Multi Encoder and DSP folder preserve not working
  • Steph9609
    • Nov 2016
    I just bought and downloaded Reference and now I use Batch Converter.
    When I'm testing a single encoding the DSP folder.jpg preserve, it's work well.
    When I use the multiple encoder to create mp4, mp3 on local and on NAS the folder.jpg doesn't transfer.
    I did many tests, it's not related to the NAS, a multiple local computer destination is not working either. It's not related to music file format original or output.
    I tried setting the DSP for each encoder and\or at the first page where you select to add or remove encoders.
    I use output "single folder" for each encoder and use the same dynamic naming "[album artist] - [album] [year]\[origfilename]"
    Do I miss something... Anyone have an idea?
    Thanks a lot.
    (Otherwise, I have been using dBPoweramp for years... what a great product!)
    • 46218
    Re: Multi Encoder and DSP folder preserve not working
    It is not possible for this dsp effect to be used with multi-encoder.
    • Steph9609
      • Nov 2016
      Ohhhhh...
      Thanks your support is appreciated.
      ...if I may add, a little note about that, somewhere at the DSP effect setting page would be really helpful. I lost MANY hours on that.
      Thanks and keep the good work.
