FLAC to Apple lossless tag problem
  • GiAgLiOl
    • Jan 2022
    • 14
    Re: FLAC to Apple lossless tag problem
    We release R17.5 in the next 2 weeks, it could be a change in the background libraries has fixed this issue, but for now on that advanced configuration page, enable the debugging option and convert the file in your image to m4a, the log will show after conversion, paste the contents here please.
    Thank you for your efforts and help!
    • GiAgLiOl
      • Jan 2022
      • 14
      Splitting Command Line:"C:\Program Files\dBpoweramp\CoreConverter.exe" -dbcmd="C:\Users\giorg\AppData\Local\Temp\dBT4B85.t mp"
      ->-> [dBCoreConverter::ReaddBCommandFile]
      <-<- [dBCoreConverter::ReaddBCommandFile]
      Decodes [clDecoder::Get]
      BatchID [clDecoder::Set]
      ->-> [cldBCodecHandler::LoadEncoder]
      Loading Encoder 'C:\Program Files\dBpoweramp\encoder\Apple Lossless.DLL'
      <-<- [cldBCodecHandler::LoadEncoder]
      BatchID [clEncoder_ALAC::Set]
      ->-> [dBCoreConverter::StripCoreConverterCmds]
      <-<- [dBCoreConverter::StripCoreConverterCmds]
      SendRawUnCompressed [clEncoder_ALAC::Get]
      Communicate [clDecoder::Get]
      Communicate [clEncoder_ALAC::Get]
      NeedHQAudio [clEncoder_ALAC::Get]
      ->-> [clDecoder::Open]
      Opening file 'F:\Flac\Racecorner - Radiostation [insectorama] 24bits-2021\01-Racecorner - Getwiedel.flac' for read access: Opened
      Init FLAC:
      Reading Meta Data:
      Contains picture block, size (bytes): 115787 type: 3
      contained 10 tags:
      ALBUM: Radiostation
      ARTIST: Racecorner
      COMMENT: Visit https://insectorama.bandcamp.com
      Year: 2021
      ENCODED BY : grandsrt8
      ENCODER SETTINGS: -compression-level-8
      GENRE: Techno
      TITLE: Getwiedel
      Track: 1
      Album Artist: Racecorner
      ->-> [clDecoder::ReadIDTags]
      <-<- [clDecoder::ReadIDTags]
      ->-> [clDecoder::FillAudioProps]
      Encoder: FLAC reference libFLAC 1.3.2 20170101
      Sample Count: 15,478.055
      ID Tag: Vorbis Comments
      Contains: Album Art, CRC, ID Tag [Vorbis Comments]
      <-<- [clDecoder::FillAudioProps]
      ->-> [clDecoder::FillAudioInfo]
      Uncompressed WFX (sent to db): Format Tag: 1 Channels: 2 Bits per Sample: 24 Samples Per Second: 44100 Bytes Per Second: 264600 Block Align: 6 CB Size: 0
      Audio Length: 350976 mili-seconds 64126488 bytes 2116 kbps
      <-<- [clDecoder::FillAudioInfo]
      Creating Decode Buffers: Created
      <-<- [clDecoder::Open]
      SendOverReplayGainTags [clEncoder_ALAC::Get]
      ->-> [clEncoder_ALAC::BeginConversion]
      Converting to 'F:\Flac\Racecorner - Radiostation [insectorama] 24bits-2021\01-Racecorner - Getwiedel.m4a' encoder settings ''
      <-<- [clEncoder_ALAC::BeginConversion]
      Encoding To: Apple Lossless
      Encoder Cmd Line:
      ->-> [dBCoreConverter::CloseDecoder]
      ->-> [clDecoder::Close]
      <-<- [clDecoder::Close]
      ->-> [clEncoder_ALAC::EndConversion]
      <-<- [clEncoder_ALAC::EndConversion]
      File Size Check : 64461711 bytes Filename: F:\Flac\Racecorner - Radiostation [insectorama] 24bits-2021\01-Racecorner - Getwiedel.m4a
      File Size Check (before ID Tags Written): 64461711 bytes Filename: F:\Flac\Racecorner - Radiostation [insectorama] 24bits-2021\01-Racecorner - Getwiedel.m4a
      ->-> [dBCoreConverter::IDTagWriter]
      Decodes [clDecoder_M4A::Get]
      IDTags [clDecoder_M4A::Set]
      Writing ID Tags to m4a: [clDecoder_M4A::WriteTheseTags]
      ALBUM: Radiostation
      ARTIST: Racecorner
      Year: 2021
      GENRE: Techno
      TITLE: Getwiedel
      Track: 1
      _albumart_1_Front Album Cover<subdesc>cover: [DATA] FF D8 FF E0 00 10 4A 46 49 46 00 01 01 01 00 48 00 48 00 00 FF DB 00 43 00 05 03 04 04 04 03 05 04 04 04 05 05 05 06 07 0C 08 07 07 07 07 0F 0B 0B 09 0C 11 0F 12 12 11 0F 11 11 13 16 1C 17 13 14 1A 15 11 11 18 21 18 1A 1D 1D 1F 1F 1F 13 17 22 24 22 1E 24 1C 1E 1F 1E FF DB 00 43 01 05 05 05 07 06 07 [clDecoder_M4A::WriteTheseTags]
      <-<- [dBCoreConverter::IDTagWriter]
      ->-> [clDecoder_M4A::Close]
      <-<- [clDecoder_M4A::Close]
      ->-> [aacstream::clDecoder_M4A::Close]
      <-<- [aacstream::clDecoder_M4A::Close]
      Conversion completed in 2,3 seconds x152 realtime encoding
      File Size Check (core converter exit): 64580101 bytes Filename: F:\Flac\Racecorner - Radiostation [insectorama] 24bits-2021\01-Racecorner - Getwiedel.m4a
        • 43928
        can you upload that exact file to dropbox (the m4a file) and post a link please.
        • GiAgLiOl
          • Jan 2022
          • 14
          <edited>
            • 43928
            Convert the flac file to apple lossless and send us the m4a file please.
            • GiAgLiOl
              • Jan 2022
              • 14
              #21
              I have sent you a private message with the link.
              • GiAgLiOl
                • Jan 2022
                • 14
                #22
                I am facing also this problem:
                In the m4a file, I am filling out the info in the tag using ID-Tag and at the end I click "OK". The file doesn't keep that info!
                  • 1748
                  #23
                  Where are those files stored? In a special folder i.e. that is under control of iTunes or software like that?
                    • 43928
                    #24
                    We have found the issue, R17.5 will fix, we release in the next 2 weeks.
                    • GiAgLiOl
                      • Jan 2022
                      • 14
                      #25
                      Thank you very much! You are the best!
