Asset Sort Order, Linn Kazoo, next problem, please help
  • erho
    • Aug 2016
    • 53
    Hello,
    now I am using Asset and it works with latest Linn Kazoo.
    One problem remains, have tagged my files with Metadatics and use Album Artist Sort, Composer Sort, Artist Sort and Conductor Sort. In configuration I have set to use only Sort view. But sometimes it works, most of the times it do not work. Artist Bruce Springsteen, Artist Sort Springsteen Brice for example shows me in Kazoo under B not S.
    What is wrong or what did I wrong?
    • 46189
    Re: Asset Sort Order, Linn Kazoo, next problem, please help
    If you have changed tags after asset has scanned, try a rescan (refresh all).
    • erho
      • Aug 2016
      • 53
      Spoon, seems that I found out, that the sorting only works for Composer and Conductor with newest Kazoo. Artist amd Album Artist Sorts do not work. Another problem that have to be fixed by Linn .....
      • erho
        • Aug 2016
        • 53
        @Spoon,
        perhaps it helps for you to understand my problem. I am using Asset an QNAP TS-251+ NAS, Macbook Retina, OSX Sierra, with latest Kazoo as Controlpoint and have tagged all right. The Sorting tags for Artist and Album Artist do not work, also they do not work after 10 rescans.....
        • erho
          • Aug 2016
          • 53
          So, now tried it with BubbleDS Control Point on Android tablet and the sort tags for album artist and artist do also not work. Summa summarum the QNAP version of Asset 5.1 is bugged, not the mistake by Linn. Can you fix this please, have never thought that the so-called best server on the market made such problems. Do not want to say it but perhaps it will be better to use Minimserver which works like a charm. Sorry for that, on my system Asset has better sound but with these problems...
            • 46189
            It is likely you have the files tagged in a non-standard format. Which audio type are you using? Which program is used to write the sort tags?
            • erho
              • Aug 2016
              • 53
              Audio type is FLAC. I am using Metadatics on Mac.
              • erho
                • Aug 2016
                • 53
                What are the standard format tags?
                  • 6188
                  For flac files, "vorbis comment" tags. Some rippers incorrectly put ID3Vx tags in flac files.
                    • 46189
                    Your Tagger has to write 'Artist Sort' and 'Album Artist Sort' (notice the space), this is the most used standard for flac, if it is writing ArtistSort and AlbumArtistSort then Asset will not read.
                    • erho
                      • Aug 2016
                      • 53
                      Thanks will try it.
                      • erho
                        • Aug 2016
                        • 53
                        Hi, now it works, must change the tags within Metadatics. Thank you for your help Sir. How should I tag classical albums? Perhaps do you have some tips for me?
                        • erho
                          • Aug 2016
                          • 53
                          Absolutely no idea how to tag classical albums, help is welcome
                            • 6188
                            • erho
                              • Aug 2016
                              • 53
                              thanks, will read and learn, how is your way to do it please?
