Total Track *
  • TJoerg
    • Jan 2022
    • 22
    Total Track *
    In the past I ripped CD's with MEDIA CENTER which is writig the total track amount in a column.
    Unfortunately AR don't.
    How can I change this? Thanks!
    • 4015
    Re: Total Track *
    I think you might mean CD Ripper and not AR?
    You are able to add tags in CD Ripper, prior to ripping.
    • TJoerg
      • Jan 2022
      • 22
      Re: Total Track *
      Yes, I meant CD-Ripper, sorry!
      I cannot find that field "total tracks".
        • 5752
        Re: Total Track *
        in CD Ripper settings, there is an option to tick related to adding total tracks or total discs.
        • TJoerg
          • Jan 2022
          • 22
          Re: Total Track *
          There are options called:
          -Track number without track count
          -Disk number without disc count
          both of them are unchecked but still it's not shown.
            • 5752
            Re: Total Track *
            with these unchecked, can you confirm that CD rips don't have track count and disc count metadata fields filled in. I don't mean showing in the CD ripper screen, but instead showing up in the metadata tag as written (checking post rip).
              • 4015
              Re: Total Track *
              If you don't use Illustrate's tracktotal tag, use the ID Tag Processing DSP and map tracktotal to the tag you require e.g. totaltrack.
              • TJoerg
                • Jan 2022
                • 22
                Re: Total Track *
                Did you really try?
                It's not there!
Name:	Bildschirmfoto 2022-01-28 um 11.18.07.jpg
Name:	Bildschirmfoto 2022-01-28 um 11.19.56.jpg
                @Spoon?
                • TJoerg
                  • Jan 2022
                  • 22
                  Re: Total Track *
                  Did you really try?
                  It's not there:
                    • 43989
                    Re: Total Track *
                    You should be able to type any value you want rather than select from a list in ID Tag Processing.
                    • TJoerg
                      • Jan 2022
                      • 22
                      Re: Total Track *
                      But do I have to set this value with each CD? I mean the CD-Ripper knows how many tracks are on the CD and it's also in the database how many discs are in the Cover.
                      I really don't get it. If there is an option "Track-number without track count" and "Disk number without disc count" CD-Ripper should use this info and write it in the Tags imho.
                        • 5752
                        Re: Total Track *
                        It does. If I don't tick those two options, in my tags I see total tracks and total discs. But there are different metadata fields where different players/servers are looking for different named fields (totaltracks vs tracktotal, etc.). On this point, I don't think you ever responded to my earlier question:
                        edit: in my FLAC rips, the total tracks field is called TRACKTOTAL.
                          • 5752
                          Re: Total Track *
                          Did you really try?
                          It's not there!
                          [ATTACH=CONFIG]3253[/ATTACH]
                          [ATTACH=CONFIG]3254[/ATTACH]
                          @Spoon?
                          I'm not sure it shows up in this "write tags" option section. Confirm that post-rip, a metadata tag field like TRACKTOTAL is showing up in your files. It does for me in my FLAC rips.
                            • 4015
                            Re: Total Track *
                            No. Create a ripping profile, setup ID Tag Processing DSP, and use the profile on every rip.
                            It does, if ripping to flac, using the Windows version and the tag is called TRACKTOTAL. I guess MEDIA CENTER calls it something else.
                            What file format are you ripping to, and can you answer garym's post no. 13?
                            • TJoerg
                              • Jan 2022
                              • 22
                              Re: Total Track *
                              ok, I opened one of the rips in "iTunes" and also in "Amadeus". both of them using format "Track/Title-Nr. 1/9"
                              "TRAKTOR" is using "1 of 9".
                              So it seams the problem is on Media Center which needs an extra field "Total Tracks" or just don't want to translate.
                              I'm using AIFF (Apple) which is similar to FLAC (Windows). Maybe that's the problem, since MC is originally build for Windows.
                              Honestly meantime I'm tired about it and tend to leave it like it is.
                              It would be helpful to have a proper manual for CD-Ripper where it is EXACTLY described how to build those "extra-fields"
