Flac padding block written after picture instead of tags
  • RogerW
    • Jan 2021
    dbpa is writing the padding block after the picture block. This means the picture block has to be moved when adding a tag.
    If padding was written after the tag (vorbis comment) block then only the new tag and padding blocks would have to be written.
    Is there something I am missing?
    • 45170
    Re: Flac padding block written after picture instead of tags
    What if someone updates the picture? typically album art is around 500K which is nothing to be moved.
    • RogerW
      • Jan 2021
      Since there can be only one padding block no matter where it goes it will be a compromise.
      Thanks for the reply.
