Audio converter Engine
  • digitalad
    • Aug 2015
    How to use ACE ?
    I configure a new profile but I can't select a codec for conversion. The "Convert to" choice list is empty.
    Somebody could help ?
    nA
  • pignonson
    • Aug 2015
    Re: Audio converter Engine
    I have same troublesheet. The context "Convert to" is empty.
    OS 7 64bit
    ACE : 4.1.2.0 - 32 bit installed
    DbPowerAmp : 15.3.0.2 for 64 bit
    JLB
      Try asking the support team at www.trinitysoftware.nl also.
        • 46230
        You need 32 bit dBpoweramp installed, see:
        The 64 bit release of dBpoweramp will only work correctly with 64 bit codecs. In Codec Central the codecs which are indicated as 32 bit only will not work with the 64 bit version of dBpoweramp. As the 32 bit version of dBpoweramp has been retired, on the registration download page is an 'Old OS?' link, click that to download
        • digitalad
          • Aug 2015
          Hi Spoon,
          Are you sure ? ACE is installed in the folder 64bit programs.
          I completed the installation of 32-bit dBpoweramp but the result is the same.
          Does the number of CPU cores on the host station to matter?
          The purchased version is a version of ACE 2 CPU cores.
          The host station is equipped with a 4-core CPU.
            • 46230
            Number of CPUs does not matter, all that counts is both ACE and dBpoweramp are installed to the default locations. Try uninstall both, then install ACE, it is installs to 64 bit location then install 64 bit dbpoweramp. to same location.
            • digitalad
              • Aug 2015
              Hello,
              I tried this without success.
              (Intel i5, Windows 7 enterprise)
              I completely de-installed dBpoweramp and ACE.
              I erased all traces in the registry.
              I launched the installation of ACE as shown (before dBpoweramp).
              This time, ACE is installed in the x86 folder (?) C: \ Program Files (x86) \ Illustrate \ dBpoweramp
              Then, without forcing it to the 32bit installation, dBpoweramp was installed under the same tree. This did not happen before.
              It works now.
              nA
