Included Help file problem
  • Corin
    • Sep 2005
    This is more of a nit-picking concern, but I thought the developers might want to know that the link to the forum that's inlcuded in the Trouble.htm help file isn't correct - I just bought/registered a version of dbpowerAMP CD Writer and was looking for a weird specific answer when I discovered this. Obviously, I was able to find the forum on my own, but again I thought someone might want to know.
    Thanks, great work guys!
  • Corin
    • Sep 2005
    Specifically...
    Forgot to inlcude the link that's in the file...this is it.
    [<a href="http://www.dbpoweramp.com/forum.htm">Forum</a>]
      Re: Specifically...
      Its right in my version (dMC r11.5rc2). Are you using r11? If so, its been updated since then.
        • 43930
        Re: Specifically...
        Thanks, will look into it.
          Re: Included Help file problem
          Spoon, if you are looking into those help files, please have them open into a new window. As it is they open into the currently opened browser window. Use target="_blank" .
            • 43930
            For the main indexes? I always thought for the first page it was the fact the shell was calling it (like setting start >> run).
              Hmmm, I don't know, Spoon. There must be a way to have it open into a new window of its own. Right now it jumps into whatever window happens to be open.
              I have a web building programs (Dreamweaver) that did that too when viewing a page in webview, until I found an option in it to open a new window. So it must interface somehow using some parameter.
              But I don't know how you'd have to do it.
                • 43930
                I fixed it, was nothing to do with the file, but how ShellExecute in Spoon Installer works, was calling with "open" verb, it needed a NULL passing...
                  Super .... now we have a new download in a beta?
                    • 43930
                    No it will go for live release this week, I am 99.999999999% there is no issue changing that small bit of code.
