I am running AssetUPnP 4.6.3 on a multihomed environment on Debian x86_64. To
run the UPnP service in one network only I use flag
--ipaddress x.x.x.x
TCP and UDP listener bind to the correct socket, other networks are not used.
However, the multicasts are sent to other networks as well, carrying an invalid
URL in the payload (details and config below).
Communication in the configured network is working properly. I noticed that for
restarted control devices it may take a minute to list AssetUPnP - I guess that's
ok for a UPnP service, right?
Cheers, kapfenho
ps: thanks for this outstanding music server
--ipaddress x.x.x.x
Cheers, kapfenho
Code:
*** good packet 00:00:00.020331 00:00:00:00:83:12 > 01:00:5e:7f:ff:fa, ethertype 802.1Q (0x8100), length 348: vlan 500, p 0, ethertype IPv4, 172.16.6.4.35238 > 239.255.255.250.1900: UDP, length 302 [email protected]. P.........l.6..NOTIFY * HTTP/1.1 Host: 239.255.255.250:1900 LOCATION: http://172.16.6.4:26125/DeviceDescription.xml NTS: ssdp:alive CACHE-CONTROL: max-age=1800 Server: UPnP/1.0, DLNADOC/1.50, AssetUPnP/1.0 USN: uuid:7920C4B2-07A7-3A30-F547-925ABE888F85-abcd-123456789abc::upnp:rootdevice NT: upnp:rootdevice *** wrong packet 00:00:13.120738 00:00:00:00:83:02 > 01:00:5e:7f:ff:fa, ethertype IPv4 (0x0800), length 344: 172.16.4.4.39284 > 239.255.255.250.1900: UDP, length 302 E..J)[email protected]. P.......t.l.6..NOTIFY * HTTP/1.1 Host: 239.255.255.250:1900 LOCATION: http://172.16.4.4:26125/DeviceDescription.xml NTS: ssdp:alive CACHE-CONTROL: max-age=1800 Server: UPnP/1.0, DLNADOC/1.50, AssetUPnP/1.0 USN: uuid:7920C4B2-07A7-3A30-F547-925ABE888F85-abcd-123456789abc::upnp:rootdevice NT: upnp:rootdevice *** processes 10867 ? S 0:00 AssetUPnP --ipaddress 172.16.6.4 10869 ? Sl 0:03 \_ /home/upnp/assetupnp-4.6.3/AssetUPnP --fork-is-webconfig --ipaddress 172.16.6.4 --control-pipe 11 12333 ? Sl 11:36 \_ /home/upnp/assetupnp-4.6.3/AssetUPnP --fork-is-upnp --ipaddress 172.16.6.4 --control-pipe 7 18955 ? S 0:13 \_ /home/upnp/assetupnp-4.6.3/AssetUPnP --fork-is-umedialibrary --umedialibrary-param s --control-pipe 9 *** sockets udp UNCONN 0 0 172.16.6.4:1900 *:* users:(("AssetUPnP",pid=12333,fd=29)) tcp LISTEN 0 20 172.16.6.4:45537 *:* users:(("AssetUPnP",pid=10869,fd=8)) tcp LISTEN 0 20 172.16.6.4:26125 *:* users:(("AssetUPnP",pid=12333,fd=32)) *** interfaces 4: bond0: <BROADCAST,MULTICAST,MASTER,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default link/ether 00:00:00:00:83:02 brd ff:ff:ff:ff:ff:ff inet 172.16.4.4/24 brd 172.16.4.255 scope global bond0 valid_lft forever preferred_lft forever 5: bond0.500@bond0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default link/ether 00:00:00:00:83:12 brd ff:ff:ff:ff:ff:ff inet 172.16.6.4/24 brd 172.16.6.255 scope global bond0.500 valid_lft forever preferred_lft forever *** route default via 172.16.4.1 dev bond0 172.16.4.0/24 dev bond0 proto kernel scope link src 172.16.4.4 172.16.6.0/24 dev bond0.500 proto kernel scope link src 172.16.6.4 *** packets 2016-02-17 23:47:24.718405 00:00:00:00:83:02 > 01:00:5e:7f:ff:fa, ethertype IPv4 (0x0800), length 344: 172.16.4.4.44550 > 239.255.255.250.1900: UDP, length 302 2016-02-17 23:47:24.738562 00:00:00:00:83:02 > 01:00:5e:7f:ff:fa, ethertype IPv4 (0x0800), length 396: 172.16.4.4.44550 > 239.255.255.250.1900: UDP, length 354 2016-02-17 23:47:24.758698 00:00:00:00:83:02 > 01:00:5e:7f:ff:fa, ethertype IPv4 (0x0800), length 424: 172.16.4.4.44550 > 239.255.255.250.1900: UDP, length 382 2016-02-17 23:47:24.778849 00:00:00:00:83:02 > 01:00:5e:7f:ff:fa, ethertype IPv4 (0x0800), length 408: 172.16.4.4.44550 > 239.255.255.250.1900: UDP, length 366 2016-02-17 23:47:24.799002 00:00:00:00:83:02 > 01:00:5e:7f:ff:fa, ethertype IPv4 (0x0800), length 410: 172.16.4.4.44550 > 239.255.255.250.1900: UDP, length 368 2016-02-17 23:47:24.819149 00:00:00:00:83:02 > 01:00:5e:7f:ff:fa, ethertype IPv4 (0x0800), length 371: 172.16.4.4.44550 > 239.255.255.250.1900: UDP, length 329 2016-02-17 23:47:24.839295 00:00:00:00:83:02 > 01:00:5e:7f:ff:fa, ethertype IPv4 (0x0800), length 344: 172.16.4.4.44550 > 239.255.255.250.1900: UDP, length 302 2016-02-17 23:47:24.859433 00:00:00:00:83:02 > 01:00:5e:7f:ff:fa, ethertype IPv4 (0x0800), length 396: 172.16.4.4.44550 > 239.255.255.250.1900: UDP, length 354 2016-02-17 23:47:24.879569 00:00:00:00:83:02 > 01:00:5e:7f:ff:fa, ethertype IPv4 (0x0800), length 424: 172.16.4.4.44550 > 239.255.255.250.1900: UDP, length 382 2016-02-17 23:47:24.899713 00:00:00:00:83:02 > 01:00:5e:7f:ff:fa, ethertype IPv4 (0x0800), length 408: 172.16.4.4.44550 > 239.255.255.250.1900: UDP, length 366 2016-02-17 23:47:24.919856 00:00:00:00:83:02 > 01:00:5e:7f:ff:fa, ethertype IPv4 (0x0800), length 410: 172.16.4.4.44550 > 239.255.255.250.1900: UDP, length 368 2016-02-17 23:47:24.939997 00:00:00:00:83:02 > 01:00:5e:7f:ff:fa, ethertype IPv4 (0x0800), length 371: 172.16.4.4.44550 > 239.255.255.250.1900: UDP, length 329 2016-02-17 23:47:24.960337 00:00:00:00:83:12 > 01:00:5e:7f:ff:fa, ethertype 802.1Q (0x8100), length 348: vlan 500, p 0, ethertype IPv4, 172.16.6.4.39182 > 239.255.255.250.1900: UDP, length 302 2016-02-17 23:47:24.980541 00:00:00:00:83:12 > 01:00:5e:7f:ff:fa, ethertype 802.1Q (0x8100), length 400: vlan 500, p 0, ethertype IPv4, 172.16.6.4.39182 > 239.255.255.250.1900: UDP, length 354 2016-02-17 23:47:25.000712 00:00:00:00:83:12 > 01:00:5e:7f:ff:fa, ethertype 802.1Q (0x8100), length 428: vlan 500, p 0, ethertype IPv4, 172.16.6.4.39182 > 239.255.255.250.1900: UDP, length 382 2016-02-17 23:47:25.020870 00:00:00:00:83:12 > 01:00:5e:7f:ff:fa, ethertype 802.1Q (0x8100), length 412: vlan 500, p 0, ethertype IPv4, 172.16.6.4.39182 > 239.255.255.250.1900: UDP, length 366 2016-02-17 23:47:25.041010 00:00:00:00:83:12 > 01:00:5e:7f:ff:fa, ethertype 802.1Q (0x8100), length 414: vlan 500, p 0, ethertype IPv4, 172.16.6.4.39182 > 239.255.255.250.1900: UDP, length 368 2016-02-17 23:47:25.061167 00:00:00:00:83:12 > 01:00:5e:7f:ff:fa, ethertype 802.1Q (0x8100), length 375: vlan 500, p 0, ethertype IPv4, 172.16.6.4.39182 > 239.255.255.250.1900: UDP, length 329 2016-02-17 23:47:25.081327 00:00:00:00:83:12 > 01:00:5e:7f:ff:fa, ethertype 802.1Q (0x8100), length 348: vlan 500, p 0, ethertype IPv4, 172.16.6.4.39182 > 239.255.255.250.1900: UDP, length 302 2016-02-17 23:47:25.101486 00:00:00:00:83:12 > 01:00:5e:7f:ff:fa, ethertype 802.1Q (0x8100), length 400: vlan 500, p 0, ethertype IPv4, 172.16.6.4.39182 > 239.255.255.250.1900: UDP, length 354 2016-02-17 23:47:25.121634 00:00:00:00:83:12 > 01:00:5e:7f:ff:fa, ethertype 802.1Q (0x8100), length 428: vlan 500, p 0, ethertype IPv4, 172.16.6.4.39182 > 239.255.255.250.1900: UDP, length 382 2016-02-17 23:47:25.141791 00:00:00:00:83:12 > 01:00:5e:7f:ff:fa, ethertype 802.1Q (0x8100), length 412: vlan 500, p 0, ethertype IPv4, 172.16.6.4.39182 > 239.255.255.250.1900: UDP, length 366 2016-02-17 23:47:25.161950 00:00:00:00:83:12 > 01:00:5e:7f:ff:fa, ethertype 802.1Q (0x8100), length 414: vlan 500, p 0, ethertype IPv4, 172.16.6.4.39182 > 239.255.255.250.1900: UDP, length 368 2016-02-17 23:47:25.182095 00:00:00:00:83:12 > 01:00:5e:7f:ff:fa, ethertype 802.1Q (0x8100), length 375: vlan 500, p 0, ethertype IPv4, 172.16.6.4.39182 > 239.255.255.250.1900: UDP, length 329
