Help running Script!
  • WickedGeek
    • May 2005
    I am running the following script against a test.wav file.
    ' Wave Converter
    Set objArgs = WScript.Arguments
    For I = 0 to objArgs.Count - 1
    filepath = filepath & objArgs(I) & " "
    Next
    ' Set Mp3Settings = CreateObject("dMCScripting.Mp3Settings") ' Create Mp3 Object
    ' Call Mp3Settings.Set (128, 44100, 0, 0) ' 160kbps 44.1Khz Stereo CBR
    ' Create dMC Object
    Set dMC = CreateObject("dMCScripting.Converter")
    ' A Returned Compression Codec can be passed onto GoConversion
    cc = dMC.GetCompressions(2) ' Return a Compression Codec (position 0)
    ' Set My options (Volume norm off, ID Tag Preservation On, No delete Source files)
    dMC.VolumeNormalize = False
    dMC.PreserveTags = True
    dMC.DeleteSourceFiles = False
    ' Puts converted file into same folder
    dMC.ConvertToFolder = False
    ' Add My Files to Convert
    Call dMC.AddFromFile(filepath)
    ' Convert To Wave (No option page, Want Overwrite page, Want finished, Want Errors)
    Call dMC.GoConversion("Wave", True, True, False, False)
    I get the following error.
    Support for the audio type '.wav' might be obtained at 'Codec Central' ....
    Does anyone know how to fix this error?
    • 43930
    Re: Help running Script!
    Try adding a file such as c:\test.wav
    • WickedGeek
      • May 2005
      I tried appending a file path with no luck. I copied test.wav to the c root and ran the following command convertwav c:\test.wav. I got the same error message. I must be something simple, just don't know what it is.
        • 43930
        Try converting that wave file normally with dmc.
        • WickedGeek
          • May 2005
          Converting it manually works fine. What does the error mean?
            • 43930
            It means the music converter has not been able to load its codecs.
            • WickedGeek
              • May 2005
              Any suggestions on why this could be happening? It's working fine when I manually convert. Doesn't dbpoweramp by default has a built in wav file converter? Am I doing something wrong in the code?
                • 43930
                It does and that is the odd part. Try putting your executable or script code in the same folder as musicconverter.exe
