Multi Disc Sets
  • Oliver Knowles
    • Sep 2014
    • 26
    Re: Multi Disc Sets
    Going back to my original post, is it not possible to display multi disc sets in this way? In other words, box sets would appear as one album but when you click on them, they are then divided into separate discs. As far as I can tell, the multi disc options on Asset don't allow for this. I don't like the default option of grouping all discs into one album folder. I've tagged all my multi disc sets using the Disk Number tag but only the 'Show as Album, Disc X' option seems to use this tag properly and then it presents other problems as we've discussed. Ideally, I don't really want to have to retag all these files just so that they fit with Asset. I hope that makes sense.
      Re: Multi Disc Sets
      Yes it is possible, as you can customise the browse tree.
      • Oliver Knowles
        • Sep 2014
        • 26
        Re: Multi Disc Sets
        Please can you advise how you would do this? Thanks in advance.
          • 46231
          Re: Multi Disc Sets
          You have to retag the albums where your disc number tag is saved to the wrong tag, otherwise asset will not read it.
          • Oliver Knowles
            • Sep 2014
            • 26
            Re: Multi Disc Sets
            Sorry, I don't understand. What do you mean by my 'disc number tag is saved to the wrong tag'? Why does one tag need to be saved to another tag? I don't get this at all.
              • 46231
              #21
              Re: Multi Disc Sets
              For FLAC the tags you need are 'Discnumber' and 'disctotal' with no spaces.
              • Oliver Knowles
                • Sep 2014
                • 26
                #22
                Re: Multi Disc Sets
                Thanks, I've located these tags on Metadatics and they are the ones I'm using now. This solves the issue I had with some files showing as 'Disc 0', etc.
                  • 6189
                  #23
                  Re: Multi Disc Sets
                  Can't recall if one can copy from existing tag to correct tag field with dbpa. But in any case, with mp3tag, one can easily batch copy from your existing disc tags into these correct tags with a couple of mouse clicks (yes, works on FLAC files).
                  • Oliver Knowles
                    • Sep 2014
                    • 26
                    #24
                    Re: Multi Disc Sets
                    Hi Mville. Would you mind explaining how you would customise the browse tree to achieve this? Thanks in advance.
                      Re: Multi Disc Sets
                      RTFM
                      Sorry, I am a Illustrate for Windows only user, so I wouldn't have a clue how to configure Asset on a non-Windows platform.
                      • Oliver Knowles
                        • Sep 2014
                        • 26
                        #26
                        Re: Multi Disc Sets
                        RTFM
                        No worries. Thanks for replying anyway.
