Shortcut?
  • TJoerg
    • Jan 2022
    • 22
    Shortcut?
    When I change the Genre I always have to scroll down by mouse which is very time-consuming.
    In other software I just click the first letter to jump but in AR it doesn't work (on MAC).
    Is there any other shortcut for it?
    Thanks!
    • 5747
    Re: Shortcut?
    I'm confused regarding what sotware you're using? dbpoweramp CD ripper, dbpa converter, PerfectTunes, or ????
    • TJoerg
      • Jan 2022
      • 22
      Re: Shortcut?
      I'm using dbpoweramp CD ripper
        • 5747
        Re: Shortcut?
        In CD ripper, I simply type in the genre I'm applying to the album or track. I don't use a mouse for this at all.
        • TJoerg
          • Jan 2022
          • 22
          Re: Shortcut?
          Of course this works too, but I wanted to use the scroll-down-menu / column bar like I do in ANY other software.
            Super Moderator
            • 1365
            Re: Shortcut?
            You are using the top bar genre box in CD Ripper, correct?
            If you type first letters of the genre, it should auto complete the rest of it. It might be that it doesn't do this for you because its auto-completion is case-sensitive, seems to fill the rest only if you start with a capital letter, such as fill with "Opera" if you type "O", but not "o".
            I can see how this can be annoying and will look into addressing it.
