Converting 2 Wave. Need Help!!!??
    Below is my code. when the .GoConversion is called the Error Log window pops up with error "The CODEC required to compress". Am I doing somthing wrong. please help.
    But I can right click the .mp3 file in Explorer and convert to Wave without any problems.
    If (oDMC Is Nothing) Then
    Set oDMC = New DMCSCRIPTINGLib.Converter
    With oDMC
    .VolumeNormalize = True
    .PreserveTags = True
    .DeleteSourceFiles = True
    .ConvertToFolder = True
    End With
    End If
    If (oDMC_WavSettings Is Nothing) Then
    Set oDMC_WavSettings = New DMCSCRIPTINGLib.WaveSettings
    oDMC_WavSettings.Set 44100, 2, 64
    End If
    For Each oFTempFile In aFSourceFolder.Files
    If (UCase(Right(oFTempFile.Name, 3)) = "MP3") Then
    oDMC.ToFolder = aFSourceFolder.Path
    oDMC.AddFromFile oFTempFile.Path
    oDMC.GoConversion "Wave", True, False, True, False
    -Parma
    • 43929
    Shouldn't it be 16 on the end for 16 bit?
      Thanks Spoon
      dBpowerAMP is really cool program. I am very glad that I found this gem of util.
      I would like to contribute to this cool product. Please let me know what is the procedure/policy.
      And also, Is there way to suppress the progess window when the convertion is started?
      -Parma
        • 43929
        There are no options for hiding to progress.
          Another question related to dAP
          I copied the code below into a VB function, and at run time in this line, I get an error message "ActiveX component can't create object"
          Set Multiplayer = CreateObject("dBpowerAMP.Multiplayer")
          Since I have used dMC by adding a reference to it in VB, I tried to do the same. but could not find anything in the references window. I also searched the registry for the progID "dBpowerAMP.Multiplayer" and did not find any.
          Please help.
          -Parma
          • daren
            • 153
            Hi unregistered,
            When you say "I would like to contribute to this cool product"
            do you mean by writing codecs, DSP's, etc...?
            The procedure is simple; create the components (examples
            available on the developer page) and send them to Spoon to
            be put on the download page.
            The beta forum is also useful to get codecs tested before releasing.
            What were you thinking of creating?
            Best regards,
            Daren.
