problems
  • Devo512
    • Aug 2005
    problems
    upon installation for my db i keep havingthe same re occurring error
    it reads Error:
    Programfiles/illustrate/dbpoweramp/svetaconfig.exe
    can any one please help me?
    Re: problems
    It looks like you have installed Sveta. Have you also downloaded and installed dBpowerAMP Music Converter (dMC) and the Power Pack? If not, Sveta relies on dMC to do its work. And this means you need to download and install dMC.
    If you have downloaded and installed dMC, then did you install it in the default location or not? And have you installed these with administrative priviledges on the computer you are using or not?
    If the answers to these questions are all "yes", I would recomend that you uninstall Sveta, re-start your computer, and re-install Sveta.
    Please let us know how you make out.
    Bill
      • 43928
      Re: problems
      Sounds like you havn't installed Sveta, rather just a Sveta driver.
