Is it possible to rip a CD directly to an NAS drive?
  • ripcd
    • Jun 2020
    • 77
    For example, WD My Cloud drive: https://www.bestbuy.com/site/wd-my-c...?skuId=5990210
    Or would you have to rip to the internal drive or external drive that is connected by cable first and then move it to the NAS drive?
    Re: Is it possible to rip a CD directly to an NAS drive?
    are you able to give the NAS drive a letter drive in your windows machine? If so, you should be able to rip directly there, just by pointing to that "letter" drive in the ripper location setting.
    • ripcd
      • Jun 2020
      • 77
      I don't know, I don't have it yet, I'm trying to decide whether to buy it or not.
        • 1932
        You have to look if the NAS offers a SMB/Samba service. WD's NASs do it.
        • Hammerhead
          • Oct 2019
          • 10
          Yes you can if SMB is enabled on the NAS and the path in CD Ripper would be something like
          \\NAS\media\music
          You'll need to check on your NAS and folder names but remember your back up strategy.
          I know that CDR can rip in multiple formats but can it RIP in the same format to multiple locations?
            Yes you can use multi-encoder and have the same encoder multiple times with different locations to rip to.
