How do i ... =p help!
  • ybw89
    • Apr 2005
    Hello, i've got many songs that a seperate files, but are one song.
    how do i bunch em up into 1 file?
    Re: How do i ... =p help!
    Download Audacity for free. A free multi-track audio editor and recorder. Audacity is a free, easy-to-use, multi-track audio editor and recorder for Windows, Mac OS X, GNU/Linux and other operating systems. Audacity is free software, developed by a group of volunteers and distributed under the GNU General Public License (GPL).
    • ybw89
      • Apr 2005
      wat download are u referring to?
        The one appropriate for your OS.
        • ybw89
          • Apr 2005
          Ok so its audacity rite?
          i'm having trouble using it, please give me a basic idea oh how to use this program
            Sorrym I can't because I've never used it myself. It should have its own help file.
            • ybw89
              • Apr 2005
              LOL thnks for tryin' help me Chris,
              Anyone know how to Bunch up multiple files in 1 song..
              Or any1 got any other programs they can share with me
              • Craze
                • Oct 2002
                • 308
                Hello ybw89,
                Basically what you want to do is open up the first song that you're wanting to string together. This will become the main window for compiling all of your tracks to for your final mix.
                Next open up the second song. From the second song file window click Edit/Select/All and Copy.
                Return to the first song window and click on the button that looks like the Fast Forward button but is actually "Skip to the End" button. Click Edit/Paste. Repeat for the rest of the songs you want to string together.
                Save it when you're finished.
                This is a great little program to compliment your Illustrate products.
                Best Wishes.
                -Craze
