stream captured sound
  • uncleX
    • Sep 2015
    • 8
    I'd like to stream the sound that I have captured through Asset Upnp to another application (Vlc, iTunes).
    Which port and furher info should I use?
    kr
    Peter
    • 46189
    Re: stream captured sound
    The other application has to be UPnP compatible, you can capture from iTunes, etc, but not to.
    No ports need to be set, it works on the standard asset streaming port.
    • uncleX
      • Sep 2015
      • 8
      Problem is that I cannot 'see' the asset UPNP server in itunes. I would expect it to be at the top left where you can switch between libraries.
      Alternative I thought of was using the "open stream" functionality in itunes. In this box you can input the URL. I have had positive experience with JamCAst this way.
      By using iTunes I can directly distribute the PC sound to several AirPlay receivers, thus creating cheap multiroom
        • 46189
        iTunes is not UPnP compatible, you will never see any UPnP server.
        • uncleX
          • Sep 2015
          • 8
          Right
          But how about the alternative: Jamcast is able to stream to a userdefinable port, which Itunes can access by "Open stream".
          I woudl expect Asset upnP to have such a functionality also
            • 46189
            If you enable debug mode for asset, you can then browse to the Sound Card Capture item and see its URL.
            • uncleX
              • Sep 2015
              • 8
              is it something like : http://192.168.1.100:26125/content/c...o11.forced.mp3 ??
              • uncleX
                • Sep 2015
                • 8
                Is it something like http://192.168.1.100:26125/content/c...o11.forced.mp3 ?
                  • 46189
                  Yes, try pasting into a web browser on a different PC.
