Asset and NFS problems ?
  • ccrider
    • Sep 2011
    • 9
    Since using Asset to stream my audio files from my server I have problems streaming video files. I use NFS - Protocoll for streaming files to a Dune player, and now every 5 to ten minutes or so (did not check this exactly) the video / film stops for a second and is juddering with artefacts until it continues normally after some seconds . If Asset ist checking periodically for changes, could this be a reason for this behaviour ??
    • 46231
    Re: Asset and NFS problems ?
    You can disable Asset from automatically checking (which is based on file changes only), in Asset Configuration >> Advanced Settings >> uncheck 'Detect and catalog new tracks'
    • ccrider
      • Sep 2011
      • 9
      Ok, thanks ! I will try that and post results ...
      Do you know how often Asset is checking automatically ?
      • ccrider
        • Sep 2011
        • 9
        So, I have unchecked automatic scanning and restarted Asset, but it did not solve my problem.....
          • 46231
          Quit asset (set to disabled), I do not think Asset is causing the problem.
          • ccrider
            • Sep 2011
            • 9
            Ok, will check that....thanks for your help so far !
