Asset does not work with QNAP 4.2 firmware
  • pafal
    • Jul 2014
    • 11
    Just upgraded to QNAP QTS 4.2 and Asset no longer works. It is flagged as not supported by the firmware and is shut down.
    QTS 4.2 is in RC1 now and the general release is likely to be a month away so a recompiled Asset for QNAP would be timely.
    • 46189
    Re: Asset does not work with QNAP 4.2 firmware
    Which QNAP do you have?
      • 46189
      I have updated to 4.2, and yes there is a message that Asset is not compatible, but it also says that:
      Multimedia Station, QDK
      are not compatible either.
      Looking at Asset it is running normally though. The 2 other apps are QNAPs own apps (multimedia station is built into the firmware...), I suspect this error message is not a real one.
      • pafal
        • Jul 2014
        • 11
        I have a TS-869U-RP.
        https://www.qnap.com/i/sv/product/model.php?II=30
        If i reboot the NAS it will stop, or not start, Asset UPNP with the informative message that the application is no longer supported by this firmware.
        But if I go into the app center and start Asset UPNP manually it will stay "on" and not be shut down. All working as it should.
        So with this work around I can get Asset UPNP to work on the NAS with RC1 firmware.
        • Klaus57
          • Dec 2014
          • 9
          I use QNAP HS-210, it works without any problems with Firmware 4.2 and Asset 4.5.1
          • Patatorz
            • Feb 2013
            • 12
            I use a TS-251 : I have an error message (same for BubbleUPnP server) but even after few reboots it works.
            BR
            • pafal
              • Jul 2014
              • 11
              Just installed the RC3 of the Qnap firmware. The messages regarding incompatibility of Asset 4.5 are now gone.
