Problem updating to R2026-7-13
  • alan9990
    • Mar 2026
    • 25
    It may well be simply some fundamental error/misunderstanding on my part, but I don't understand why the update is failing...
    from the web interface, it offers a direct link to R2026-7-13
    I click on this, and I get a local download saved titled "getupdate"
    This appears to be a compressed file. When I attempt to extract it, I get "an error occurred while extracting files. Command exited abnormally"
    So I'm somewhat in the dark with this at present.
    • 46190
    Which platform?
    • NinthWave
      • Nov 2018
      • 20
      The process stops at "starting asset" on debian trixie
      • NinthWave
        • Nov 2018
        • 20
        Originally posted by Spoon-
        Which platform?
        I tried installing from scratch on a debian trixie LXC and it hangs at "starting asset" anf
        • NinthWave
          • Nov 2018
          • 20
          [HTML]=== Asset UPnP installer ===
          Installing version:
          R2026-07-13
          Upgrading from:
          R2026-07-13
          No existing process found.
          Updating crontab...
          Starting Asset...[/HTML]
            • 1650
            There's a glitch in the install script, that causes it to get stuck waiting for Asset to finish starting (script not updated for changed configuration data location).
            You can safely stop the script with Ctrl+C or equivalent at the point it prints "Starting Asset", it's installed and running.
            • RayK
              • Jul 2026
              • 9
              Unable to install on Synology DS214play running DSM 7.1.1-42962 Update 9.
              Was able to reinstall Asset 7.5 fine
                • 46190
                We have update the ARM (Pi) and Linux installs to fix the install script not finishing. Same version number, just redownload. Note QNAP, Synology, macOS has not changed at this point.
                • NinthWave
                  • Nov 2018
                  • 20
                  I confirm I update the Linux version flawlessly. I noticed the logo on web UI has been changed.
                  Thanks again for quick fix.
                  • alan9990
                    • Mar 2026
                    • 25
                    I'm trying to update on Arch Linux
                    • alan9990
                      • Mar 2026
                      • 25
                      so, still not sure what I'm doing wrong...
                      clicking on the URL shown in the web interface, even just now, seems to download a file called "getupdate". Yet I still cannot successfully extract this file.
                      Have I missed some permalink regarding upgrades? Don't understand why this is problematic.
                        • 46190
                        Your security for the web browser is set to too high levels blocking the download.
                        either reset to default or install 2nd browser to download install.
                        • NinthWave
                          • Nov 2018
                          • 20
                          As of now, there is a new R2026-07-15 version, is it the same fix as R2026-07-13 with only a new date ?
                          • alan9990
                            • Mar 2026
                            • 25
                            I don't think I've explained my issue correctly.
                            I can download the update. This creates a file ~/Downloads/getupdate which is a gzip.
                            Once I go to the download location, and try to "extract here" this very file then attempts to overwrite itself... and despite whichever option I try, I always get "an error occurred while extracting files"
                              • 46190
                              It is possibly not a proper download. Anyhow rename to .tgz and try to extract.
