Results 1 to 2 of 2
Thread: Dsp effect "Write silence" does not write milliseconds as described in help
  1. #1
    Join Date
    Mar 2022
    I wanted to batch process some files of mine and put exactly 25ms in front and at the end of each file with the dsp effect "write silence" as described here: https://www.dbpoweramp.com/Help/dMC/...*Write_Silence.
    When I set it to "00.00.25" it adds 25 seconds instead of 25 milliseconds - what am I doing wrong?
  2. #2
    Join Date
    Apr 2002
    Re: Dsp effect "Write silence" does not write milliseconds as described in help
    Using Windows or OS X?
    On Windows there is a specific box for ms, a box for seconds and one for minutes.
    See right at the end of the page:
    https://www.dbpoweramp.com/Help/dMC/dsp.htm
    How are you entering "00.00.25"?
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
