Unable to enable utility codeccs in Big Sur with 17.4 release
  • ogomez92
    • Apr 2021
    Hi, I want to enable length split, but I don't know how, I can't find the option in the converter page.
    The help site says to go into converter tab and it should be there but it isn't.
    • 43927
    Re: Unable to enable utility codeccs in Big Sur with 17.4 release
    In R17.x they are always enabled, in the encoder drop list look at the end of the list.
    • ogomez92
      • Apr 2021
      Ah yeah thanks, I didn't think to check the converter format instead the ADD DSp to look for split audio there. thx.
