USB Device: FaceTime HD Camera (Built-in)
      USB Device: Apple T2 Controller
      Thunderbolt Bus: MacBook Pro, Apple Inc., 55.3
        • 1650
        #33
        Re: Mass Removing Leading and Trailing Whitespaces From a Tag Field
        Thanks for the crash details.
        Attempted workaround has been added in R17.3 beta 10-
        Current version: beta 13 Download: https://www.dbpoweramp.com/beta/DMC-R173b13.dmg Changes since R17.2 Fixed failure to encode FLAC with very large album cover tags. Fixed failure to convert when source files are momentarily locked by another program. Changes in beta 9 Made possible to enter CD drive offset manually even
        Please report if it works or not (might be showing a different error message instead of crashing now).'
        If the problem persists, please export configuration dump (dBpoweramp settings, troubleshooting tab) and email to peter@dbpoweramp.com for analysis, I'll be hopefully able to recreate the issue in details then.
        • AudibleImagery
          • Aug 2020
          • 50
          #34
          Thank you very much. This solves one of my problems that I mentioned in this thread but I'm also experiencing that DBPoweramp doesn't show a detailed log when I encode more than 3,000 songs. It stays on the encoding window and never crosses over to the log window. This is problematic because I have no way of encoding 75,000 songs at 2,000 song intervals.
          • AudibleImagery
            • Aug 2020
            • 50
            #35
            Thank you for your help. I'm also experiencing the problem that when I encode more than 2,000 songs no detail log is shown. This is problematic because I'm trying to encode 75,000 songs.
              • 1650
              #36
              Thanks for the bug report.
              I've been trying to recreate the failure to open conversion log view with no success, I must be doing something differently, everything seemed normal with over 10000 tracks.
              Please post a sample log of successful short conversion, I'll try to do the same with more tracks.
              • AudibleImagery
                • Aug 2020
                • 50
                #37
                leading white space sounded odd, but then I checked some of my mp3 files. The iTunNorm field also has a leading white space. And these iTunNorm values weren't created by dbpa. They were created by mp3tag (based on the ReplayGain values). So the leading white space is not something unique to dbpa. However, when I go to iTunes, and open any of these mp3 files, iTunes is properly reading the iTunNorm information and showing the soundcheck volume modification correctly (when I look at file info within itunes). So there is no need to remove the leading white space iTunes is reading the info correctly.
                To your point here about iTunNorm tags Gary, DBPoweramp batch converter seems to be writing iTunNorm tags (instead of Comment iTunNorm tags) to AAC and ALAC files. I had suspected this because SoundCheck doesn't work with AAC or ALAC.
                  • 6188
                  #38
                  Not sure about SoundCheck (although I think it does), but I've noticed the different soundcheck tag for mp3 (Comment iTunNorm) vs m4a (iTunNorm). I don't have any ALAC. And these different "soundcheck" tags are consistent with the two different tag fields that mp3tag adds when creating soundcheck values based on ReplayGain values.
                    • 46171
                    #39
                    See:
                    Can someone please explain the difference between the COMMENT ITUNNORM and ITUNNORM tags? For years I have created the COMMENT ITUNNORM tag in MP3Tag assuming that iTunes and my iPod would use this tag for the iTunes Sound Check feature. However, I notice that dBpoweramp is writing the ITUNNORM tag and not the COMMENT
                    as a test I took a fresh m4a file (Apple Lossless), with no normalization tags, iTunes scanned it and with sound check enabled it said on the file info page -4.2db
                    I convert the file to a new file with -converted on the end, this time with Replaygain set to write iTunes track normalization then the file info page on import is -8db, this indicates apple are reading the iTunNorm tag from m4a.
