Raspberry Newbie needs help
  • ASF
    • Jun 2012
    • 123
    Re: Raspberry Newbie needs help
    Simon:
    Getting closer. I found the following page regarding Linus syntax for NFS server mounts: https://access.redhat.com/documentat...nfs-mount.html
    Based on this, I tried changing the line as follows: "192.168.1.152:/WD-NAS-FINK/Music/WAV /home/pi/nas nfs ro 0 0"
    When I then tried to mount the server, I received the following message:
    I wonder if I need to add a user ID and password? If so, can you advise how to add this? Alternatively, should I try using the IP address twice, in lieu of the IP address followed by the device name?
    Aaron
    • ASF
      • Jun 2012
      • 123
      I tried adding "username=admin,password=********* " after "nfs" and before "ro" in the line. Unfortunately, after a reboot, I am unable to access the Raspberry. Do I need to start over?
      Aaron
      Last edited by ASF; August 07, 2017, 04:55 PM. Reason: Sorry, had to edit a duplicated message; ignore JPG
      • simes_pep
        • Dec 2013
        • 300
        I would stick with mounting the Music folder, the sub-folder can be identified in the Watched folder within Asset.
        • simes_pep
          • Dec 2013
          • 300
          I think the server in the WD device is confusing things by allowing you to define the nfs mount point.
          So just keep that bit simply and let the Raspberry mount the NAS share and navigate to the required sub-folder.
          Simon
          • ASF
            • Jun 2012
            • 123
            In other words just the name of the share, i.e. "\IP address\nfs\Music". I will try when I straighten out my microSD card.....I have to reformat it and start again. I'll let you know how things go when I get back to where I was....DARN!!
            Thanks for the help.
            Aaron
            • ASF
              • Jun 2012
              • 123
              #21
              Simon:
              I am back up and running. Asset UPnP is installed and comes on with each reboot. I then added the following line in the fstab file: "192.168.1.152:/192/168/1/152/nfs/Music /home/pi/nas nfs ro 0 0". Unfortunately, the server still won't mount. Here is the message that I receive:
              This message seems to suggest we are even closer, but I wonder what I need to do to resolve the apparently missing information.
              Aaron
              • simes_pep
                • Dec 2013
                • 300
                #22
                This is the entry in my fstab file
                192.168.0.3:/media /home/pi/nas nfs ro 0 0
                You need to work on the mount points as allowed by the WD device
                Simon
                • ASF
                  • Jun 2012
                  • 123
                  #23
                  Not sure I understand what to try next? What do I do to deal with rpc.stand?
                  Aaron
                  • simes_pep
                    • Dec 2013
                    • 300
                    #24
                    To be honest don't know - I don't have statd running - some information is at https://www.ibm.com/support/knowledg...mds5/statd.htm
                    But I believe it is due to the entry in the fstab file.
                    Is there a section in the manual for the WD device, describing how to use the NFS settings?
                    Simon.
                    • ASF
                      • Jun 2012
                      • 123
                      #25
                      I will check. I may have to resort to a call to them, although I find they have been less than helpful at times. I'll share what I find out.
                      Thanks for ALL of your help...you've clearly gotten me close to the end result!!
                      Aaron
                      • ASF
                        • Jun 2012
                        • 123
                        #26
                        Here's the only information I could find in their manual. I will try their technical support.
                        Aaron
                        • ASF
                          • Jun 2012
                          • 123
                          #27
                          Simon:
                          I just found this link: https://backdrift.org/fixing-rpc-sta...remote-locking which seems to address the problem. Might you look this offer and see if the syntax and use looks appropriate for the Raspberry?
                          Aaron
                          • simes_pep
                            • Dec 2013
                            • 300
                            #28
                            My nfs mount to the ReadyNAS units I have don't seem to need locking mechanism, but maybe your WD unit does - try what is listed, and see if you can mount the share.
                            Simon.
                            • ASF
                              • Jun 2012
                              • 123
                              #29
                              I tried and received the following:
                              After starting the rpcbind, I tried to mount /home/pi/nas and got the following result:
                              I then edited the /etc/fstab file again by inserting my username and password as shown here: "192.168.1.152:/192.168.1.152/nfs/Music /home/pi/nas nfs username=Aaron,password=******** ro 0 0"
                              This resulted in the following message:
                              I just don't know enough about Linux and mounting drives (let alone using NFS) to figure anything else out. I am trying to reach out to Western Digital but I suspect they will say they can't help since the issue is within the /etc/fstab file on the Raspberry and thus not in their purview. I'll let you know.
                              Aaron
                              • simes_pep
                                • Dec 2013
                                • 300
                                #30
                                Again I think your entry in fstab is wrong - it should be similar to 192.168.0.3:/media /home/pi/nas nfs ro 0 0
                                For WD instructions - see https://support.wdc.com/knowledgebas....aspx?ID=17224 - I think the useful parts are sections 5 & 6
                                Either limit the nfs to just the RaspberryPi's IP address or use a wildcard.
                                Simon.
