Problems after resuming from hibernation
  • Ratty
    • Jan 2009
    • 14
    My machine which runs Asset (XP SP3) is generally hibernated overnight. It seems that after a reasonable period of hibernation - say 1+ hrs - Asset doesn't want to function once the machine resumes. Its ports are still listening, it's still context-switching, but it fails to show up in Sonos until the service has been manually restarted. Hibernating for a brief period doesn't trigger this problem.
    If it's an intractable issue a simple workaround would be to have the Asset service automatically restart itself on machine wake-up.
    EDIT: Is there a command line switch for AssetConfig.exe to exit the child processes and restart the service without going through the GUI?
  • Ratty
    • Jan 2009
    • 14
    Re: Problems after resuming from hibernation
    Ah. I see that NET STOP terminates it gracefully. :o
      • 44052
      Try the Beta 2 version (in the beta section of the forum).
