Gapless Playback with Wattson Audio Emerson Analog
  • badlyread
    • Jul 2026
    Hi All
    First post so be gentle.....
    I have had Asset installed on a MacMini acting as a server for years now and gapless playback has never been a problem until now. I previously had a Primare NP5 going to a Chord Hugo2 DAC which inserted a gap between continuous tracks and the same now happens with the Emerson. Both are meant to handle gapless playback. Have I somehow adjusted the settings in Asset to cause this? Or is it the Emerson?
    Many thanks
    Neil
    • 46190
    The UPnP server does not handle gapless, the player does, by reading the next stream before the end of the previous one.
    • badlyread
      • Jul 2026
      Hi Spoon
      Thanks for getting back to me.
      So if I understand you correctly the streamer is responsible for the gapless playback. Nothing to do with Asset?
        • 46190
        Correct
        • simbun
          • Apr 2021
          • 263
          The control point also has to support gapless playback. What app are you using to browse AssetUPnP?
          If you're on Android try BubbleUPnP and enable 'Gapless control' under Settings > Renderers settings > <<Emerson>>.
          If you're on iOS try mconnect, and enable gapless playback by:
          • Select the Emerson renderer from 'Play to' tab
          • Switch to the 'Player' tab
          • Select the cog in the top left corner of the screen
          • Select 'Gapless'
          • Enable 'Gapless to Renderer'
          • badlyread
            • Jul 2026
            Hi simbum
            I'm using the Wattson Audio app Wattson Music which supports gapless playback. I've just reinstalled the latest firmware update from Wattson and still the issue remains. I have an iOS device. I've just tried MConnect enabling the gapless feature and still no gapless. Very strange.
            I'll contact Wattson.
            Many thanks.
            • badlyread
              • Jul 2026
              Sorted! Files are in ALAC. Transcoded to WAV on the fly and gapless playback is happening. Very strange.
              Thank you to all those that responded.
