2 Questions about CD Ripper - De-emphasis ticked option and Cross-pressing verif.
  • krafty
    • Dec 2021
    • 44
    Hi Spoon and team,
    I have two questions:
    Question 1
    Option:
    [X] Apply De-emphasis to CD tracks marked with Pre-emphasis.
    Regarding this setting, I had the "Track Technical" column hidden for a while (because it is the default layout). This is a three-fold question:
    a) Will this column show up out of nowhere when you insert a CD with Pre-Emphasis flag on the tracks?
    b) If there is any action here that CD Ripper takes, it will be registered in the .log file, thus, if any CD was de-emphasized, then the log will tell me it was, otherwise it won't say a thing, is that correct? None of my CDs had a alert about de-emphasis. Reason I ask is because I don't think I have any CD like that (Low-Life was one of the, and Please from Pet Shop Boys too) and I am just a little cautious about settings that change audio.
    c) In the process of de-emphasizing the CD, it will modify the audio. Even going that route, will it still return an accurate rip based on the de-emphasized version of the CD?
    I still think some vinyl rips are better than this de-emphasis process -- it usually removes treble much more than it is desired.
    Question 2
    Option:
    [X] Cross-pressing verification.
    Regard this setting, I noticed that if ONE track gets a second PASS (Pass 2), say, the only track on the CD, this track will not register an entry for a cross-pressing verification, whereas other tracks that do get a Pass 1 Accurate, will return a cross-pressing verification. Example:
    Code:
    Track 1:  Ripped LBA 32 to 22505 (4:59) in 0:31. Filename: D:\MUSIC\ALAC\Nine Inch Nails\Pretty Hate Machine\01 - Head Like A Hole.m4a
      AccurateRip: Accurate (confidence 200)     [Pass 1]
      CRC32: 725895A5     AccurateRip CRC: 656DDA22 (CRCv2)     [DiscID: 010-00124700-00924dc5-6c0b6f0a-1]
      AccurateRip Verified Confidence 200 [CRCv2 656dda22]
      AccurateRip Verified Confidence 200 [CRCv1 10b3ee54]
      AccurateRip Verified Confidence 51 [CRCv2 fc4e6eca], Using Pressing Offset -438
      AccurateRip Verified Confidence 66 [CRCv1 c445ad51], Using Pressing Offset -438
    Track 2:  Ripped LBA 22505 to 43427 (4:38) in 0:26. Filename: D:\MUSIC\ALAC\Nine Inch Nails\Pretty Hate Machine\02 - Terrible Lie.m4a
      AccurateRip: Accurate (confidence 200)     [Pass 1 & 2]
      CRC32: 4D362A45     AccurateRip CRC: EEB04C9E (CRCv2)     [DiscID: 010-00124700-00924dc5-6c0b6f0a-2]
      AccurateRip Verified Confidence 200 [CRCv2 eeb04c9e]
      AccurateRip Verified Confidence 200 [CRCv1 8acd5654]
    Track 3:  Ripped LBA 43427 to 60407 (3:46) in 0:09. Filename: D:\MUSIC\ALAC\Nine Inch Nails\Pretty Hate Machine\03 - Down In It.m4a
      CRC32: 2BF2BE50     AccurateRip CRC: 02115DB0 (CRCv2)     [DiscID: 010-00124700-00924dc5-6c0b6f0a-3]
      AccurateRip Verified Confidence 200 [CRCv2 2115db0]
      AccurateRip Verified Confidence 200 [CRCv1 7a882703]
      AccurateRip Verified Confidence 53 [CRCv2 86092b31], Using Pressing Offset -438
      AccurateRip Verified Confidence 67 [CRCv1 798e69f9], Using Pressing Offset -438
    As you can see above, I did not paste all tracks, but track 02 on this CD is AccurateRip - and has a CRCv2 and CRCv1 check. Tracks 01, 03 to 10 are also registering to the log another two entries for a -438 pressing offset, CRCv2 and CRCv1. The track 02 was the only one that got two passes.
    And I have been seeing this behaviour when it goes 2 passes. Is there any explanation as to way it won't log a cross-pressing verification when it has to go through a second pass?
    Thank you for your attention.
  • BOOTP
    • Feb 2020
    • 67
    Re: 2 Questions about CD Ripper - De-emphasis ticked option and Cross-pressing verif.
    I asked this a while back and the log file will reflect any de-emphasis - see quote from Spoon below.
    HD CD is easy, the tracks will be saved as 24 bit. De-emphasis, a line will be written to the secure ripping log.
    The log file will also reflect HDCD - take a look at the extract below from a recent CD I ripped. Minor point but Spoon does need to add a 'new line' before the 'Extraction Log' starts.
    Code:
    Encoder: FLAC -compression-level-8 -verify
    Track Technical Details
    Track 1: HDCD
    Track 2: HDCD
    Track 3: HDCD
    Track 4: HDCD
    Track 5: HDCD
    Track 6: HDCD
    Track 7: HDCD
    Track 8: HDCD
    Track 9: HDCD
    Track 10: HDCD
    Track 11: HDCD
    Track 12: HDCD
    Track 13: HDCD
    Track 14: HDCD
    Extraction Log
    Track 1:  Ripped LBA 0 to 20505 (4:33) in 0:41.
    • krafty
      • Dec 2021
      • 44
      Thanks BOOTP.
      As I understood, THIS WILL ONLY SHOW UP if it's detected via TOC. If the CD does contain a extreme brightness and it is said to have Pre-Emphasis and it does not show up in TOC, then you will have to apply the DSP on a CD per CD basis.
      • BOOTP
        • Feb 2020
        • 67
        Thanks BOOTP.
        Yes, I do not have a pre-emphasis CD to check, but it is worth adding the Track Technical column in CD Ripper and you will see this information pre-rip. Regardless, the log file will still contain the information you need in order to apply post-rip DSPs if you require.
        A good tip is to search the root folder that contains all your log files via the operating system search facilities. A search like [Track Technical] will filter out only those logs (and thus rips) where HDCD or pre-emphasis is present. Another search I use is [re-rip frame] to check up on those potentially problematic rips.
        By the way, with regards to Question 2 I have not seen this before. In my logs when a pressing offset is used it applies to the entire CD given the whole CD was pressed at a different time or plant. All I can suggest is that the DiscID and associated track does not exist in the AccurateRip database, or has been skipped due to a processing problem - if you really want to check you could re-rip the CD and see what the new log brings. However, the important information here are the AccurateRip CRCs, and given the confidence value is already at 200 you can be guaranteed those ripped tracks are undeniably perfect.
        • krafty
          • Dec 2021
          • 44
          Well, just try it out. Get a CD you know there is a track that will get 2 passes.
          It does make an AccurateRip out of that track.
          However, it will be the only track that will not leave a cross-rip reference.
          All other tracks that gets one pass will have additional 1, 2 or 3 cross-rip references.
          The track that gets 2 passes will only have its own CRCv2 and CRCv1 pressing, logged. Despite it is accurate in the end.
            • 43998
            We will look at this 2 passes issue.
            • BOOTP
              • Feb 2020
              • 67
              OK so on a quick look I found two logs that exhibit the same behaviour you describe on tracks 1 and 3.
              Here is the original log from: dBpoweramp Release 17 BETA 6 Digital Audio Extraction Log from 15 March 2020 21:02
              Code:
              Extraction Log
              Track 1:  Ripped LBA 0 to 21152 (4:42) in 0:43. Filename: C:\Users\X\Desktop\Def Leppard\Acoustic in Singapore\01 Armageddon It.flac
                AccurateRip: Accurate (confidence 63)     [Pass 1]
                CRC32: 4E381FBB     AccurateRip CRC: 7B5E9C50 (CRCv2)     [DiscID: 006-00062951-0020afc9-3805fa06-1]
                AccurateRip Verified Confidence 63 [CRCv2 7b5e9c50]
                AccurateRip Verified Confidence 50 [CRCv1 6494e32d]
              Track 2:  Ripped LBA 21152 to 40407 (4:16) in 0:22. Filename: C:\Users\X\Desktop\Def Leppard\Acoustic in Singapore\02 Two Steps Behind.flac
                AccurateRip: Accurate (confidence 64)     [Pass 1]
                CRC32: 380566A7     AccurateRip CRC: 7F0F3CAC (CRCv2)     [DiscID: 006-00062951-0020afc9-3805fa06-2]
                AccurateRip Verified Confidence 64 [CRCv2 7f0f3cac]
                AccurateRip Verified Confidence 50 [CRCv1 e08c6a43]
                AccurateRip Verified Confidence 2 [CRCv1 9a9b6241], Using Pressing Offset +6
              Track 3:  Ripped LBA 40407 to 57255 (3:44) in 0:18. Filename: C:\Users\X\Desktop\Def Leppard\Acoustic in Singapore\03 From the Inside.flac
                CRC32: 83AE81AF     AccurateRip CRC: AC7E0FBF (CRCv2)     [DiscID: 006-00062951-0020afc9-3805fa06-3]
                AccurateRip Verified Confidence 63 [CRCv2 ac7e0fbf]
                AccurateRip Verified Confidence 51 [CRCv1 8b7053e8]
              Track 4:  Ripped LBA 57255 to 75062 (3:57) in 0:18. Filename: C:\Users\X\Desktop\Def Leppard\Acoustic in Singapore\04 Animal.flac
                CRC32: 19FC015E     AccurateRip CRC: 571CA4AE (CRCv2)     [DiscID: 006-00062951-0020afc9-3805fa06-4]
                AccurateRip Verified Confidence 63 [CRCv2 571ca4ae]
                AccurateRip Verified Confidence 50 [CRCv1 f801a0ee]
                AccurateRip Verified Confidence 2 [CRCv1 22738086], Using Pressing Offset +6
              Track 5:  Ripped LBA 75062 to 95122 (4:27) in 0:19. Filename: C:\Users\X\Desktop\Def Leppard\Acoustic in Singapore\05 When Love and Hate Collide.flac
                CRC32: 41D618F8     AccurateRip CRC: 6466F70E (CRCv2)     [DiscID: 006-00062951-0020afc9-3805fa06-5]
                AccurateRip Verified Confidence 64 [CRCv2 6466f70e]
                AccurateRip Verified Confidence 50 [CRCv1 658b8cbc]
                AccurateRip Verified Confidence 2 [CRCv1 2ba40e05], Using Pressing Offset +6
              Track 6:  Ripped LBA 95122 to 114795 (4:22) in 0:17. Filename: C:\Users\X\Desktop\Def Leppard\Acoustic in Singapore\06 Pour Some Sugar on Me.flac
                CRC32: 9F6727E2     AccurateRip CRC: F362B04A (CRCv2)     [DiscID: 006-00062951-0020afc9-3805fa06-6]
                AccurateRip Verified Confidence 64 [CRCv2 f362b04a]
                AccurateRip Verified Confidence 50 [CRCv1 50d94dbd]
                AccurateRip Verified Confidence 2 [CRCv1 39aad62a], Using Pressing Offset +6
              6 Tracks Ripped Accurately
              Here is a re-rip, and you will note the cross-pressing skip is exactly the same: dBpoweramp Release 17.4 Digital Audio Extraction Log from 31 December 2021 12:16
              Code:
              Extraction Log
              Track 1:  Ripped LBA 0 to 21152 (4:42) in 0:46. Filename: C:\Users\X\Desktop\Def Leppard\Acoustic in Singapore\01 Armageddon It.flac
                AccurateRip: Accurate (confidence 74)     [Pass 1]
                AccurateRip Verified Confidence 74 [CRCv2 7b5e9c50]
              Track 2:  Ripped LBA 21152 to 40407 (4:16) in 0:23. Filename: C:\Users\X\Desktop\Def Leppard\Acoustic in Singapore\02 Two Steps Behind.flac
                AccurateRip: Accurate (confidence 75)     [Pass 1]
                AccurateRip Verified Confidence 75 [CRCv2 7f0f3cac]
                AccurateRip Verified Confidence 74 [CRCv2 ac7e0fbf]
                AccurateRip Verified Confidence 74 [CRCv2 571ca4ae]
                AccurateRip Verified Confidence 75 [CRCv2 6466f70e]
              Track 6:  Ripped LBA 95122 to 114795 (4:22) in 0:18. Filename: C:\Users\X\Desktop\Def Leppard\Acoustic in Singapore\06 Pour Some Sugar on Me.flac
                AccurateRip Verified Confidence 75 [CRCv2 f362b04a]
              • krafty
                • Dec 2021
                • 44
                Hmmm... this is weird, to your log, it would seem to me that the Pass 2 would have nothing to do with it. But in my case, it is happening when it get 2 passes. In your case, it would seem that that particular track is not present as ripped with the pressing offset +6, which it would be normal to think of. But in my case, it's like night and day... if I get a second pass, that only track won't register the pressing, I'm gonna do some testing here with two CDs I know they have a second pass.
                Update: I posted a new message but it got into the moderation filter. I was able to reproduce the problem. First track got 2 passes, other tracks got 1 pass. The first track missed the cross-pressing entries in the log. Then I noticed that the two passes might be caused by the drive spin up -- so it had to go 2 passes. I was able to get one pass in the log for that message that is in the moderation queue, that had the drive at full speed when ripping. I also did a second test with a spin up for 8 seconds each track - this time around it got one pass and also got the entries for the cross-rips. But the spin-up thing before each track does not mean much. It looks to me that whenever it goes to 2 passes, no matter what, it will fail to register the cross-rip reference. To workaround this second pass, I am ripping a new rip at full speed right after a first rip that had 2 passes.
                • krafty
                  • Dec 2021
                  • 44
                  Ok. Here's some interesting thing.
                  The pressing is this one.
                  The behaviour was funny.
                  The first track got two passes, but the I noticed that the drive was not at full speed. I ended up ripping the track again, before the drive would stop spinning completely, and I got not only 1 pass, but also the records for the other cross-ripping reference:
                  Notice that the first time around, it didn't record the +251 pressing with 2 passes.
                  Code:
                  dBpoweramp Release 17.4 Digital Audio Extraction Log from sexta-feira, 31 de dezembro de 2021 19:29
                  Drive & Settings
                  Ripping with drive 'F:   [ATAPI    - iHAS122   F     ]',  Drive offset: 6,  Overread Lead-in/out: No
                  AccurateRip: Active,  Using C2: No,  Cache: 1024 KB,  FUA Cache Invalidate: No
                  Pass 1 Drive Speed: Max,  Pass 2 Drive Speed: Max
                  Bad Sector Re-rip::  Drive Speed: Max,  Maximum Re-reads: 34
                  Encoder: Apple Lossless
                  DSP Effects / Actions: -dspeffect1="ReplayGain= -albummode={qt}0{qt} -itunnorm={qt}1{qt} -r128lufs={qt}-18{qt} -maxtgain={qt}25 dB{qt}"
                  Extraction Log
                  Track 1:  Ripped LBA 32 to 29470 (6:32) in 1:05. Filename: D:\MUSIC\AccurateRips_MR\Tears For Fears\Songs From The Big Chair\01 - Shout.m4a
                    AccurateRip: Accurate (confidence 90)     [Pass 1 & 2]
                    CRC32: 003C3B7E     AccurateRip CRC: CEC3BAA6 (CRCv2)     [DiscID: 008-000d4a46-0056d352-6009cf08-1]
                    AccurateRip Verified Confidence 90 [CRCv2 cec3baa6]
                    AccurateRip Verified Confidence 58 [CRCv1 ca7c7de]
                  Track 2:  Ripped LBA 29470 to 58842 (6:31) in 0:16. Filename: D:\MUSIC\AccurateRips_MR\Tears For Fears\Songs From The Big Chair\02 - The Working Hour.m4a
                    AccurateRip: Accurate (confidence 92)     [Pass 1]
                    CRC32: EFE95B47     AccurateRip CRC: 1CB2B59C (CRCv2)     [DiscID: 008-000d4a46-0056d352-6009cf08-2]
                    AccurateRip Verified Confidence 92 [CRCv2 1cb2b59c]
                    AccurateRip Verified Confidence 56 [CRCv1 d25bbfe]
                    AccurateRip Verified Confidence 53 [CRCv2 79f3e823], Using Pressing Offset +251
                    AccurateRip Verified Confidence 42 [CRCv1 82d6dea7], Using Pressing Offset +251
                  Track 3:  Ripped LBA 58842 to 77700 (4:11) in 0:09. Filename: D:\MUSIC\AccurateRips_MR\Tears For Fears\Songs From The Big Chair\03 - Everybody Wants To Rule The World.m4a
                    AccurateRip: Accurate (confidence 97)     [Pass 1]
                    CRC32: 50CFDB16     AccurateRip CRC: 33E47C3D (CRCv2)     [DiscID: 008-000d4a46-0056d352-6009cf08-3]
                    AccurateRip Verified Confidence 97 [CRCv2 33e47c3d]
                    AccurateRip Verified Confidence 57 [CRCv1 cfd84793]
                    AccurateRip Verified Confidence 55 [CRCv2 c4ce1b8d], Using Pressing Offset +251
                    AccurateRip Verified Confidence 43 [CRCv1 5fc4cdb2], Using Pressing Offset +251
                  Track 4:  Ripped LBA 77700 to 100967 (5:10) in 0:11. Filename: D:\MUSIC\AccurateRips_MR\Tears For Fears\Songs From The Big Chair\04 - Mothers Talk.m4a
                    AccurateRip: Accurate (confidence 95)     [Pass 1]
                    CRC32: 93D54352     AccurateRip CRC: 5301E12C (CRCv2)     [DiscID: 008-000d4a46-0056d352-6009cf08-4]
                    AccurateRip Verified Confidence 95 [CRCv2 5301e12c]
                    AccurateRip Verified Confidence 57 [CRCv1 27c09775]
                    AccurateRip Verified Confidence 52 [CRCv2 1117fc5], Using Pressing Offset +251
                    AccurateRip Verified Confidence 42 [CRCv1 6fc9fe52], Using Pressing Offset +251
                  Track 5:  Ripped LBA 100967 to 123062 (4:54) in 0:09. Filename: D:\MUSIC\AccurateRips_MR\Tears For Fears\Songs From The Big Chair\05 - I Believe.m4a
                    AccurateRip: Accurate (confidence 94)     [Pass 1]
                    CRC32: C5B2B9EB     AccurateRip CRC: 8BE65F91 (CRCv2)     [DiscID: 008-000d4a46-0056d352-6009cf08-5]
                    AccurateRip Verified Confidence 94 [CRCv2 8be65f91]
                    AccurateRip Verified Confidence 58 [CRCv1 cfb631a1]
                    AccurateRip Verified Confidence 52 [CRCv2 d42399c], Using Pressing Offset +251
                    AccurateRip Verified Confidence 42 [CRCv1 45f7fac9], Using Pressing Offset +251
                  Track 6:  Ripped LBA 123062 to 134945 (2:38) in 0:05. Filename: D:\MUSIC\AccurateRips_MR\Tears For Fears\Songs From The Big Chair\06 - Broken.m4a
                    CRC32: F22FDC2D     AccurateRip CRC: 048D56DE (CRCv2)     [DiscID: 008-000d4a46-0056d352-6009cf08-6]
                    AccurateRip Verified Confidence 94 [CRCv2 48d56de]
                    AccurateRip Verified Confidence 58 [CRCv1 73aa3d56]
                    AccurateRip Verified Confidence 53 [CRCv2 22457feb], Using Pressing Offset +251
                    AccurateRip Verified Confidence 42 [CRCv1 9c38ec1d], Using Pressing Offset +251
                  Track 7:  Ripped LBA 134945 to 157602 (5:02) in 0:09. Filename: D:\MUSIC\AccurateRips_MR\Tears For Fears\Songs From The Big Chair\07 - Head Over Heels.m4a
                    CRC32: FC07CD21     AccurateRip CRC: 9023C781 (CRCv2)     [DiscID: 008-000d4a46-0056d352-6009cf08-7]
                    AccurateRip Verified Confidence 95 [CRCv2 9023c781]
                    AccurateRip Verified Confidence 57 [CRCv1 a9aab813]
                    AccurateRip Verified Confidence 53 [CRCv2 4dae4a8e], Using Pressing Offset +251
                    AccurateRip Verified Confidence 43 [CRCv1 706b700b], Using Pressing Offset +251
                  Track 8:  Ripped LBA 157602 to 188362 (6:50) in 0:12. Filename: D:\MUSIC\AccurateRips_MR\Tears For Fears\Songs From The Big Chair\08 - Listen.m4a
                    CRC32: 91E9D402     AccurateRip CRC: D5CD8F62 (CRCv2)     [DiscID: 008-000d4a46-0056d352-6009cf08-8]
                    AccurateRip Verified Confidence 92 [CRCv2 d5cd8f62]
                    AccurateRip Verified Confidence 53 [CRCv1 1c868684]
                    AccurateRip Verified Confidence 52 [CRCv2 e9a4550], Using Pressing Offset +251
                    AccurateRip Verified Confidence 41 [CRCv1 cdea6de8], Using Pressing Offset +251
                  8 Tracks Ripped Accurately
                  dBpoweramp Release 17.4 Digital Audio Extraction Log from sexta-feira, 31 de dezembro de 2021 19:32
                  Drive & Settings
                  Extraction Log
                  Track 1:  Ripped LBA 32 to 29470 (6:32) in 0:20. Filename: D:\MUSIC\AccurateRips_MR\Tears For Fears\Songs From The Big Chair\01 - Shout.m4a
                    AccurateRip: Accurate (confidence 90)     [Pass 1]
                    AccurateRip Verified Confidence 54 [CRCv2 4c9692a8], Using Pressing Offset +251
                    AccurateRip Verified Confidence 42 [CRCv1 21c89b23], Using Pressing Offset +251
                  1 Tracks Ripped Accurately
                  • BOOTP
                    • Feb 2020
                    • 67
                    That is strange. Does your drive not support C2, as I see it disabled in the log?
                    My understanding is you would not get these multiple passes if C2 is enabled as errors would be identified via the C2 error protocol.
                    • krafty
                      • Dec 2021
                      • 44
                      Yes, it supports C2. But when I turn this on in DBPA, it can't rip any CD. So I leave this disabled.
                      In that other program we know of, it works as expected - but in Secure Mode it takes 20 to 30 minutes to rip one CD with Test & Copy.
