Low quality of Up Stream Artwork
  • Mihaylov
    • Jun 2014
    • 23
    The quality of folder covers (for example, of album artists) is very poor when Up Stream Artworks option enabled. Why? Is it possible to make something to improve quality of folder covers?
    Please to compare the two screens:
    Sizes of covers are 600x600 pixels.
    • 46231
    Re: Low quality of Up Stream Artwork
    Which Asset version do you have? what is asset running on? this picture of the control point, what is the control point?
    • Mihaylov
      • Jun 2014
      • 23
      Asset 5 for Windows XP. Running on my NAS DIY: Gigabyte-ga-c1037un-e, imbedded CPU Celeron 2 Core 1.8 GHz, RAM 2 GB, SSD 2TB for audio library, SATA DOM 4GB for OS. Control Point - Lumin 5.0 and Linn Kazoo.
        • 46231
        What is the browse you do to get to the 2 artworks above?
        • Mihaylov
          • Jun 2014
          • 23
          OK
          I use my own navigation tree and my own AssetImages:
            • 46231
            For Asset to supply the art in the upstream it has to resize the art as it makes no sense on supplying full size art when there are 300 album artists shown as sending over full resolution art would slow the browse. The art is resized using the GDI built into windows, this is limited to the color space of Windows, so make sure that Windows is set to true colours (32 bit or 24 bit).
            Looking a your screenshot of the configuration program it looks like 256 colors...
            • Mihaylov
              • Jun 2014
              • 23
              Yes. It's 256 colors (8 bit).
              OK, I will try to set 24 or 32 bit.
              • Mihaylov
                • Jun 2014
                • 23
                I set depth of color 32 bits in the register and made Refresh All in the Asset UPnP Configuration and now everything is all right.
                Thanks!
