Accuracy problems after upgrading from R16.6 to R17
  • Stormrider
    • Feb 2019
    Hi
    aufter upgrading to R17 my accuracy for rips dropped from 95% or more to mostly less than 30% of the tracks i rip being ripped accuratly.
    Anyone experiencing similar problems?
    here's an example:
    here's the log of this rip maybe that helps to get ahold of the problem:
    The problem accurs on 2 dries built into the same computer and like i said til i updated the software worked flawless.
    • 43930
    Re: Accuracy problems after upgrading from R16.6 to R17
    Which DSP effects are you using?
    • Stormrider
      • Feb 2019
      Playlist writer, HDCD and ReplayGain on both formats (i am ripping to FLAC and MP3 at the same time).
        • 43930
        We have been able to reproduce, for now until R17.1, set the option 'Temporary Folder' in dBpoweramp Control Center >> Advanced
        set to the same location as if you type:
        %tmp% into the path of Windows file explorer, browse to that exact path and set.
        • Stormrider
          • Feb 2019
          Thanks for the fast reply.
          I did set the temporary folder to the standart folder windows/temp and that seems to work properly.
          Problem solve i guess.
