dMC-R15.3-Ref-Registered.exe will not start
  • brunzeg
    • Jul 2015
    I installed a new hard disk on my PC, so I need to re-install dbpoweramp I purchased in 03-2014. I downloaded today the dMR-R15.3-Ref-Registered.exe from the dBpoweramp website, but when I click on the downloaded file, nothing starts. when I look at the programs/processes running (via CTRL-DEL, task list), I don't see any program like dbpoweramp running or installation program...
    what can I do to re-install my purchased product ? I'm working on PC with Windows Vista
    Re: dMC-R15.3-Ref-Registered.exe will not start
    Are you sure you have completely downloaded the dMC-R15.3-Ref-Registered.exe? Try it again and check the filesize, should be 26.3MB
      See:
      for some this update also stops the installer from running.
      • Rasho
        • Aug 2015
        I have the same problem on 8.1.
        I purchased the registered product a few weeks back but wasn't worried when opening the file did nothing as the product worked. My trial period has ended now, though and the registered version won't install so I can't use it.
        The file looks the correct size (I tried downloading again too) and I uninstalled the update above from 8.1 but it still won't work.
        Any more ideas so I can install the product?
          What is the exact filesize?
          What antivirus are you using?
          (the vista issues is limited only to vista)
          • Rasho
            • Aug 2015
            Thanks for the reply. During debug I have discovered other times my PC is having issues so think the problem is on my end. Am going to refresh or reset windows and try again.
            • Rasho
              • Aug 2015
              Works fine now so must have been corrupt windows.
