Library Exclusions: issues with UTF-8, spaces and capitals
I've just discovered and installed Asset UPnP and I'm trying to run a 2nd instance with exclusion. However, I seem to be having an issue with UTF-8 characters:genre:=variété
becomes, after saving:
genre:=variété
This is quite typical of UTF-8 encoding issues.
So my question is: do exclusions support UTF-8 characters?
If not, is there a way to handle diacritics? (i.e. will genre:=variete match genre:=variété)
I had other questions regarding exclusions. Are spaces taken into account? And what about capital letters?
For example, will:
genre:=variete francaise
match the iTunes genre:
Variete Francaise
(I'm leaving the accents out for now)
Asset is running on Synology DSM 6.2 and I'm configuring Asset from Safari running on macOS 11.
Re: Library Exclusions: issues with UTF-8, spaces and capitals
Thanks for the bug report.
This problem has been addressed in Asset R7.1 beta-
https://forum.dbpoweramp.com/showthr...-Mac-amp-Linux
Just verified, "genre:=variété" is now stored correctly.
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
Copyright © illustrate 2021, All rights reserved
