script converting full directory with sub-dirs
  • gnd
    • Sep 2002
    Hi all.
    I'm trying to write vbs script to convert files to ogg. it works on single file, but i cannot figure out how to convert full directory. Or what i really want: to convert full directory structure with all sub-directorys.
    What i want to achieve? I have tons of loops that i want to convert to ogg (many thousands of files), so what i want is to select root-dir of loop dir-structure, and just convert all to ogg in one step, replacing all original files.
    now my script looks like this:
    ' Create dMC Object
    Set dMC = CreateObject("dMCScripting.Converter")
    ' Set My options (Volume norm off, ID Tag Preservation On, No delete Source files)
    dMC.VolumeNormalize = False
    dMC.PreserveTags = True
    dMC.DeleteSourceFiles = False
    ' Set Output Folder (to C:\Conversion123 )
    dMC.ConvertToFolder = False
    ' dMC.ToFolder = "C:\Conversion123"
    ' Add My Files to Convert
    Call dMC.AddFromFile("D:\loops\mm\AMBIENT\120BPM\BASS\b ass_a1.wav")
    ' Convert To ogg (want option page, Want Overwrite page, Want finished, Want Errors)
    Call dMC.GoConversion("Ogg Vorbis", False, False, True, False)
    please help.
    thnx
    gnd
    • 43929
    Have you seen the File Selector addon for dMC?
    Set it to preserve path, and set output to the drive it is on.
    • gnd
      • Sep 2002
      thnx for info.
      well, i figured out another way. I make plylist *.m3u, then i right click on it and "convert to". Works perfectly. I converted 22.000 (22 thousand) files in one run. I think thats preety amazing. Works great. Very stable. Great software.
      one thing...
      Is there a way that it automatically converts mono files to mono ogg, and stereo to stere ogg. That would be nice. And it should use half of stereo bitrate for mono files.
      gnd
        • 43929
        Not at the moment, if you load the files into my Audio Player dAP - you coudl sort on channels and just convert the 1 channel ones.
