Autoclose window after conversion has finished
  • DikkieDick
    • Dec 2004
    Hello,
    After I've converted a bunch of files I always have to click Finished to close the window. At my office it autocloses. I can't find a setting to change the situation at home to my office-situation. I've plunged through the registry but nothing. How can I get Music Converter autoclose after conversion?
    Greetings, Dick
    Re: Autoclose window after conversion has finished
    Originally posted by DikkieDick
    Hello,
    Greetings, Dick
    That would be the checkbox in Powerpack from dMC: Skip finished message.
    • DikkieDick
      • Dec 2004
      Seems logical to me, only I don't use Powerpack. I only have Dbpoweramp music converter (dmc-r11.exe).
        Do you have the same OS at home as at the ofice? Do you run it from a shortcut? is there some parameter you use in the shortcut at the office that might explain why it autocloses there but not at home?
        Or is it run minimized at the office and the button just sits minimized in the task bar, but hidden due to the way XP handles minimized windows buttons?
        • DikkieDick
          • Dec 2004
          Christina,
          Well, almost the same. At home I'm using XP Home Edition and at the office we have XP Prof. I run converter from the explorer-window by rightclicking on a bunch of MP3s. There's no button sitting in the taskbar.
          At home I had v10, now v11, same as at the office.
          Greetings, Dick
            That's just it - there should be a button in the taskbar showing an open window - if it is open. XP is weird with this, it hides buttons. other than that I have no other ideas for troubleshooting, sorry.
