Discussion of dMC R12 Alpha
This topic is closed.
    Re: Discussion of dMC R12 Alpha
    If I'm reading it correctly, a buffer is used to hold data that is being read. Cache is used to reduce accesses to the CD drive.
    • Spies
      • Aug 2006
      • 37
      Spoon, the AMG meta data is awesome! Since the data is so complete I would love to see a user selectable option to combine those tags that have multiple entries per song, such as artist and composer, into one tag with a delimiter, such as a semicolon.
      Using a FLAC file as an example:
      Composer=Rick Davies
      Composer=Roger Hodgson
      Becomes:
      Composer=Rick Davies; Roger Hodgson
      Would love to see Styles as a meta data option too. The more data data from AMG the better. I also see that FLAC 1.1.3 will have support for cover art. The beta is out now. Hopefully you will be able to integrate it soon. Looking forward to Replay Gain tag support as well. And while I am thinking about it will your "dBpowerAMP Reference" edition be able to handle changers such as the Sony VGP-XL1B2 changer? That would be awesome! Can hardly wait to see what the next Alpha brings.
        • 43930
        Becomes:
        FLAC uses Ogg tags, the two seperate composers are correct for Ogg Tags, it is upto the audio player to recombine them.
        Flac album art should be relatively soon (the current beta has no means ot manipulate the art data).
        • gaillard
          • Aug 2006
          • 51
          hey spoon, with the wavpack encoder, is there a way to use the -x option for asymetrical encoding?
          • Vulcan
            • Aug 2006
            • 27
            Spoon, I am having trouble with alpha 7 in secure mode.
            Upon trying to rip any track, I get an error lik the the following:
            Error ripping to Test Conversion, 'Track 3' to 'E:\My Music\FLAC\Kara's Flowers\Fourth World (1997)\03 Myself.IGNORE'
            Unable to read CD, check CD disc (frame LBA 33306) [clRipperSecure::Rip]
            I did uninstall the previous alpha and 11.5 before installing, and this is the first time I have encountered such a problem. Please feel free to email me if you need any more information.
              Can you rip when in Burst mode?
              • gaillard
                • Aug 2006
                • 51
                Thats how errors that it cannot read through are reported i beleive. There is a bad error on that cd. plus if you have that new option checked all errors look like that (yay! =))
                • gaillard
                  • Aug 2006
                  • 51
                  guess i'll just have to keep using the cli encoder for -x option, any plans for this in the future?
                    • 43930
                    Is it popular?
                    This error means the CD drive is unable to return any data for that track, technically it is a failure of the drive, as normlly even rubbish data is always returened. After this (I have seen it on one of my drives) Windows will normally put the drive into PIO mode, there should also be an error written into the Windows Event Viewer.
                    • gaillard
                      • Aug 2006
                      • 51
                      I would hope its popular since david is putting it into the next version as default, although not the highest -x mod but still putting -x as default. with no decoding time reduction people would be foolish not to use it.
                      Also i was wondering if you wouldn't mind making it where for the cli encoder, if we can still pass things from the artist, date box to the cli line without them automatically being added to the meta data. Because the meta data i am using for things like accuraterip results and source and encoded by but still want to pass my own things to the cli line, is this possible? thanks spoon. Its looking really good.
                      • bhoar
                        • Sep 2006
                        • 1173
                        Is it popular?
                        I assume SCSI drives are immune from the UDMA->PIO symptom?
                        Also, "CD disc" is about 1/3 redundant.
                        -brendan
                        • gaillard
                          • Aug 2006
                          • 51
                          This is interesting to me spoon because for example, if i put a big fat finger print on a disc, accurateRip always comes back with cannot read cd, not garbage data. But everything is ok with me as long as all errors are reported, i just want to know that there are no errors in the music.
                            • 43930
                            I will be moving over to the new version soon, so that will self sort it's self.
                            Yes I would think so.
                            The previously mentioned error is a very specific one, and has nothing to do with normal cd ripping (if you see that error it would fall under the error tab, not information).
                            • Vulcan
                              • Aug 2006
                              • 27
                              Yes. Burst mode works perfectly.
                              • gaillard
                                • Aug 2006
                                • 51
                                Most erros i get do fall under the error tab, such as a fingerprint. Many many times this has happened.
