Results 1 to 7 of 7
Thread: Is it possible to rip a CD directly to an NAS drive?
  1. #1
    Join Date
    Jun 2020
    For example, WD My Cloud drive: https://www.bestbuy.com/site/wd-my-c...?skuId=5990210
    Or would you have to rip to the internal drive or external drive that is connected by cable first and then move it to the NAS drive?
  2. #2
    Join Date
    Nov 2007
    Location
    Florida, USA
    Re: Is it possible to rip a CD directly to an NAS drive?
    Quote Originally Posted by ripcd View Post
    are you able to give the NAS drive a letter drive in your windows machine? If so, you should be able to rip directly there, just by pointing to that "letter" drive in the ripper location setting.
  3. #3
    Join Date
    Jun 2020
    I don't know, I don't have it yet, I'm trying to decide whether to buy it or not.
  4. #4
    Join Date
    Feb 2014
    You have to look if the NAS offers a SMB/Samba service. WD's NASs do it.
    Join Date
    Apr 2021
    Assuming you can write directly to the drive (which you should be able to), what's your backup strategy?
    I have a dedicated hard drive in my PC that holds the master copy of my music, which then gets synced to a backup server and a Pi (with attached storage) for streaming purposes.
    The device you linked to doesn't appear to have RAID (not that RAID is a backup), so it looks more like a backup target.
  6. #6
    Join Date
    Oct 2019
    Location
    Reading
    Yes you can if SMB is enabled on the NAS and the path in CD Ripper would be something like
    \\NAS\media\music
    You'll need to check on your NAS and folder names but remember your back up strategy.
    I know that CDR can rip in multiple formats but can it RIP in the same format to multiple locations?
  7. #7
    Join Date
    Apr 2002
    Yes you can use multi-encoder and have the same encoder multiple times with different locations to rip to.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
