Test conversion - Meaning of the error message
  • Grga
    • Oct 2021
    On one old drive I did a test conversion of FLAC files, below is a message I have received at the end, I would appreciate if
    someone can explain what could be the reason of the error.
    I have tried to play the files, and everything is OK I did not hear any issues.
    • 43983
    Re: Test conversion - Meaning of the error message
    Try using dBpoweramp to convert one of those FLAC to Flac (without overwriting the existing).
    I am thinking they are corrupted.
    • Grga
      • Oct 2021
      OK, I'll try... if still receive the error m. file is corrupt and there is no remedy?
        • 43983
        Different players use different FLAC decoding libraries, FB2000 uses ffmpegs which might be able to decode the files. We use the official FLAC release.
        • Grga
          • Oct 2021
          OK thanks, I did not played this flac files for long time, do you know what can make them go corrupt?
            • 43983
            Bad disk (HDD or SSD), or perhaps they were created by a program which did not write them correctly.
            • Grga
              • Oct 2021
              Tried Foobar same thing, files are corrupt.
