Constant and regular stuttering with Asset Upnp and PS3
  • armitage
    • Jan 2011
    I installed yesterday Asset Upnp in order to benefit from the replaygain when streaming music to my PS3. The media server is correctly detected and I can browse smoothly between the different artists, albums.
    The problem is that when I try to play a file (all files in my library are flac), I will have microcuts every 2 to 3*blooper*seconds before the music keeps playing.
    I set the flac files to be transcoding as LPCM ( the override for wav being removed) and uncheck the L24*blooper*playback for now.
    The problem appears on both 16bits and 24bits playback.
    My ps3 is connected through ethernet to my wifi n rooter, while my pc is using wifi.
    I am sure it is not a problem signal strength as I am able to stream flawlessly 1080p movie with PS3 media server along with any kind and music.
    I*blooper*have also the same issue with foo_upnp the dnla server of foobar2000.
    Could it be the replaygain that is causing this problem as this is the function I am trying to use? Or could it be some weird problem between Asset Upnp and my wifi rooter?
    My PC*blooper*is showing 0% usage when transcoding (I7 at 3.5Ghz with 12Go of Ram) so I am confident it is not struggling with the transcoding.
    Thank you in advance for your input.
    • 46231
    Re: Constant and regular stuttering with Asset Upnp and PS3
    Wifi is the issue as it is going from the laptop over wifi to the ps3, this is causing the breakups.
    • armitage
      • Jan 2011
      Hi Spoon,
      Thank you for your input. I though it was, is it any setting I could improve on Asset Upnp or my rooter to fix this issue?
      I have trouble to understand how the wifi could be the cause, knowing that I can stream 1080p video or HD audio with other media server and that my wifi link speed never comes under 243MB/s when using Asset.
      When I experienced some stuttering with 1080p video, my link was always close to 0MB/s usually due to the interference with the neighbour's wifi coupled to the strain of the HD*blooper*movie.
      This is not the case with simple audio and my wifi do not drop.
      Any specific suggestion that would not involve pulling out a ethernet cable throughout my flat?
        • 46231
        As a test connect a cable into your computer, thus bypassing the wifi
        • armitage
          • Jan 2011
          I*blooper*will try to do that if I come across some ethernet cable long enough.
          I had opt that I did something wrong through the settings.
