Batch Convertir for Car
  • Ajalden
    • Mar 2019
    Hi Forum readers,
    I’ve tried a couple times to rip using batch converter from Flac to Acc to reply music in the car but i’m Not getting the file structure right.
    I like to be able to view as Artist and then go into Artist Album to choose which Album.
    The first time it worked but when I choose next track it went to next album instead of next track. The last time it had all my music listed as artist/track so 1000’s of tracks to flick through.
    Any advice welcome?
    Thanks, Andy
    • 45866
    Re: Batch Convertir for Car
    You possibly need:
    [artist]\[album]\[track] [title]
    as the naming. For batch converting for the Car, be sure to check out this:
    It was designed for that one purpose.
    • Ajalden
      • Mar 2019
      Thank you for speedy response, I give it a go and check out tune fusion
      • Ajalden
        • Mar 2019
        You possibly need:
        This made no change the Car stereo and a Naim server still sees artis/album and every single track showing which means I see 1000’s of tracks. However I don’t use iTunes but coped 2 albums to it’s library and it does see it as artis/album. Can I try anything else?
        I looked at Tunefusion but only see it for Microsoft nd I use Apple, any plans?
        Andy
        • Ajalden
          • Mar 2019
          I tried your suggestion and get the same result it shows as artist/album and every single track shows so I have 1000&*8217;s on entries. I also tried it on a Naim sever and sa,e result.
          I don&*8217;t use I tunes but copied 2 albums nd it does show artist/album.
          I&*8217;m using AAC and original files are in Flac, no idea if this has anything to do with it?
          I looked at Tumefusion and it&*8217;s omly available for Microsoft, any plans to support Apple?
          Andy
          • Ajalden
            • Mar 2019
            Apologies for so many typing errors, without glasse at moment so struggling to see!
              • 45866
              It is likely that the filename and path is not used by the car or the Naim, rather the ID Tags. The Naim should be using a UPnP server, such as on a NAS.
