Multi Disc Sets
  • Oliver Knowles
    • Sep 2014
    • 26
    Multi Disc Sets
    I'm trying to organise my multi disc sets/box sets using Asset. I have all my files tagged using the 'Disc Number' tags. If I select 'Leave Album Tag Untouched' in the options, however, it groups all the files in one album listing. I like to be able to view each disc separately so this is no good for me. Selecting 'Show as Album, Disc X' does achieve this but it's brought up a couple of anomalies. Firstly, a small number of discs show up as 'Disc 01, Disc 02, Disc 03' instead of 'Disc 1, Disc 2, Disc 3'. I also have a few single discs that now have 'Disc 0' added at the end. I've checked the tags on these discs and I can't figure out what's happened as the tags appear correct. In the case of the former, I've input '1', '2', '3' in the Disc tag. In the latter, I've left the Disc tag empty as the discs are not part of multi disc sets.
    Ideally, I'd like an option where the box set appears as one album/listing. This would show the box set artwork. You would click on this and it would open up the separate discs with their own artwork. I don't think this can be done on Asset unless I'm mistaken. To give you an example, 'Neil Young Archives Vol. II (1972 - 1976)' would appear as one album with its artwork. You'd click on this and you'd then have separate discs, i.e. 'Disc 1 - Everybody's Alone (1972-1973)', 'Disc 2 – Tuscaloosa (1973)', etc, with their own artwork.
    • 46231
    Re: Multi Disc Sets
    Which Tag editor are you using? dBpoweramp?
    • Oliver Knowles
      • Sep 2014
      • 26
      Re: Multi Disc Sets
      No, I'm using Metadatics.
        • 46231
        Re: Multi Disc Sets
        Try with dBpoweramp please. Or PerfectTUNES.
        • Oliver Knowles
          • Sep 2014
          • 26
          Re: Multi Disc Sets
          I don't have any of these programmes. It should work fine with Metadatics as I've not had problems with it on other UPNP software. I would have thought using the Disc Number tag on Metadatics would work fine.
            • 46231
            Re: Multi Disc Sets
            Often files can contain more than one tag type, using dbpoweramp or perfecttunes in their trial mode would show what tags asset is reading. We have to rule this out.
              Re: Multi Disc Sets
              What audio file format is your library?
              In Metadatics, double-check that the Disc Number tag is consistent for all audio files?
              ... and as Spoon suggests, Asset may use a different disc no. tag than that used in Metadatics.
              • Oliver Knowles
                • Sep 2014
                • 26
                Re: Multi Disc Sets
                Hi, I use FLAC and DSF files.
                Looking at Metadatics, there is the 'Disc Number' tag and also a 'TotalDiscs' tag. Could it be latter tag interfering?
                • Oliver Knowles
                  • Sep 2014
                  • 26
                  Re: Multi Disc Sets
                  Am I right in thinking that the scenario I gave for the Neil Young boxset in my first post is not possible on Asset?
                    Re: Multi Disc Sets
                    In Metadatics, copy 'disc number' to 'discnumber' and 'totaldiscs' to 'disctotal', then Refresh All in Asset and report the outcome.
                    • Oliver Knowles
                      • Sep 2014
                      • 26
                      Re: Multi Disc Sets
                      I'm not sure what you mean, I can only see 'Disc Number' and 'TotalDiscs'. There are no 'Discnumber' or 'Disctotal' options.
                      However, if I remove the TotalDiscs tag, the Disc 0 at the end disappears. It was for CDs where there is a bonus DVD or in the case of my SACDs, a surround mix in addition to the main stereo mix. Once I remove the TotalDiscs tag, the Disc 0 disappears. This solves that problem.
                      I can't figure out why I get 'Disc 01', 'Disc 02', etc. It does only seem to be on big box sets (i.e. at least 10 discs). Could this be the issue, that if there are at least 10 discs, it reverts to 2 characters instead of 1?
                      By the way, can I ask what you mean by Refresh All? Where can I find that? I thought Asset refreshed itself without needing to be instructed, is that not right?
                        Re: Multi Disc Sets
                        Are you not able to create new tags in Metadatics e.g. 'Discnumber' and 'Disctotal' and then copy other tag values to these new tags?
                        Look in Asset UPnP Configuration.
                        • Oliver Knowles
                          • Sep 2014
                          • 26
                          Re: Multi Disc Sets
                          I'll have to look at this in the next day or two when I get a chance.
                          Asset is stored on my Synology NAS. I access the Status, Options and Advanced settings via my Synology webpage. The screen shots on the Asset UpnP Configuration instructions page look quite different to what I'm seeing. I can't find the Refresh All button anywhere. I'm using a Mac by the way. What am I doing wrong?
                            Re: Multi Disc Sets
                            On the following webpage, it has a Rescan All option. Do you not have this?:
                            Asset UPnP Linux, QNAP & Synology Manual
                            • Oliver Knowles
                              • Sep 2014
                              • 26
                              Re: Multi Disc Sets
                              Sorry, yes I do have something similar. It looks slightly different on Synology, there is a 'Restart Asset UPnP', 'Rescan folders detecting changes' and 'Clear database, rescan all folders'. When I saw 'Refresh All', I thought there was some other page I couldn't see, that's all.
