Installing Asset UPnP in WS 2012R2, need help
  • Armsan
    • Jan 2016
    Hello all,
    I´m trying to install Asset UpnP, trial version, in a machine with WS 2012R2 OS.
    The first error was a WVMCore.DLL missing. Got it from the net and this error was solved.
    The was the WMASF.DLL missing. This one I can´t solve.
    Any ideas, how to succeed this installation, please?
    Thank You.
    Armsan
    • 46189
    Re: Installing Asset UPnP in WS 2012R2, need help
    You should install the Windows XP version of Asset, this includes all those files.
    • Armsan
      • Jan 2016
      Thank You Soop.
      I´ll try and then let you know.
      Best regards.
      Armsan
      • Armsan
        • Jan 2016
        Good day Spoon,
        Infortutenly I get tehe same message: WMASF.DLL is missing...
        Oh well, it seems there will be no Asset for me.
        Thank You Spoon for your help.
        Regards.
        Armsan
          • 46189
          in the install folder, in 'Decoder' folder delete the Windows Media Audio.dll
          • Armsan
            • Jan 2016
            Hi Spoon,
            Sorry to bother you again but I can´t get it to work, I mean the program doesn´t start.
            Yes, I´m new at this and I did what you recommended but: I only can delete the Windows Media Audio.dll file, after the installation done, right?
            After installation, I must go to Program Files(x86)>Illustrate>dbPoweramp>Decoder and delete that file, right? That´s what I did.
            If I want to do it before installation, I mean before running assetUPnP.exe program, how should I do?
            Thank You.
            Regards.
            Armsan
              • 46189
              You do it after installing. The installer should install ok even though it might give the above error, but Asset will be installed.
              • Armsan
                • Jan 2016
                OK Spoon, I understand. But then how do I start the program? How do I see the GUI? Does it auto matically create a start button on the desktop?
                I confirm you that the Asset Service is active in the task manager.
                Thank You.
                Regards.
                Armsan
                  • 46189
                  Asset has no Gui (beyond the configuration program), it is a UPnP server, you need a UPnP control point to browse what is on UPnP servers.
                  • Thuanb
                    • Aug 2016
                    Thank You.
                    Regards.
                    Armsan
                    Armsan, were you able to make it work? I'm trying to do the same but stuck. I could see all music files but couldn't play them. Those buttons are grayed out, and the screen keeps saying, "Waiting for...". This is Premium version, I'm frustrated.
                      • 46189
                      Answering here:
                      Hi, I've just newly registered, downloaded and installed Asset on my server. The program gives the error / warning of missing .dll file but otherwise seemed ok. However, my iPad Kazoo keeps waiting forever fir something that won't let me listen to the music. Please advise what I'm missing here. Thank you.
