Asset UPnP on Bravia TV setup problem
  • Alfaman
    • Sep 2009
    Hi
    I am trying to get Asset UPnP (current beta version) to work from a Vista PC to a Sony Bravia KDL-40W4500 TV that is dlna certified.
    Before I installed Asset I could see and play my music files over the network on the TV and browse what looks like the Windows Media Player library, playlist etc. With Asset installed it is showing up under Network in Vista as a media device as is my PC/user name as a second media device. In Windows Media Player library Asset shows up on the left under Library with a small networked PC icon.
    When I look for Assets on the TV it is missing but the network diagnostics on the TV finds it with ip no., port no.etc. but with the problem "Compatible files could not be found" and will not list it to browse. The TV is seeing it OK but can find no files. Asset is pointing at the same folder as Media Player library. Have I missed something in the setup or has anyone used it on a Sony TV before?
    Sorry for being long-winded..
    • 46231
    Re: Asset UPnP on Bravia TV setup problem
    Try v2 of Asset (in the beta section of this forum)
    • Alfaman
      • Sep 2009
      Yes I have that version running - version: release 2 (beta)
      • chrisrd
        • Nov 2009
        • 13
        I've just received my RipNAS and am also trying to use my Sony Bravia 40Z4500 with Asset (Release 2) without success. The devices are joined via hard-wired ethernet and both are pingable from my laptop.
        If I go into 'Server Display Settings' in the TV setup area I get:
        Servers cannot be recognised.
        Please check the connections,
        press OPTIONS key and select "Update List".
        Going into "Update List" as suggested produces the same message.
        Using the 'Server Diagnostics' on the TV I get:
        Asset UPnP: RIPNAS Failed
        If I turn on Media Library Sharing on the RipNAS I also get:
        RIPNAS: 1 : Windows Media Connect Failed
        The 'RIPNAS' part of the diagnostics indicates the TV is able to see the RipNAS.
        Any hints on how to further diagnose this problem? (If it helps running any diagnostics etc., my laptop is running Ubuntu 9.04).
        • chrisrd
          • Nov 2009
          • 13
          As a reference point, the Bravia works with DLNA from my Ubuntu laptop using minidlna:
          Download ReadyMedia for free. ReadyMedia (formerly known as MiniDLNA) is a simple media server software, with the aim of being fully compliant with DLNA/UPnP-AV clients. It was originally developed by a NETGEAR employee for the ReadyNAS product line.
            • 46231
            There will be an update for Asset v3 (in the beta section of our forum) next week which passes all the DLNA compliance tests. It might help.
            • chrisrd
              • Nov 2009
              • 13
              As a further note: I found that I can click on this 'Failed' line and get some more info:
              Compatible files could not be found.
              Server Asset UPnP: RIPNAS
              UDN uuid:1006065e5-<<<more>>>
              IP Address 192.168.<<<more>>
              MAC Address 00:1c:<<<more>>>
              TCP Port 26125
              This is with Asset configured to use a test directory containing a single mp3 file.
              I downloaded Asset v3 BETA today to test this but unfortunately with no success.
                • 46231
                The sony might be going in through a search into UPnP, try enabling the debug option in Asset Configuration, let the sony try to connect then see if the log can show anything.
                • chrisrd
                  • Nov 2009
                  • 13
                  Nothing in the log at all I'm afraid.
                    • 46231
                    The log was totally empty?
                    • chrisrd
                      • Nov 2009
                      • 13
                      Yup. Size zero.
                      ....hmmm, that's odd. If I turn off the 'Output Debug Log' flag, and after Asset restarts itself, the debug log has:
                      Triggering Database Rescan (MediaFoldersWatch.txt changed)
                      Turning on the flag again, the log size goes back to zero.
                      • AndrewFG
                        • May 2010
                        • 59
                        I have a Sony Bravia KDL-40W4500. Yesterday I tried it with Asset v2.1 Release and the latest v3 Beta both running on Windows XP SP3. And in both cases I experienced exactly the same problem as the OP did. I see this thread has been dead for sometime, so I wonder if there is any other news?
                          • 46231
                          It seems to be that Sony TV which is having trouble detecting it, the Sony PS3 has no such problem.
                          • AndrewFG
                            • May 2010
                            • 59
                            I think that the Discovery part of the UPnP process is working, since the Sony TV does seem to discover your server. So my guess is that when the Sony tries to download your UPnP/DLNA Device Description Document or SCPD, it is detecting a syntax error in your XML payload (or maybe in the HTTP headers)...
                            In a day or two, I will install a network sniffer, and send you some captures of what your server is sending vs. what other servers are sending. So that you can perhaps determine the missing syntax element...
                            • AndrewFG
                              • May 2010
                              • 59
                              Ok. Here are the first few bugs that I found so far in Asset:
                              1) Asset is not responding to valid UPnP M-SEARCH requests. This means that the official UPnP certification test tool cannot even find Asset so the tool cannot even start the test suite on it...
                              2) In Asset's device descriptor document there are at least three syntax errors:
                              - in <iconList> it is providing references to two <mimetype>image/jpeg</mimetype> icons, but in both cases the actual icons that it delivers are BMPs
                              - the <eventSubURL> ends in event.xml; but this is a url for HTTP POST so properly this should not be a file name
                              - ditto for the the <controlURL> ...
