Library Exclusions: issues with UTF-8, spaces and capitals
  • gemow
    • Sep 2020
    • 11
    I've just discovered and installed Asset UPnP and I'm trying to run a 2nd instance with exclusion. However, I seem to be having an issue with UTF-8 characters:
    genre:=variété
    becomes, after saving:
    genre:=variété
    This is quite typical of UTF-8 encoding issues.
    So my question is: do exclusions support UTF-8 characters?
    If not, is there a way to handle diacritics? (i.e. will genre:=variete match genre:=variété)
    I had other questions regarding exclusions. Are spaces taken into account? And what about capital letters?
    For example, will:
    genre:=variete francaise
    match the iTunes genre:
    Variete Francaise
    (I'm leaving the accents out for now)
    Asset is running on Synology DSM 6.2 and I'm configuring Asset from Safari running on macOS 11.
    • 1658
    Re: Library Exclusions: issues with UTF-8, spaces and capitals
    Thanks for the bug report.
    This problem has been addressed in Asset R7.1 beta-
    Current version: beta 5 Downloads: Mac (https://www.dbpoweramp.com/beta/Asset-R7.1b5.dmg) | QNAP (https://www.dbpoweramp.com/beta/Asset_R7.1b5.qpkg) | Synology (https://www.dbpoweramp.com/beta/Asset-R7.1b5.spk) Linux: x86 32-bit (https://www.dbpoweramp.com/beta/Asset-R7.1b5-Linux-x86.tar.gz) | x86 64-bit (https://www
    Just verified, "genre:=variété" is now stored correctly.
    • gemow
      • Sep 2020
      • 11
      Thanks for the fix!
