Audio Info not listing 32 bit float files?
  • belinea2010
    • May 2020
    • 17
    If i hover my mouse over a known 32 bit float wav file the dbPoweramp info box its displayed showing the various atributes of the file.
    Things such as:
    Type:
    Size:
    Length:
    Channels:
    Sample Rate:
    and importantly for me
    Sample Size:
    as well as other data.
    If I use Batch Converter > [Audio Info] it does not list the file as 32 Bit Float, it only returns 32 Bit.
    dbPoweramp must be getting the Sample Size: data so why wont the Audio Info so that and is there another way to get it?
    That file information must be stored in the file as I have not added it as a Tag.
    Many thanks.
  • belinea2010
    • May 2020
    • 17
    I have just tried to upload a small jpg to this post to illistrate my question but I each time I try I get a "Path can not be empty" error no matter which method I try.
      Will check when do next update
      • belinea2010
        • May 2020
        • 17
        Thank you Spoon.
